where is the VSS1 on a 93 impreza?
ok got the codes out, # 32 for the tranny issue, its the VSS1
where is it located? do you know the part number?
thanks in advance
Neo
One of them is built into the spedo head, the other is on the transmission (if this is an automatic).
nipper
as Nipper said
but to continue
VSS#1 is in the rear of the tranny
so it could be a wiring issue - broken/ corroded conn. ect.
VSS#2 is in the speedo head.
its def the VSS1, thats the code that the comp is giving me
is there a problem running like that? there is nothing wrong how it shifts or anything...
If its an automatic, you wont have AWD without both VSS operating.
nipper
yeah its an Auto, but i went to the barrens on staurday and i was playing in the snow yesterday and the AWD was and is working, still i have code 32 on the tranny, thats the VSS1, weird aint it?
ok that sounds it could be it
where is the ground thought, ground to the tranny?
Try reseting the TCU as well, by unplugging the battery for 45mins.
This may not help but the VSS#2
in my automatic 97 OB
is not working due to a bad drive gear.
It is stuck in AWD because of this problem.
I thought it would be the opposite but??
I have the FWD fuse in to overt the problem.
Have you noticed if it is in 4wd all of the time?
We are talking torque bind or other symptoms?
Might want try spinning the tires then put the FWD fuse in and give it a whirl.
No other symptoms, no torque bind or anything the only thing i've noticed since its that the first gear takes a little long to shift into second, but that may be the cold weather. I've noticed that when the front wheels start to spining the rear wheels kick in right away, so there is a 1 or 2 seconds delay there but definetely not stuck in AWD, i tried in the snow and at the pine barrens last saturday. the power light blinks whenever i start the car, and when i pull the code its code 32 ... VSS1, how long do I have to fix that till it causes any major problems? and does anybody know the part number for that sensor? just in case... but tomorrow i'm gonna get under the car remove the sensor and see if all the wires and connectors are in ok condition... i'm just afraid that i'm gonna cause any more damage driving like that
ok so this morning my car wouldnt shift gears, so i was thinking damn the tranny went, nahhh it was both VSS's gone, went ot the JY and got some sensors... VSS1 had a broken wire and VSS2 i believe was disconnected by vibration i think, so i changed the VSS1 and reconnected VSS2 i think and the car is all good again no codes at all. isnt it weird how 2 sensors can destroy a car? :confused: :confused: :lol: next step is the lift
cheers
Neo
