Subaru_Mechanic Posted April 12, 2007 Share Posted April 12, 2007 noboday seems to have decent pugs for sale, so im goin to 410 toyota and grabbin a set of 15'' steelies for my 27's... i need to dril the rims out tho, thing is i dont have a drill press/ tools to do it. can anyone do it? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 12, 2007 Share Posted April 12, 2007 You don't need a drill press - just a cheap variable speed 3/8" drill will do it. Use a small bit for a pilot hole, and then go with the larger bit. Taper the holes if you feel like it using a dremel. GD Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted April 12, 2007 Share Posted April 12, 2007 These were over a half inch thick and I adapted them to 4X140 with a hand drill. http://www.ultimatesubaru.org/photos/showphoto.php?photo=1386&cat=500&perpage=12&sort=3&ppuser=584 Just measure correctly the first time and keep the holes vertical. Not complicated. Someone had a template you could print off then overlay but I can't find the thread... Quote Link to comment Share on other sites More sharing options...
Turbone Posted April 12, 2007 Share Posted April 12, 2007 Bring them with you when you come to pick up the rear brakes. Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted April 13, 2007 Share Posted April 13, 2007 Are those rail wheels that you drilled out? Quote Link to comment Share on other sites More sharing options...
Subaru_Mechanic Posted April 13, 2007 Author Share Posted April 13, 2007 Bring them with you when you come to pick up the rear brakes. SWEET! will do:grin: Quote Link to comment Share on other sites More sharing options...
