August 30, 200718 yr my 95 leg sedan has a cel on, i sent him to autozone and you all know what they said, "it's OBDI we can't read it." so i found these post on reading the codes. http://www.ultimatesubaru.org/forum/showpost.php?p=549871&postcount=12 http://www.ultimatesubaru.org/forum/showpost.php?p=531744&postcount=6 http://www.ultimatesubaru.org/forum/showpost.php?p=532548&postcount=19 http://endwrench.com/images/pdfs/EWPreOBDAug05.pdf correct me if i'm wrong: black connectors under the dash will give me the codes in the memory. green connectors will give me the current operating trouble codes. both will clear the memory. thanks, john
August 30, 200718 yr my 95 leg sedan has a cel on, i sent him to autozone and you all know what they said, "it's OBDI we can't read it."john Did they actually look to see if there's a connector? My '95 is OBD2.
August 30, 200718 yr Author Did they actually look to see if there's a connector? My '95 is OBD2. good question. my son's doing this away at college. i'll have to ask. but does this mean the connectors aren't there and it will not give the codes?
August 30, 200718 yr Subaru started rolling out ODBII in '95. See if it has the ODBII connector. Not familiar with how to use the green and black connectors. There are articles on EndWrench about it though.
September 4, 200718 yr My experience with OBDII on my '95 2.2: Local auto parts store says, 'Can't read 95 Subarus'. I say, it's OBDII. They read the codes. Done. Nice guys.
September 4, 200718 yr Legacy777 wrote up how to check odb1 codes a very long time ago: http://www.surrealmirage.com/subaru/engine.html
