Documented: The 1970 FF-1 Project car...
I found a couple 1/64th scale Subaru's on Ebay that I HAD to have... They just arrived today :)
All 3 are rather accurate for their size....
But I wish I could get a larger model with opening doors and such :(
  • Replies 1.6k
  • Views 329.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • OMG! FINALLY! She will live again!  THE HOLE.... IS GONE! (more photos to come soon - i just opened the box, crappy phone pix!)       Now the fun begins.
  • SEAT PHOTOS!   Again, seats are from a 1982 Mazda GLC. They were from the original owner, who'd removed them from his car when new to install Sparco seats. Sat in his basement for 30 years waiting
  • Horns work!  (BEEP BEEP you've been warned!)   click here for video       Engine will be back inside of the car TODAY
Posted Images
Has anyone here ever setup an aftermarket Oil Pressure gauge or Fuel Meter gauge on an early EA car? I'm trying to figure out whats required.
Alright, I found some later model brake drums on ebay. I'll find out if they are compatible with the backing plates/etc. when they get here...
Hopefully they work, so I can use the longer studs and keep these wheels!
I forget but did you look into maybe modifying some 2wd EA82Turbo rear discs to work with your FF-1 rear suspension? That would be pretty cool...
-Bill
-Bill
They have a 3-bolt mounting pattern, which is different. It might be do-able, but the bearings might mount differently too, which would be a more difficult issue.
I'd need to see them to be sure though...
Edited by Kostamojen
Well the drums I ordered didn't pan out... They are totally different :(
The hub mounts differently, the height is different, everything is different...
Has any other year FWD Subaru had Aluminum rear drums???
Anyway, I did get another suggestion that might help with the wheels. I'll look into that and report back later...
you might be able to find some this guy
http://medford.craigslist.org/pts/979755765.html
I posted that over in the ebay/craigslist section... I only need a couple parts, and a couple of those i'll have repaired. The driver side glass and the vent covers are all I really need, and i'm contemplating having someone fabricate custom vent covers.
Honestly, other than the engine, theres really no other Subaru that the FF-1 is similar too.
The Chassis, Suspension, body parts/accents/etc. are all completely different than any other model...
But thats why its so great :D
Yes, I Agree! ... it is a Pretty Car! :) I Like it.
There are Few of Them Still Runnin` Fine Here, some 1,100 And Some 1,300 Engine
(Sport I Believe)
Alright, im at a critical juncture here...
I absolutely need to decide on what tire size to run!
I'm still 50/50 on going with 15" or 14" wheels, more specifically I either want to run 195/45/14"s or 195/45/15"s.
Yes, I already have the 14" Enkeis, however they still need restoring (which costs money) and I'd have to have spacers made for the rear (which is an issue due to the studs). But the more I see 15" small profile tires, the more I like them. And I havent seen 15"s on any FF-1's.
So basically, i've figured that each size has its positive and negative attributes:
195/45/14 tires (with either the Enkei wheels, or custom steelies)
Positives - Plenty of clearance to fit them, will allow me to lower the car even more (over 1" of extra lowering due to tire diameter), will accelerate faster due to smaller diameter and lighter weight.
Negatives - Will lower gearing ratio and screw up the speedometer a bit, also they look quite small on a car from the photos i've seen.
195/45/15 tires (with the Australian Superlights, or custom steelies)
Positives - will fill out the wheel wells nicely, will probably look better on the car, won't screw up the speedo/gearing much.
Negatives - more weight, won't lower the car any, with the Superlights they might not clear the front inner fender when turning.
So basically, the 15"s (which I know will clear the fenders if I did custom wheels, they are not that large for 15" tires since they have the 45 series sidewall) might be better for driving the car in rough conditions and at higher speeds and the car and might look more porportional, but the 14's would let me lower the car more which might look better too...
Either way, I still can't decide :( Basically, no matter which route I go, I still need to spend wheel money, and I can sell the Enkeis ASAP for cash which will go straight into any of the other wheel options...
Thoughts/Opinions?
for reference....
14s:
15s:
kinda hard to tell from those pics, with the ride height being so different. but from a looks standpoint, I think the 14s fit better.
I think the offset is different with pugs anyway, they seem to stick out about 1/2 inch more then the factory wheels do.
This is my first time seeing this thread. I think the 15 pugs look good but yea sit to wide. Heres a question. Have you considered widening the wheel wells. Since your going lower and for a unique look i think it would enhance the stance of your ride. I believe they use fiberglass but it would be alot of custom work. Might be cool to see. Nice project buy the way.
Ben
Edited by The Dude Abides
Ben
Yeah I think pugs are actually wider than that! The widening of the fender thing sounds cool! But it all depends on how "factory" you want to keep the car looking
Ben
The rear fender wells were changed:
The pugs were not so much of an issue as the 205/55 tires were. With 195/45's they wont stick out from the side of a 6" wide wheel so they will be pretty much "flush" with the rear fender. And with the modified rear fenders, the suspension will bottom out before the tires hit the fender.
The problem with the 15's with the offset that the pugs have (~+25) is the front:
Notice how far those wheels stick out even if the fat tires were not on there. However, I could pull the front fenders out, thats not too difficult to do...
Now that wouldn't be an issue if I went with the custom steelie approach, since I could have the offset put exactly how I need it.
Here is another photo of 14's, specifically the Enkei's on an FF-1. Notice how small they look, and the tires I would be using are even smaller than those:
Right now, i'm leaning towards the 15's with custom steelies...
If i were you i would definately go with the 15s. I do like how those pugs look on that butt i can see the offset being a problem. If you were to widen both front and rear wheel wells again, how would that look. Would the front stick out further then the front. With those 15inch weels, wide wells, and a low stance that would look sick.
Buy what year and model is that white subaru with the 15inch pugs anyways.
Well now I'm starting to lean back to the 14's again, after looking closely at more pics (was going to post this earlier, but the site was down):
Notice how the FRONT wheels are pretty much flush with the fender, while the rears are in quite a bit. It appears that the front suspension would work best with a +50 or +45 offset, while the rears need to be much lower, especially dealing with my suspension problem.
Now I'm thinking that the spacers in the rear will even things out...
This won't work with the 15" superlights since they have the same offset as the Pugs, but custom steelies I could do different offsets for front and rear (say, +45 front, +30 rear) and it would work.
I think that spacers in the rear would definitely solve your problem. You just need to find some lugs that work!
I shipped one of my drums to RenaissanceMan so he can make some spacers. I'm going to try these 14's and see how they work.
So your gonna be able to get longer studs on there?!?!
I'm going to try and find some double sided bolts with modified washers to fill the gap. I think it should work, I just have to find the right width bolt with the right thread pattern.
Sweet! Well good luck! I'm looking forward to seeing the wheels on there!
Even if the thread pitch isn't the same, you might want to go down to Napa and see if they can find something for you thats longer but will press into the drum and hubs. They might even let you dig around and try and find something and even if you pay a couple bucks for one and it doesn't work, you're still trying to discover how to make it work and everything counts, even if it doesn't work. Just something I'd try to do.
Thats pretty much what I was going to do. Theres another local place called Tognottis that has more quality aftermarket bits that can help too.
I figure i'll check ARP's catalog after I figure out exactly what I need.
I shouldve thought of this earlier, but why dont you look in Speedway's Online Oval-track parts catalog, speedwaymotors.com
They sell everything you could ever need to build a race care, which also means longer racing studs, and the prices are usually very reasonable and the quality is very good.
-Bill
Just a FYI, I am working on the car, mostly just restoring/painting small parts right now to rebuild the suspension.
In the mean time, here are a few pics i've found online recently to tide you over...
Oh, and im still mulling over the wheels/tires... I'm having spacers made, but now i've discovered 195/40/16's! :(
