TheLoyale Posted September 30, 2007 Share Posted September 30, 2007 What's a good NGK for the EA82? Please post plug# I've got Bosh platmums right now, But sometimes runs a little ruff. Like a Blup.. blup.. bla.. kinda thing.But has power and runs vary well.. Quote Link to comment Share on other sites More sharing options...
GLCraig Posted September 30, 2007 Share Posted September 30, 2007 Bpr6es-11 Quote Link to comment Share on other sites More sharing options...
Infinitrium Posted September 30, 2007 Share Posted September 30, 2007 Good ol' V-Powers Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted September 30, 2007 Author Share Posted September 30, 2007 What's a V-power?? A plug? Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted September 30, 2007 Share Posted September 30, 2007 What's a V-power?? A plug? Ngk v power is what they meant. Not sure if that really helps over the good old standard ngk plug as said above. Can't go wrong with ngk. That is what I have been running in all of the cars I work on from Jeeps to subies to vw's. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted September 30, 2007 Author Share Posted September 30, 2007 Yeah i was going to put NGK in but my dad said Bosh is better. Because he had problems with NGK. Fouling out and stuff. But i should have just gone with them in the first place. Thanx Quote Link to comment Share on other sites More sharing options...
DaveT Posted September 30, 2007 Share Posted September 30, 2007 I have used BPR7ES for years. They are a cooler version of the BPR6ES. Every EA82 I've had has had mild, occasional pre-ignition. The cooler plugs seem to help a bit. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted September 30, 2007 Author Share Posted September 30, 2007 Yeah ok i'll have to try them... I mean the only real time it does it's blup blup thing is when you put the brake on to put it in Drive or Reverse. then it does it a little bit. And other then that it runs good.... The one other thing is when you first start it for the day it will run a little ruff and the RPM's will drop around 450-550 but you give it a little gun and then runs good. So i'll get some better plugs soon. Thank's for the plug # Quote Link to comment Share on other sites More sharing options...
