October 13, 200718 yr my rear u joint is bad on my xt6 so im running it in front wheel drive for a while untill i come up with a good solution. the u joint is "staked" basicaly its held in with about 10 little hits with a punch to hold the cups into the driveshaft. parts books at parts stores dont list one since subaru wanted you to replace the whole drive shaft if it ever failed. so i did some measuring and i think i found a u joint for another car that will fit... but has anyone ever done this? any part numbers? thanks
October 13, 200718 yr rockford sells ujoints specifically for the XT6. i have a complete set installed in mine. dont know the part numbers but i've posted them on here and at the XT site before. they are rather steep - $20 or $30 each. easiest solution is to just get a used one. if it's the rear portion then ANY EA82 or ER27 rear half shaft will work. i probably have one i could send you...as do tons of others here on the board.
October 14, 200718 yr 430-10 is their number for the u-joint. Here's the link.... http://www.rockforddriveline.com/New%20Parts%20Page/Staked%20In%20Page.pdf
October 14, 200718 yr these dudes know what's up. I'm running a "gary's special" rear driveshaft in my xt6 right now
October 14, 200718 yr Dont let those stake marks spook ya. just use a strong vise and start driving them out. easy as pie. Just act likethey are not even staked.I already practiced on a rear half that NUG gave me with the RX,and it was pretty easy.Ive got new ones ready for Roxy.and plan on doing them both as soon as i get home. Ill take some good digital photos and document the process.
September 28, 201015 yr What is it with you and three year old threads dude? Most of these people don't hang around here much anymore..... Why not just start a thread and ask your question? Bad form. GD
