Reman Gasket Set?
In the process of rebuilding my 98 Outback 2.5 DOHC .
Whats the difference between the overall gasket set 10105AA401, and the Reman Block Set 10104AA060 ?
reman block set should have everything needed to split the block - not much too it really.
the "overall" gasket set sounds weird, never heard that terminology before, is that a head set or head gasket set?
Can't say much about the "block set". I would imagine it has the case o-rings and maybe head gaskets.
The 401 set is a complete set: all the gaskets and o-rings except valve cover gaskets. Also valve stem seals, exhaust gaskets, intake gaskets, oil filler neck o-rings, water crossover pipe o-rings, dipstick tube o-rings, etc.
What are you planning on doing anyway?
Emily
http://www.ccrengines.com
I'm rebuilding the short block, new bearings, pistons, and rings etc. I have the 401 gasket set for this, but see another kit also, if you use a reman short block?
I'm wondering what the difference was? I believe it cost more for the reman block kit. The 401 kit has all the o rings and gaskets included for rebuilding the short block? So why would it cost more? Thicker Head Gaskets for decking the blocks????:confused:
If you're already using a reman'd shortblock, you don't need the case o-rings (there are quite a few), the oil pump o-rings, etc.
If you are doing a complete engine, you need all those PLUS the head gaskets, cam seals, front and rear main seals.
Long story short: the 401 is for a complete engine rebuild and has everything, except valve cover gaskets.
Emily
Thats sort of odd.
nipper
Here's some part # based info on the #'s you listed; difference in msrp is maybe $15.
10104AA060 reman ENGINE GASKET KIT COMPLETE FOR 1997-1999 LEGACY OUTBACK 2.5 includes headgasket set, engine seals, orings, washers & gaskets (this kit does not include valve cover gaskets) NOTE this kit is for use with subaru reman block only)
10105AA401 ENGINE GASKET KIT COMPLETE FOR 1997-1999 LEGACY OUTBACK 2.5 ALL includes headgasket set, valve cover gaskets, engine seals, orings, washers & gaskets
