November 23, 200718 yr i have a 1979 subaru wagon that has 56,000 miles on it. it sat for 5 years with out being driven. i have had the carb rebuilt, new gas tank and a few other things. i had driven it maybe 50 miles and it lost about half of it power...any thoughts on what it might be?
November 23, 200718 yr after sitting for 5 years...could be lots of things. carb is the first thing that pops in my head, but sounds like you're confident that is not the problem? have you tried spraying starter fluid in there while cranking? fuel filter and ignition (plugs, wires, cap rotor) come to mind. vacuum hoses are a good thing to check too. if you have a compression tester might want to see what you get.
November 23, 200718 yr Hey jacearby....give me a call. I'm in Euless and have worked with these older Subys for years. I'm PM you my # Todd subaru3@aol.com www.vintagesubaru.com
November 24, 200718 yr LACK OF FUEL fix with weber ignition? fix with electronic alt? fix with xt6 adjust valves
May 16, 200916 yr If it Ran Good for around 50 Miles and then Lost Half of its Power, all that after five Years sat... Could it Have a Clogged Exhaust? Because seems like Something is getting Hard to Move... Have you Checked the Vacuum Lines? Good Luck!
