January 23, 200818 yr Chances are, yes. We need to see the sides of them, to see if there are oil feed/return ports and coolant ports. EDIT: IT does look like the turbo mounting holes are there and tapped. I'm going to say yes. Also, I didn't realize how much of an offset the intake ports were.
January 23, 200818 yr Here are the sides. The Head on the right should have a tube sticking out of the big hole on its bottom left corner. The tube that's missing is for the oil return from the turbo.
January 23, 200818 yr l'm no expert on 82t's having never owned one but shouldn't there be injector bosses visible like an 81t?
January 23, 200818 yr Somewhere on the head it should have EA82 cast into them. If it's just EA82, they're first generation, if there's a line under it, it's 2nd, if there's a box around it, it's 3rd. It's believed that they got better, but I can't remember the changes that made them better.
January 24, 200818 yr The Head on the right should have a tube sticking out of the big hole on its bottom left corner. The tube that's missing is for the oil return from the turbo. +1 but is it oil or coolant? but definately a line coming out on turbo heads
January 25, 200818 yr +1 but is it oil or coolant? but definately a line coming out on turbo heads Oil return on rear (as installed) of right head (1-3 side). Coolant has a port on the bottom of same head.
