February 4, 200818 yr i put a 2.2 in a 2.5 outback recently and i got a code 106 "manifold absalute pressure" this is a new one on me any clues????
February 4, 200818 yr Howdy J, We will assume you mean P0106 My documentation says P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem The MAP / Baro sensors and their exchange solenoid are located on the pass side strut tower. Make sure the line from them is connected to the intake manifold. You could test the solenoid but testing beyond that is not in my inventory. Hope this helps
February 4, 200818 yr the hose from that solenoid also has a small in-line filter in route to the intake, it is about 1" circular in shape and has a foam covering. that being clogged will set of the CEL. the only time i've seen it was a EGR code, but i think in my dealings with that i saw mention of the P0106 related sensor you're referring to.
February 4, 200818 yr First, a thaks to Jules for posting this. Second, a thanks to Gary for mentioning the filter. Third, I confess to being a big dummie - Red Fox size. My 97 OB with a 2.2 swap also has this error code. That is why I knew where to look to take the picture. Now the big dummie part. I went out to get a picture for Jules of the filter and lo and behold. Mine is hanging on the end of a hose going nowhere!!! Can anyone tell me where it is suppose to connect. I saw no open nipples on the intake. Ya big dummie!!
February 4, 200818 yr Author it comes from UNDER the intake, there should be a black T in there that it plugs into, and ill have to take a look and see if mine is off too it DID PD the code(lock to memory) im going to take a look thanks skip thanks gary
February 4, 200818 yr quit calling my friend skip a dummie! awesome skip, that's sweet! it runs fine like that? from memory i believe there's a T fitting from that hose you can see in the same picture. looks like yours might not have it. the hose i'm speaking of is the one facing the passengers seat parallel to the ground so to speak, at least coming out of the intake it's || to the ground. this hose should have a T fitting that your filter hose connects to.
February 4, 200818 yr [...]Mine is hanging on the end of a hose going nowhere!!! Can anyone tell me where it is suppose to connect.[...] From the pic, it looks like you have a vacuum hose running from the nipple on intake manifold #3 runner going directly to (I assume) the fuel pressure regulator. There's supposed to be a short piece of hose from that nipple to a T, then the hose from the T continuing to the regulator. The loose hose with the filter should be routed under the intake, and connected to the center nipple of the T. While you have the hood up, see if there's an emission control diagram pasted to it. It won't show the physical routing, but should give the hose schematic.
February 4, 200818 yr Okay, so I'm not as good at this as porcupine73. Anyway, the text says "< T about here", if it can't be read.
February 4, 200818 yr Author quit calling my friend skip a dummie!awesome skip, that's sweet! it runs fine like that? from memory i believe there's a T fitting from that hose you can see in the same picture. looks like yours might not have it. the hose i'm speaking of is the one facing the passengers seat parallel to the ground so to speak, at least coming out of the intake it's || to the ground. this hose should have a T fitting that your filter hose connects to. are you refering to me me calling skip a dummie no that is NOT me i love skip i have allways loved skip and he will confirm that and i was thinking of 2.5, not the 2.2 so i am the dummie gary you got issue with me??? i mean to offend no one!!!
February 5, 200818 yr are you refering to meme calling skip a dummie...........................gary you got issue with me??? ha! another joke you missed, someone else called skip a dummie: Third, I confess to being a big dummie - Red Fox size. Ya big dummie!! now don't do it again!
February 5, 200818 yr Author no one said i had to understand sarcasim or know how to spell to oin this board.............. just love my subaru and i do more than that i love em all actually anything with an engine yup pretty much thats me not laughing but i am working trans rebuild gotta go
February 5, 200818 yr Hey Skip. I have one of each here. A 97 2.5 and a 95 Legacy 2.2. I can look tomorrow. I do think it's basically under the intake for #3 as has been posted. To give you some idea I think I forgot to replug it back into the T after removing it to place the temperature sensor (for the dash) sensor spade terminal back on - I needed a little more room. I think it's just towards the firewall from the temp sensor. Then again - my memory isn't always so good - but you knew that. If you wanna stop by and swap stuff I can make sure both cars are here. We can clear the codes and see what happens. Dave
February 5, 200818 yr Okay guys, Please let me rectify the situation. First, thanks for the help, I'll email ya Dave. Second, I'm the big dummie (so called by I) Here I am, offering all this help and then standing "nekid" in front of the crowd. (hangs his head in the shame of it all) thanks Steve if you're watchin' Third, My man OB99W nailed it with his picture. (pictures do help, I hope we all learn a lesson from this) My swapped engine did not have this "T" fitting he shows. As my penitence.. I will and do so promise to correct this error tomorrow and post a follow up. I will just possibly - add a "must check" on EJ25 to EJ22 swaps for all those interested. We/I owe a thanks once again to Jules for asking and to Gary for bringing up the filter. Thanks to all, I'll go grab a towel now to cover my privates.
February 5, 200818 yr [...]Third, My man OB99W nailed it with his picture.(pictures do help, I hope we all learn a lesson from this) My swapped engine did not have this "T" fitting he shows.[...] I take no credit for the original picture -- it's your pic Skip, which I: 1) downloaded 2) converted to bitmap 3) "Painted" 4) cropped to reduce bandwidth 5) converted back to JPEG 6) uploaded I'm sure all the manipulation contributed to the blur, but if it got the job done...
February 5, 200818 yr Author i wish i knew how to do all that picture stuff.............. i know how to use digi camera, but not that hosting stuff i feel old
February 5, 200818 yr i feel old i have some good news and some bad news, the bad news first, you are old!! and the good, you are going to get older!! it's more fun than the alternative.
February 5, 200818 yr Author i have some good news and some bad news, the bad news first, you are old!! and the good, you are going to get older!! it's more fun than the alternative. BUT I DONT WANT TOO in a winny childs voice
February 5, 200818 yr [...]you are old!![...] Old at 33? Wow, John, now you're making me feel really old! From http://www.answers.com/old&r=67 : 1.a Having lived or existed for a relatively long time; far advanced in years or life. But since it's all relative... My definition of "old": someone who has at least a few years on you, no matter what your present age. Or, another definition from the above link: 12. Skilled or able through long experience; practiced. Yeah, I like that one.
February 5, 200818 yr hey guys are the 2.5 engines so bad that it's better to just replace it with a 2.2? Usually people want more power, not less.
February 5, 200818 yr You can get the 106 code if you cross the two vacum hoses that go to the solenoids. If you cross them, you only get vacum to the map sensor when the egr valve is open. I did it once. Figured it out real quick.
February 5, 200818 yr hey guys are the 2.5 engines so bad that it's better to just replace it with a 2.2? Usually people want more power, not less. It depends what's wrong with the particular 2.5. The 2.5s are prone to piston slap and HG leakage. There's a question as to whether even the latest HGs from Subaru fix the problem. Of course, if the engine was allowed to significantly overheat (due to bad HGs or whatever) or otherwise suffered, putting in one of the more-reliable 2.2s may be the best option for some people. A decent used 2.2 (getting somewhat harder to find as time goes by) may be cheaper than reworking a 2.5 with enough problems.
February 5, 200818 yr ^^^^^^^^ Could not be better put. I'll just add the non-intereference aspect is a draw to some of us.
February 5, 200818 yr [...]I'll just addthe non-intereference aspect is a draw to some of us. Good point -- better to be just stranded if a timing belt breaks, than be stranded and have the possibility of bent valves, etc.
February 5, 200818 yr Author hey guys are the 2.5 engines so bad that it's better to just replace it with a 2.2? Usually people want more power, not less. you can get more power out of a built 2.2 than a built 2.5(phase 1) becouse the 2.5 will blow its gaskets under any kind of boost/compression
February 5, 200818 yr I wonder why subaru doesn't offer the 2.2L engine as a cheaper option to the 2.5L on all new cars? It would save them millions on warranty repairs alone.
