July 17, 200817 yr so here the deal, i recycled a gl-10 sedan. i got the entire harness with no cut wires anywhere, and now have a running motor to put in my project wagon. once i had the wiring out i decided to have a little fun. i've never ran a motor just sitting on the floor so i tried and it worked. heres the pics the wagon waiting for a motor front fenders from the sedan for the wagon check out the meaty winter tires that came on the car heres the motor like the fuel system and heres the motor running
July 17, 200817 yr That is the coolest thing ever. Running the motor out of the car with a functional dash, out side of the car. Jeff
July 17, 200817 yr Hi This is Jerry, i built an engine stand for my 2.2 engine it had oil pressure gauge and the radaitor hook up. When i open up the front 2 barrels it would pick up the stand off the floor about 2 inches. It's really cool to see an engine running out of the car. Thanks Jerry
July 20, 200817 yr My brother in law has something like that set up in his shop but its permanant for "experimental" reasons on a '63 VW bug motor :-p
July 20, 200817 yr Very cool. You should hook the exhaust up to a hose venting outside if you are going to run it a lot. But there is no better way to prove it all works without putting it back in the car.
July 21, 200817 yr Author Very cool. You should hook the exhaust up to a hose venting outside if you are going to run it a lot. But there is no better way to prove it all works without putting it back in the car. thanks, that motor is now in a wagon and run about as good as it did on the floor. im blaming all the crappy fuel its been running on. im hopping all it needs is some fresh fuel and a tune up to last for it a bit
July 21, 200817 yr thats priceless, it looks like something i would do, not sureif that is a good thing or not though.
