I long for the boost love
Caboobaroo
Oh man, I haven't updated this thread for a long time. More things have been done since the last update. I got all the intake/PCV plumbing in and done, had to replace the crappy F-pipe since it broke. PS lines are the EJ22T down to the ends of the flex lines, then I had EA82 ends put on so they mate up to the EA steering rack. I also cut the crap out of the core support for the EJ22T radiator to fit. Got the EA81 A/C slim fan to fit between the radiator and the PS pump with about 1/2" of clearance. Still need to figure out the other side as far as a fan. Wiring harness is in and a couple wires still need to be spliced together since I didn't want to splice them out of the car and then run into an issue of it being too short.
Everything else is done though as far as I can think. Oh well maybe not the heater hoses and a couple bolts here and there.... Here's a pic, the rest are in my gallery.
http://rides.webshots.com/album/555167621jgSQVh
  • Replies 114
  • Created
  • Last Reply
Top Posters In This Topic
Rob its not really a race.. The clock starts when you start the project. Russ is dreaming big I will give him that, but just doing a little at a time instead of all at once he would have been driving this car a few years ago. Then it would have beena series of small projects and not ginormous one.
Hurry up Russ!
Mykey
Hurry up Russ!
Mykey
Oh, it is now :rolleyes:
I started mine on Fri.
slackers........:grin:i don't believe either one of you are building anything.:grin:cheers, brian
For whatever reason, that came off really funny.:) Good job on the swap caboob, don't get unmotivated, it'll get done soon. I am in the same boat.
This still isn't done?!!?
Don't forget to put oil in it!:lol:
No still not done. I lost motivation awhile ago for a few months but I've had a hair up my @$$ in the last couple months so stuff has been getting done. I've been trying to get a few other things done with it too like '05 STi engine mounts, fitting that radiator in there and figuring out what fans I want to run.
Oh and there's oil in it:lol:
  • 4 months later...
Woo woo! Progress is slow but continues!
I'm currently working on the exhaust for it since it was another thing I needed to do. Picked up an ERZ 3" bellmouth catless downpipe with a broken hanger and an Esplier JTC-500 catback from my buddy's '05 STi monster. I got the downpipe fixed yesterday and will be installing it today. Then I might hit up the junkyard to see if I can find the 3AT crossmember I need and see what I can do to make it work.
I also have all my electrical stuff at the house now (Power Probe, DVOM, etc.) so I can figure out what's going on with my harness.
Time to get crack-a-lackin!
HOORAY for progress!!!
Yesterday I took my harness down to Suberdave's and we went through it checking it out. Glad to have another set of eyes on it since I was going crosseyed everytime I'd look at it.
Did a couple small connections, figured out all the other loose ends and its ready! I came home yesterday, put it in the car, found out my fuel pump is no worky and stopped. Went onto do yardwork instead:rolleyes:
I just ordered a NEW Walbro 255LPH pump since the used one I have is crap. Now I just gotta wait for it to show up, along with a new oxygen sensor, new serpentine belt, an alternator, and a few other small items I've been needing. With any luck, I might just get a trip permit and bring it to the show instead of the XT6:rolleyes:
So got more work done... then another problem arose. For the harness in and connected and for some reason the fuel pump relay isn't getting grounded through the ecu like it should. Everything else checks out good... bad ecu maybe?
