December 6, 201015 yr :confused:ok hopfuly somone can help me i have a 91 loyal i built the lift exact to the plans all that turned out perfect then came the not so fun part tryed meny different ways to get thes instald.. how do u get this to go together on the front the only thing i did not do was remove the axel. I could not get the extra clearance can someone plese help it would be very healpful :confused:
December 7, 201015 yr have you already dropped the engine crossmember? He doesn't need to drop the engine crossmember. If you do not know the specifics of this lift; please don't waste your time, and the OPs by responding. Thank you.
December 8, 201015 yr ya i know abought the lift no need to bash lift is in thanck you to the person how hellped my other car is also liffted with the same lift !!!!!!!!!!!!!!!!!!!!!!!!!
December 11, 201015 yr Could you use these blocks to make a 4 inch lift? If you can what all would i have to lower?
December 11, 201015 yr You need to READ all of the information already provided. There is a wealth of it in all of the stickys. Long story short/simple answer: NO. You can't do a 4" lift on just the struts. You need to drop crossmembers if you go 4". For all of that information, I'll leave you to research the countless other threads answering those questions.
December 22, 201015 yr So just read through this entire thing, no one did it with a g2, so i'm assuming it doesn't work? And yeah, daily driver 2002 OBW VDC H6... was planing on getting highguy lifts... but gloyale is MIA since the 15th...
January 20, 201115 yr Author 3" is going to be hard on those axles, its worth a try though...... Jeff
January 20, 201115 yr Ohh ya. Found that one out first hand. Made it about a block before the constant chatter. Popped it in 4wheel and it went away mostly. PO replaced the rear cv's but not the front. Any advice on the best off road axle for your buck?
January 22, 201115 yr can you do the torsion bar in an e82? got the front blocks made but dont have any idea how to bend 3/8 steel at a 45* angle
January 22, 201115 yr nvm but anyone know how the hell you bend 3/8" steel? a large adjustable wrench and an oxyacetylene torch.
March 17, 201115 yr how do you adjust the camber on the ea82? i had a friend help me with this and can't figure it out. Edited March 17, 201115 yr by stetjo02 idiocy
March 17, 201115 yr how do you adjust the camber on the ea82? i had a friend help me with this and can't figure it out. Front or rear? Front blocks need to be at a 15* angle pushing the strut inwards towards the engine. rear straps need to be at a 45* angle - dropping the crossmembers about an inch is a good idea too if you dont want your axles to start spewin out grease Edited March 17, 201115 yr by Loyale90 info and spellign
March 18, 201115 yr Front or rear? Front blocks need to be at a 15* angle pushing the strut inwards towards the engine. rear straps need to be at a 45* angle - dropping the crossmembers about an inch is a good idea too if you dont want your axles to start spewin out grease The front ones. The rear looks fine the way it is, I just can't figure out why my front tires are leaning out at the top. He cut the blocks at 15* and they are pushing the tops of the struts inward. The 2" block has the holes offset correctly, I believe. Could not having dropped the crossmember cause this?
March 19, 201115 yr The front ones. The rear looks fine the way it is, I just can't figure out why my front tires are leaning out at the top. He cut the blocks at 15* and they are pushing the tops of the struts inward. The 2" block has the holes offset correctly, I believe. Could not having dropped the crossmember cause this? This is loyale90 not sure maybe the angle of the axle made a little bit of difference. not having dropped the crossmembers ate my axles its really easy to do and made the axles ALOT less stressed.
March 25, 201115 yr Author The front ones. The rear looks fine the way it is, I just can't figure out why my front tires are leaning out at the top. He cut the blocks at 15* and they are pushing the tops of the struts inward. The 2" block has the holes offset correctly, I believe. Could not having dropped the crossmember cause this? Have you moved or rolled the car? that will make it settle down if you do that, other wise it will look like this \--/ Jeff
April 5, 201214 yr I know this thread is old, But I'm wondering if this lift would work for a 90 legacy ?
