I'm about to give up!!
Ok so I have scoured the archives for months trying all kinds of different things to fix this problem! Here is the issue: After the car has warmed up (91 Loyale) I get this horrible surging and hesitation and the occasional backfire... I checked the ecu codes, was getting a 35, so I removed the solenoid and put a transistor in its place... all fine and dandy CEL is gone. Ok, well that didn't fix it. I've tried to locate a vacuum leak with no luck. Also, cleaned up the mass air flow sensor, no fix either. Checked the plugs, wires, and the timing... still nothing!! Man its killin me. I love this car and it has been such a fun reliable vehicle and I refuse to get rid of it!! The only thing I can say is that when its cold and I start it up in the morning it runs awesome... just like it used to, then as the engine warms up I start to run into all the issues mentioned above. Please, does anybody have any ideas whatsover... I'm really close to taking the car up to a well known subaru mechanic in Green Mtn Falls if I can't resolve this myself.
Check your CTS ..sounds like thats where your problem may be..check the connection for corrosion and then the CTS itself.
and just for giggles...try swapping another coil into it
Coolant Temperature Sensor, it tells the ECU how hot the engine is and adjusts the fuel ratio and timing accordingly. At least thats what Ive been led to believe... Im a carb guy :grin:
-Bill
Ok, yeah I'll check the CTS as soon as I get home from work...
How about fuel flow? low pressure? clogged filter?
Would the car run fine when its cold even if the timing belt is a tooth skipped?
It could run fine when cold with a fuel problem...injector is enriched for cold start and warm up. Timing problem should be consistant.
my ej22 did pretty fine when cold, then like poo when warming up and after. was Tbelt skipped.
On an EA82 it will run like poo no matter warm or cold if one of the belts slipped a tooth. I do not believe this to be your problem.
-Bill
-Bill[/quote
Yeah thats kind of what I was thinking... The CTS problem seems to make sense.
MY XT6 had a bad connector on the CTS ( the ER27 is the same as the EA82 just with 2 more cylinders) and had the same symptoms ..ran awesom cold...warmed up ..studdered and stalled etc. I put a new connector on and it helped a great deal.. Also a friend had similar with an EJ22 ..put a new CTS ..purrs like a kitten now.
God Luck!
God Luck!
Ok, cleaning the connectors didn't seem to do the trick... got bummed out cause I warmed up the engine and it was running great, took it for a spin and it started up again.
would say its somin to do with the mixture, CTS sounds quite convincing, mine does the same atm, but thats cause of the carb setup, start it up from cold, runs real nice, warms up, mixture changes density with the heat and runs lumpy, doesnt help that it keeps fouling the plugs as well GRRRRRR lol
Definietly has to do with the temperature changing - CTS is my vote, too. Is the oil pressure ok during those 1st few minutes?
