Are these gaskets for an ea82T?
The metal gasket is for the EGR dealio, as is the little one with the hole in the middle and I have no clue what the big loopy black one is, the upper right one is for a mpfi Turbo with the normal manifold, and the bottom 2 are for Spider intake manifold.
-Bill
dude, i've never seen anything like that rubber black one. crazy looking thing.
the XT throttle body gaskets i've seen are the paper/cardboard-ish style, what years/models would that go on?
the two bottom gaskets are upper intake manifold gaskets, they don't sit on the heads.
(at least on some engines - like MPFI spider) the intake manifold assembly is actually two parts, there's a runner on each side between the heads and the rest of the larger intake assembly. these "UPPER" gaskets are for between those two parts.
whereas the one on the top right is a lower intake manifold gasket that sits right on the head.
all of those intake manifold gaskets fit an 87.5 XT MPFI with spider intake.
the tiny little gasket there looks like the gasket that goes on the bottom of the turbo for the oil return pipe. at least from here, lol.but yeah, the other guys pretty much hit the nail on the other gaskets.
I think the weird looking rubber one goes under the single point throttle body.
