February 17, 200917 yr I don't even know how to explain how I feel right now. My xt6 is doing things I and I can't figure it out.... I'm pulling my hair out... its cutting out while driving i.e. rpms are climbing but like there is no power then bam it hits me the back of my seat rest because I had to floor it. to get it up to speed... and it only does it once its warmed up. the only codes I pull are 35. I don't know... Anyone want an xt6? ive got $2500 in this in reciepts....
February 17, 200917 yr well if you are really serious about gettin rid of it and not stickin to it let me know if your willin to part with some parts from it but i would stick with it if you can finacially i know it sucks right now cus im in the same boat. my toyota mr2 has been sittin for a year cus of various problems but i work on it when i can and i think i may have finally fixed the things that are wrong with it so theres always some hope and theres plenty of ppl on here that have the knowledge to help u with what you need
February 17, 200917 yr I'm not sure what a code 35 is, but it sure sounds like you have a fuel problem. I assume you've already changed the fuel filter, but what about the pump? Had the injectors cleaned?
February 17, 200917 yr Author its doing the same thing it did when i bought it. crap in the tank ( I think ) I did a filter and the gas looked clear but it didn't seem pressurized.and the pressure shouldn't back down should it? cause it had been off since I got to work.... I have already replaced the CTS and the Purge Control Solonoid (thats the code 35) but it still pulls it. is it possible the pump is going out and not giving me enough psi
February 17, 200917 yr It sounds like a classic case of insufficient fuel delivery -- my Justy does that when it's low on fuel and sucking air -- it'll cut out on corners... then cut back in just as suddenly. A new fuel pump might be good to try, if the filter and all looks good. My truck does that same behavior when the filter clogs -- surging and cutting out -- tank was full of rust. I wonder if you might have run too much dirt through the pump and damaged it (depending on how bad the fuel tank was).
February 17, 200917 yr Author Well it lasted it a exactly a year if it was the crap in the tank... I'm gonna get a fuel pump if I have one at work today to put in tommorrow.. and I'll drop the tank... but the thing I don't understand is that it doesn't do it until it warms up.... But the other thing is that when i did the fuel filter I was expecting to get fuel spray.. I didn't just kinda drip drip pour and the gas looked clean... no color tints to it at all...... Any More Ideas?
February 17, 200917 yr Well it lasted it a exactly a year if it was the crap in the tank... I'm gonna get a fuel pump if I have one at work today to put in tommorrow.. and I'll drop the tank... but the thing I don't understand is that it doesn't do it until it warms up.... But the other thing is that when i did the fuel filter I was expecting to get fuel spray.. I didn't just kinda drip drip pour and the gas looked clean... no color tints to it at all...... Any More Ideas? Hmmm. I'm thinking an intermittent wire to something in the ignition system maybe (even the fuel pump, but could also be the coil or MAF or whatever....) ????? That sounds like it might be more temp affected than the fuel pump would be. Still doesn't quite sound like it though....
February 18, 200917 yr Author Good news.. I think its just a case of extremely bad gas because I'm almost to e now after putting in $20 in premium and a can of heet. because now its idleing ok, and its not as bad as it was... so Tomorrow I'm gonna work on my legacy for a few hours and then I'm dropping the tank... And I'm gonna clean it out... and check the pump... What I'm thinking is the filter/screen that is in the tank will suck up all the sediment/crap after a little while of driving and then when I shut it off it and the sediment/crap will drop down and allow me to drive ok when it starts.
February 19, 200917 yr mine only runs on premium does anyone else have that problem. it cuts out when you put regular in. We changed the fuel filters thinking it was dirty gas but they were clean.
February 19, 200917 yr Author I have had no problem up until this using ARCO regular gas... This was a ************co 711 gas Station... in Vancouver washington...
February 23, 200917 yr Author may Have found the Unicorn... A Xt6 with Working Air suspension for 250 It just needs a motor And I have a good one of those... the unfortunate part is its an Auto Tragic.... The air suspension is still aired since the last time he drove it 3 months ago... the back is sitting a little low but we threw a battery in it and it came right up with key on...
February 23, 200917 yr I have had no problem up until this using ARCO regular gas... This was a ************co 711 gas Station... in Vancouver washington... I just heard a report on King 5 news tonight about bad gas in WA. So far this year, they already have 16 complaints compared to 50 last year. It has to do with the ethanol blend. http://www.king5.com/localnews/stories/NW_022209WAB-bad-gasoline-SW.3fb46030.html I was a victim of this last month in my RX and I know of someone else whose car is sitting right no because of it. may Have found the Unicorn... A Xt6 with Working Air suspension for 250 It just needs a motor And I have a good one of those... the unfortunate part is its an Auto Tragic.... The air suspension is still aired since the last time he drove it 3 months ago... the back is sitting a little low but we threw a battery in it and it came right up with key on... Just what you need, another POS project! Edited February 23, 200917 yr by Turbone
February 23, 200917 yr Is condensation a possibility? Water can condense on the inside of the fuel tank overnight, and being heavier than fuel will sink to the pump pickup area after a little bit of sloshing around.. Could *possibly* explain why it only does it after a little while. Hopefully the new gas solves your problem! Perhaps look into the possibility of water in your fuel, I dont know for sure how you could prevent that, tho.. 88RxTuner
February 24, 200917 yr Author Problem Temporary solved. See http://www.ultimatesubaru.org/forum/showthread.php?p=800861#post800861
