January 16, 200422 yr I was wondering if there is any possible way to get more power out of my 93 Loyale???? also wondering about the possibilities of offroading it??
January 16, 200422 yr Do a search. The subject of getting more power is probably the most common one on this board. Start by cutting out the bottom of the airbox, getting a better muffler, and a hotter ignition. As for offroad, check out http://www.ozified.com for lift kits. If you are serious about offroading, swap in a dual-range tranny from a GL or DL.
January 17, 200422 yr Originally posted by northguy Weber carb. On an SPFI car? More air in .. more air out. Better intake.. better exhaust. For offroading, look in the photos section. More more specific info, do a quick search. theres tons of info here about the questions you are asking.
January 19, 200422 yr I too have a 93 Loyale, and I offroad it in New Mexico and Colorado, up to 12,000 feet, so I'm working with A LOT less horsepower than you are, and I'm fine. My power ain't great, maybe I could outrun a bear, maybe not, depends on how mad I've made him. I plan to put in a hotter ignition, not sure on the airbox though. If you plan to offroad, buy good tires, check your driveline often, and have fun. I've NEVER had problems with mine, and I've owned Jeeps before so I know how to off-road.
