March 6, 200917 yr So.............Today Dan and I figured we would change out the water pump since it was leaking, after getting a new water pump from Napa and cleaning the gasket very good and it is leaking down through the t-belt covers at a very good rate. It looks like it is coming out of the bottom of the water pump again, Is the any where else it could be coming from, it has a new gasket, new pump, and tight bolts and hoses................... what else could it be????? Jeff
March 6, 200917 yr Hey Jeff This is Jerry, i am a service tech for case heavy construction and i see bran new parts be just as bad as the old part. Thanks Jerry
March 6, 200917 yr Author Where did you source the waterpump from?nipper Its one of those Napa brand new ones............. Jeff
March 6, 200917 yr did you check the pump thouroghly before installing it? i once had a pump that when i installed it pushed more water out of it than the old one. the little holes on the top and bottom that open up when it goes bad where those closed off?
March 7, 200917 yr Author The only thing we didn't check was the water pump itself, but that seems real hard to belive that it, being new, would leak the same way as the old one, I guess we'll have to dive back deep into the EA82 and see WTF. Kinda of a bummer considering where it is located...........:-\ Jeff
March 8, 200917 yr Author It might have a weep hole issue.? Thats what it was on the old one but this one seems to have water running running more freely, to the ground. Jeff
March 9, 200917 yr Author Well the battle has come to and end................ the gasket was folded over and causing it to leak mess load everywhere. The mystery is over.... it was the Gasket. Jeff
