Bolt-in EA series Alternator upgrade. Nissan Maxima alt installation guide.
  • Replies 231
  • Views 66.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Ok, I don't know why this is still going on. You want to believe stereo competition rules for wiring accessories on your car? Go for it. They don't have a damn clue about the overall system I guarante
  • Take any size wire you want, wire it to a car battery, short it directly and see what happens. I did read the link. They are talking load protection, not short circuit protection and while the two are
  • GeneralDisorder
    GeneralDisorder
    EA81's are factory with 50 amp alts, EA82's are factory with 55 amp alts. Most replacement EA81 alts are actually EA82 alts though so pretty much all of them are 55's by now.   The stock units don'
This looks to be the best way around the crappy stock alt.
Thanks for the info! My '84 GL will be getting this setup. :banana:
Question though, did I read correct that the factory (ea81) harness can be modified to plug into this Maxima alt, or do you need a bit of harness from a junkyard Maxima?
Thanks!
Yes - if you pull the spade connectors out of the plastic connector on the EA81 harness they can just be slipped onto the Maxima alt male spade's.
  • 2 weeks later...
so i did this over the weekend, works fine but for some reason i cant get the pulleys to line up right even after grinding the spacer i cant really figure it out is there something im missing?
Do you mean it wobbles or do you mean the position of the pulley compared to where it needs to be in line with the belt is off?? Got a pic? Mine was basically straight swap but it still wobbles a tad because we couldnt get the spacer perfect.
its still sticks a taad to far out in relation to where it needs to be idk why but its starting to get annoying:mad:
Pics would help. A slight missalignent with v belts is not a big deal. They will handle quite a bit. That said - I would need pics of your setup to further advise.
  • 3 weeks later...
GD, or anyone else that might know...
Ive got a reman 90A Maxima alt in the mail to do this swap, but Im unsure of what pulley I need.
Im concerned about the double pulley rubbing the AC belt.
What pulley would work?
Thanks for any help:)
To repeat what GD said, "You can use either pulley, you just have to grind the spacer until the belt is properly aligned."
It may not be exact, but it's easier than hunting it down and quoting it.
Twitch
Yep - you can use that EA81 pulley. That will look great in there! What a nice engine bay! Please post a pic when you get it installed....
woah... what?
I can use the pulley I have?
Sure - zip it off there and make your spacer to fit that pulley. The spacer will be a little shorter than in my pics.
Sweet!
Thanks dude. :headbang:
Ill post a pic when its in. It should be here this week.
I look forward to swapping out the POS stock unit. It cannot even handle the heater fan on high and the high beams, at idle. :rolleyes:
Success!
Nabbed a reman alt off of ebay for $70 shipped to my door.
Works great!
Idle with no load, 14.38V
With high beams, fog lamps, heater fan on full blast, at idle Im seeing 12.8V :clap: Lights BARELY dim when the revs come to idle.
A few tips...
* I found the optimum spacer thickness to be 11mm. I used an end wrench to keep the thickness true as I was grinding the factory spacer down. To do the grinding I put the spacer in a vice, and used an angle grinder. I finished with a bench mounted belt sander.
* The round battery lead connector had to be opened up to fit over the stud on the alt.
* I didnt like how the spade connectors connected to the alternator on the top. Moisture collection was my concern. I made a foam rubber cover to fix the problem. Just a small rectangular bit, with a cut in the middle to allow the wires to pass through.
Rock on! :headbang:
Edited by Idasho
  • 8 months later...
reviving this important thread. bummed that the pics from GD's original post are gone. IIRC, they were useful and relevant.
also, i'm preparing to do this swap for my 88 GL with power steering/no AC
GD - are you still supplying these units?
Yeah - I can supply you with one. Just PM me the details.
Pics were hosted on my old internet provider's native hosting - they sucked and I switched to fiber so those addresses are gone - sadly I cannot update the posts in this thread to rehost he pictures with Picasa because the post is too old and won't allow me the edit option. Perhaps a mod can do something about that.....
sending a pm....now that i have 10 posts.
Edited by kona
Probably easier if you could repost them here and we can cut+paste them to the original.
  • 1 month later...
OLD THREAD QUESTION.
is the body the same size on these things?
tried to drop one in my XT and the body was HUGE. didn't fit at all.
picked up a reman 87 nissan maxima 3.0 SOHC alt. did i screw up?
Same size as the OE alt on my '84 GL
Only difference as far as the case goes is the harness connection location.
  • 3 weeks later...
I see thay generaldisorder said that the nissan alt would work from an 87 to 94 maxima. My question is, is the alternator the same from a 96 maxima. I looked at oreilly's autoparts website and the looked the same. I was just looking for conformation on this. thanks for the input ahead of time.
It's not the same in the '95+ Maxima - the dimensions are slightly different and it's a 95 Amp instead of the 90 of the older Maxima's. You can (I have) make them fit with some modifications to the brackets and the pulley swap I do still works on them. Not worth it for the extra 5A IMO.
