RenaissanceMan Posted June 21, 2009 Share Posted June 21, 2009 so on my 86 I got the long block put back in. I have a timing kit for it, and I was planning on running w/o covers on the engine like I did my last ea82 (years and years ago). Today I got some inspiration and putzed around a couple junkyards. After I got thru 6 subarus, I finally found a set of timing covers where all the bolts loostened without breaking the rear covers . I believe they came free like they were supposed to because they hadnt been overtightened by anyone since the day it left the factory, as it still had subaru timing belts on it (at 200K too!!!). SOOO question is.. what prep do you guys use to make sure these dang bolts dont sieze in the covers?? I was thinking about barely tightening the bolts and drilling them for safety wire so they dont come out. -Mike Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 21, 2009 Share Posted June 21, 2009 Don't install the outer cover bolts - just use zip-ties. GD Quote Link to comment Share on other sites More sharing options...
Scoobywagon Posted June 21, 2009 Share Posted June 21, 2009 A little anti-seize goes a long way. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 21, 2009 Share Posted June 21, 2009 Anti-seize isn't enough for those silly things. Zip-ties are easier, quicker, and you know they will come off. GD Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 22, 2009 Share Posted June 22, 2009 I dunno, a little packing/Bearing grease works just fine. Zip-ties tend to crack from hot/cold.. Or just spray some deep creep on them from time to time. Mine came off easy when I did all that stuff last july (Had Subaru belts too!) -Tom Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 22, 2009 Share Posted June 22, 2009 *quality* zip ties don't have that problem. And if you periodically check the belt tension then you are replacing them every 10k or so. Don't buy the chinese zip ties. GD Quote Link to comment Share on other sites More sharing options...
RenaissanceMan Posted June 22, 2009 Author Share Posted June 22, 2009 thanks for your thoughts people. In the past I have always used zip ties when covers start breaking. -Looks ghetto but works. Like I said I finally managed to come across a set of non-broken timing cover pieces, so I am interested in being able to use the threaded holes. I'll let you know what formula I come up with, though I wouldent be suprised if these damn things siezed and broke anyway... SOMEBODY out there needs to make cast aluminum versions of these things. Quote Link to comment Share on other sites More sharing options...
NorthWet Posted June 23, 2009 Share Posted June 23, 2009 The zip-tie method sounds interesting, but I haven't tried it...yet. What I have done in the past is cheat. I got longer bolts (all thread, no shoulder), nylock nuts and flat washers (all SS, IIRC). I threaded the bolts (with some locktite) through the rear of the back covers so that they stuck forwards. You can then slide the front covers over them and secure the covers with the flat washers and locknuts. Strain can be taken off the cover nut-inserts by using a wrench on the bolthead. Maybe complicated and overkill, but looks fairly neat and practically guarantees that the covers can be easily removed. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 23, 2009 Share Posted June 23, 2009 *quality* zip ties don't have that problem. And if you periodically check the belt tension then you are replacing them every 10k or so. Don't buy the chinese zip ties. GD Lol thats very true I guess replacing the ties every 10k where you check the belts would also keep them from breaking (Didn't think about that) Hmm, Cast-Aluminum covers? That'd be cool. Quote Link to comment Share on other sites More sharing options...
torxxx Posted June 23, 2009 Share Posted June 23, 2009 buy the actual "zip tie" brand. if they dont have the metal locking clip inside the end, they arent the real ones. these are very strong, I've held together a lot of things on snowmachines and 4 wheelers with these and they rarely break. And then when u need the do t-belts on it, u can just take a exacto knife or a carpenters knife and a quick flick the covers are off Quote Link to comment Share on other sites More sharing options...
