August 9, 200916 yr anyone know of a company that has or does a molded replacement carpet for the early 80's models ?
August 9, 200916 yr I wish I knew. My hatch's carpet has had dozens of cups of coffee spilled on it. Fairly gross.
August 10, 200916 yr Well I just have a carpet I pulled from a GL thats so so. Will some rubber undercoating stick to the bottom of it?
August 10, 200916 yr I heard, the carpet is flat then streched barely under the rear seats on the tunnel, more from passengers and wear. Someday I hope to know for sure. I have to get my interior finished after my ej swap. I'll be watching if your posting. Edited August 10, 200916 yr by Yo'J
August 10, 200916 yr I have a 83 gL wagon. I just replaced the front section from JC whitney. It is only available for a brat. It is the same floorpan and tunnel or it sure fits like it is. The rear sections I color matched locally for 11 bucks a yard. I have the rear section done and I just need to finish the seam under the rear seat where the foot well meets the seat. It is all new and looks great. I just got busy and need to finish that last detail. I'm just having to much fun driving it. Here is a shot after getting most of it in. I put new padding in after I coated the entire lower body with a noise canceling product. The previous owner won't recognize it. The fronts side by side. You think your carpet was gross. LOL...
August 10, 200916 yr A local company makes carpets for these, friend of mine has his done in his 88 GL Wagon but it was pricey around $200.
