outbackusjunkus Posted August 27, 2009 Share Posted August 27, 2009 '97 Outback...got a great deal on a '96 2.2 to replace the now deceased 2.5. Problem is, 2.2 is out of a MT car, so no EGR. I know this has come up before, but searched and found nadda. Anyone know how to keep the CEL light from coming on...bypassing the EGR? Should be able to put a resistor in somewhere to fool the computer...anyone know how this can be done? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 27, 2009 Share Posted August 27, 2009 i have never seen any complete information on this question. suggestions, ideas, and pointers, but nothing specific. i have a non-EGR swapped Ej25-Ej22 (essentially) as well. i just don't care about the light and the state doesn't either. Quote Link to comment Share on other sites More sharing options...
outbackusjunkus Posted August 27, 2009 Author Share Posted August 27, 2009 Hmmm...somebody has to have figured this out by now....I know it doesn't hurt anything but don't want that light on.... Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 27, 2009 Share Posted August 27, 2009 Is it possible for you to get your hands on the ECU from the car the engine came out of? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 27, 2009 Share Posted August 27, 2009 (edited) That's what I've always wondered and I've brought it up before. You can find the old threads and see what folks say, but I don't think it was anything definitive. It may even be that the ECU's aren't actually different. I've always thought that messing with the EGR is the wrong way, why not make it think it's one of the "non-EGR" vehicles. But, I've asked before and it doesn't seem like anyone knows the magic formula. The ECU issue is that almost all non-EGR 1995+ ECU's are manual transmissions. So if you have a manual trans that might work. If you have an auto you're hosed. Although I did own a 1997/8 Impreza OBS EJ22 without EGR that was an automatic. DANG IT I wish I would have known back then about this and I would have taken the ECU. The intake manifold (non-EGR) is the one currently in my Legacy LSi, so i'm absolutely positive it was a non-EGR automatic. Good luck ever seeing one of those again. Edited August 27, 2009 by grossgary Quote Link to comment Share on other sites More sharing options...
outbackusjunkus Posted August 28, 2009 Author Share Posted August 28, 2009 It is a manual trans car, but the donor vehicle is long gone. So what year ECU should I look for...maybe a '95 legacy with MT? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 28, 2009 Share Posted August 28, 2009 It is a manual trans car, but the donor vehicle is long gone. So what year ECU should I look for...maybe a '95 legacy with MT? Cool, I would try exactly that. But, it might not be as simple as swapping ECU's. Often the ECU's can run either car, they are "looking" for inputs and pins that tell them what the car is. That's why you can interchange ECU's between auto and manual vehicles - the ECU 'knows' what it is and can run either by identifying it. Same thing could happen here - you install a "nonEGR" (so you think) ECU into your car, but then it "sees" that yours is an EGR equipped vehicle so it still throws the code. That being said, it's worth a shot since the ECU is so easy to replace. Any 1995-1998 EJ22 ECU would be fine. Just make absolutely sure it doesn't have EGR. A 1995 Manual should be a sure bet, assuming the ECU's are interchangeable. For some reason I feel like I got a 95 ECU and it was different plugs, but I might be mistaken. Someone will pipe up an verify that. Quote Link to comment Share on other sites More sharing options...
dhise Posted August 28, 2009 Share Posted August 28, 2009 I have a '96 ej22 in my GL. It was throwing an egr code before I grounded the pin that told the ecu that it was supposed to be for a manual tranny. Afterwards, no code. So for the 96's the ecu's should be the same for manual and auto transmissions. You just have to let it know which one you have. As far as 97's go, I have no idea. -Doug Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 28, 2009 Share Posted August 28, 2009 GAH - post that pin number please!!!! Quote Link to comment Share on other sites More sharing options...
dhise Posted August 28, 2009 Share Posted August 28, 2009 For the 96 ecu the AT/MT identification is pin 81. On the 96 wiring harness it is a black wire with a white stripe. It needs to be grounded to tell the ecu that it is a manual. Before I did this it had the egr code and a auto trans diagnostic code (1702 I think) because it was looking for the auto tranny that wasn't there. It also cured a high cold start idle (2500 rpm) and made that function normally as well. Hopefully some of this is relevant to his '97 model. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 28, 2009 Share Posted August 28, 2009 Hopefully some of this is relevant to his '97 model.yep, i bet it's identical. the engine and trans in 96 and 97 are completely interchangeable and swappable, plug and play. wire color should be the same but if it's not the pin number certainly is. thanks. Quote Link to comment Share on other sites More sharing options...
outbackusjunkus Posted August 30, 2009 Author Share Posted August 30, 2009 (edited) Awesome. An easy fix like this is what I was hoping for. Pulled the engine last nite, looks like it'll need a clutch too, so it'll be a week or two before I have the parts and time to reassemble. Thanks for all the help, I'll follow up once everything is up and running... ...edit...wait a sec...this is a manual trans car...engine is also from a manual trans car...don't see how grounding the ECU is gonna help in this case...since this manual trans car is supposed to have an EGR... Edited August 30, 2009 by outbackusjunkus Quote Link to comment Share on other sites More sharing options...
bartw_portland Posted September 30, 2009 Share Posted September 30, 2009 one note to add here. i swapped in a 1995 ej22 into my 1997 5spd outback (removed ej25). i attempted to start the vehicle with the 1995 ecu in place and could not. didn't investigate why but put the 97 ecu back in for an immediate start. Quote Link to comment Share on other sites More sharing options...
screwbaru2 Posted October 1, 2009 Share Posted October 1, 2009 My 97 OB 2.5 MT has an egr. I had to use a head from a 2.2 out of a AT when I did the swap. Worked fine no CEL. Quote Link to comment Share on other sites More sharing options...
themoneypit Posted December 7, 2009 Share Posted December 7, 2009 i am in the same boat here.. 97 obw 5spd man trans 2.5l w/egr is coming out, non-egr 2.2l is going in. i have the entire car, so should i swap ECU or not. how do you count the pins to know which one is 81?? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 7, 2009 Share Posted December 7, 2009 i have the entire car, so should i swap ECU or not. you can but that won't get rid of your CEL's. and then ground the pin and you're still going to have issues because you have an automatic transmission. that further confuses it. unless you swap the manual trans in then of course you're fine. Quote Link to comment Share on other sites More sharing options...
bartw_portland Posted December 7, 2009 Share Posted December 7, 2009 I did a quick review of the wiring schematic looking for diffs between a 1995 EJ22 ecu and EJ25 ecu hookups. I saw that there were several diffs that would make a big difference and explained the fact that, when i installed my 95 ecu in the 97 outback with 1995 EJ22 installed, I got a nostart condition. So.....don't think that installing the ej22 is going to work with you folks either. I've also played with introducing a signal back to the 97 ecu by introducing 12 volts with a resistor to knock it down to about 5. Still got the cel. In reading more about the issue, the computer is also looking at sensors that would indicate that the egr is allowing hot exhaust gases back up into the intake (via the tube that WAS installed on the ej25 head/intake manifold). If it doesn't sense that the exhaust is being allowed back up into the intake, it throws a cel. I'm still not certain whether there is a negative affect on how the vehicle runs tho. My ej22 runs pretty well at idle. But when cold i get a bucking unless i raise the revs when in lower gears. I also don't get the gas economy that I was hoping for. I'm leaning toward drilling/tapping the rear side of the ej22 head to allow installation of the egr tube. ps: if anyone is interested in taking a look at the wiring diagrams i'm referencing, have a go... http://www.weidefamily.net/vanagon/Pending_Content/Engine_Conversion/Reference/WiringDiagrams/ brent Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 7, 2009 Share Posted December 7, 2009 Is it not just an EGR temp sensor? There should be a +5v signal from the ECU going to some kind of thermistor that tells the ECU there is exhaust gas flow through the EGR. Take that signal, run it through a relay controlled by the signal to the EGR solenoid, then through two 5 watt resistors that simulate the voltage drop in the 5v line both with/without EGR flow (so the ECU see's the temp change when it shuts off the EGR vacuum supply). The ECU isn't that smart - it's looking for a temp change in the EGR passage when it opens the EGR solenoid. Find out the proper resistances that the thermistor generate's at typical EGR temps and give the ECU the signal it wants. GD Quote Link to comment Share on other sites More sharing options...
bartw_portland Posted December 7, 2009 Share Posted December 7, 2009 I would have thought that an egr temp sensor would be present. But...I've looked all over the wiring diagram and can't find anything. If anyone else knows of the presence of this type of sensor, and it's wiring pins to the ecu or other, please let me know here. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 7, 2009 Share Posted December 7, 2009 i installed my 95 ecu in the 97 outback with 1995 EJ22 installed, I got a nostart condition.that would only be for 95 model years - all EJ25 DOCH vehicles will run just fine with an EJ22 ECU from 1996-1998, completely interchangeable. Of course all the EGR and auto/manual items still apply. Quote Link to comment Share on other sites More sharing options...
themoneypit Posted December 8, 2009 Share Posted December 8, 2009 ok cool, so i should be good to go. my car is 97 OBW 5spd, so the 96 2.2l 5 spd ecu, with pin 81 grounded should hopefully make me CEL FREE thatd be sweet!! Quote Link to comment Share on other sites More sharing options...
outbackusjunkus Posted December 8, 2009 Author Share Posted December 8, 2009 (edited) FWIW...this car is now up and running with the '96 2.2 (w/o egr). the car ('97 OBW) is throwing the egr code but runs fine. I've done some more research, found a guy who swapped in another non-egr computer but it still threw the code...he ended up splicing the sensor into his wiring harness (just before the engine, as the new intake does not have the wiring for egr). its the two wire sensor that's on the intake of the egr motor, next to the egr valve. that cured his problem. i'm planning on doing the same...maybe this weekend when i pull the engine back out to fix leaky head gaskets (i know...2.2's aren't supposed to do that...but my 2nd used 2.2 in a row with bad head gaskets). I'll stop back with the result. Edited December 8, 2009 by outbackusjunkus Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted December 8, 2009 Share Posted December 8, 2009 FWIW...this car is now up and running with the '96 2.2 (w/o egr). the car ('97 OBW) is throwing the egr code but runs fine. I've done some more research, found a guy who swapped in another non-egr computer but it still threw the code...he ended up splicing the sensor into his wiring harness (just before the engine, as the new intake does not have the wiring for egr). its the two wire sensor that's on the intake of the egr motor, next to the egr valve. that cured his problem. i'm planning on doing the same...maybe this weekend when i pull the engine back out to fix leaky head gaskets (i know...2.2's aren't supposed to do that...but my 2nd used 2.2 in a row with bad head gaskets). I'll stop back with the result. to make this process easier, should you use the wiring harness from the egr engine and then connect the sensor, with the egr car's computer of course. Quote Link to comment Share on other sites More sharing options...
outbackusjunkus Posted December 21, 2009 Author Share Posted December 21, 2009 to make this process easier, should you use the wiring harness from the egr engine and then connect the sensor, with the egr car's computer of course. Thought about that, but went the easy way. Spliced in that two wire senser off the 2.5 EGR into the wiring just before the engine and bingo...no more light. Its been a couple days now and the light has stayed gone, so looks like problem solved. Yay... Quote Link to comment Share on other sites More sharing options...
themoneypit Posted December 21, 2009 Share Posted December 21, 2009 Thought about that, but went the easy way. Spliced in that two wire senser off the 2.5 EGR into the wiring just before the engine and bingo...no more light. Its been a couple days now and the light has stayed gone, so looks like problem solved. Yay... which wires on the main harness do you use to splice it in?? colors, etc... or a pic would be even better Quote Link to comment Share on other sites More sharing options...
