September 1, 200916 yr 1996 Legacy the fuel filler pipe is in decent shape but has a small pin hole in it. What say ye about repairing it? Doesn't look worth replacing to me. I've already wire brushed, treated, and painted it. Now to plug the hole?
September 1, 200916 yr JB weld, fuel tank repair epoxy. You could even solder/braze a patch on if you're really good with a torch. JB is quicker though.
September 1, 200916 yr JB weld, fuel tank repair epoxy. You could even solder/braze a patch on if you're really good with a torch. JB is quicker though. IMO soldering/brazing on the neck of a gas tank with a torch is a bad idea. Just too easy to cause an explosion from the gasoline fumes.
September 1, 200916 yr Author yeah i thought about welding....for 2 seconds. i forgot to mention it's still on the car. i'll look for fuel repair stuff or JB weld if that's not available. probably very similar to each other anyway. low stress, low heat, should be simple.
September 2, 200916 yr IMO soldering/brazing on the neck of a gas tank with a torch is a bad idea. Just too easy to cause an explosion from the gasoline fumes. I never said to do it while its on the car. :-p Although if you filled the tank with gas all the way to the very top of the tube you could. (maybe)
September 2, 200916 yr 2000 OBW, 130,000 I have been wanting to do some prevent maintenance on the fuel fill pipe. My tech told me to clean it and spray undercoat on it. I'm not much of gearhead and I am having a hard time getting to it. Can someone tell me how to get at it properly? Maybe some illustrations? Thanks in advance Lefty
September 2, 200916 yr Today's lesson on welding a gas tank will be dropped. No need to kill anything or someone.
September 2, 200916 yr Author it's really easy to get to - remove wheel, remove plastic cover. it's REALLY simple.
September 2, 200916 yr I never said to do it while its on the car. :-p Although if you filled the tank with gas all the way to the very top of the tube you could. (maybe) Todays 'don't do this but it's safe': I had a 1983 yamaha Seca 900 (XJ900RK) and there was a chunk of gas tank space that was not usable because a collar extended down into the tank, with a very small bleed-hole at the top of the collar. If you filled up beyond the bottom of the collar, you had to drip the gas in because the bleed hole was so small. I decided to drill the bleed hole larger, so of course the question is- 1) remove tank and purge of fumes 2) do it on the bike, tank with only a little gas in it 3) do it on the bike, filled up all the way I'm too lazy to take the tank off the bike, so obviously I did (3). Dave
