Shudders when stopped at lights
36 replies to this topic
#1 Chip
Chip
    USMB is life!
  • 162 posts
  • Canada
Posted 04 March 2004 - 03:20 PM
My 98 O/B (Automatic), shudders whenever I'm stopped in drive with my foot on the brake. It's so bad that when I stop at a light I put it in neutral...which stops the shuddering. It almost feels like the Idle speed is too high but when I put it in neutral it's fine.
Is there some kind of tranny adjustment which can be done ??
#2 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,955 posts
  • Texas
Posted 04 March 2004 - 04:12 PM
your symptom seems unusual for 'torqu bind' but it may still be useful to use the FWD fuse under the hood and see if the symptom goes away.
#3 Rooskie
Rooskie
    USMB Regular
  • PipPipPip
  • 39 posts
  • Idaho
Posted 04 March 2004 - 05:06 PM
What do you do to the FWD fuse? I have the same prob on a 98 OBW Auto.
#4 Commuter
Commuter
    Subaru Master
  • 1,857 posts
  • Niagara area, Ont Canada
Posted 04 March 2004 - 05:44 PM
Check your mounts too. Especially the tranny one.
Commuter
#5 remarcable
remarcable
    Elite Master of the Subaru
  • 6,061 posts
  • South Carolina
Posted 05 March 2004 - 02:43 AM
What does the RPM gauge say? If I recall it should be at 500rpm in neutral without the AC on.
#6 charlierh2
charlierh2
    USMB is life!
  • 168 posts
  • Minneapolis, MN
Posted 12 March 2004 - 12:33 AM
if you read in the owners manual puting a 20amp fuse in the FWD holder (on top of the right wheel in 97 legacy) your in front wheel drive to protect your AWD system when you haev a flat. this woudl rule out probs with the AWD System in the rear
#7 Tiny Clark
Tiny Clark
    Certified Subaru Nut
  • 807 posts
  • Germany
Posted 12 March 2004 - 01:04 AM
If it stops as soon as you lift your foot off the brake, you may have a vacuum leak.
#8 duane b
duane b
    USMB Regular
  • PipPipPip
  • 71 posts
  • Northwest
Posted 12 March 2004 - 01:29 PM
My 96 Legacy Wagon w/ 4eat does the same exact thing. It only does it at a stop in drive doesn't matter whether it's cold or warm. In Neutral it purrs like a kitten. I've recently had Subaru do a tranny service which help with the shifting but not the shudder vibration. I've heard this can be caused by low or old tranny fliud but that's not the case anymore. How can you tell anything by lifting your foot off of the brakes? The car starts moving and the shudder goes away. As soon as you stop again in drive it starts vibrating again. A vacuum gauge would be the best bet. Is this a commen problem?
#9 Tiny Clark
Tiny Clark
  • 807 posts
  • Germany
Posted 12 March 2004 - 03:51 PM
How about pulling up the hand brake, then pulling your foot off the brake?
#10 Howsci
Howsci
    New User
  • Pip
  • 3 posts
  • Richmond, VA
Posted 12 March 2004 - 09:20 PM
It sounds like you have the exact same thing as my 96 auto legacy. I thought it was kind of weird/annoying when i bought and took it to subaru to check it out. supposedly it's the front axle shafts being slightly to much in or out of tolerance. As far as subaru new it had no ill effects except for the vibration you feel. It will go away supposedly if you change your half shafts BUT you can't buy remanufactured ones you have to buy the replacement ones they make ( don't know the part #, sorry) But it's just supposed to be only the front axles that have the problem.
-Mitch-
#11 cookie
cookie
  • 3,058 posts
  • SFO
Posted 14 March 2004 - 12:28 AM
disconnect the line and plug it. Then get in the car and try it. Don't drive it more than at a couple MPH to test. If it is a leaking booster this should show you because the car would run fine.
#12 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 14 March 2004 - 12:53 AM
2nd vote for front axles.
#13 Ranger83
Ranger83
    Subaru Nut
  • 740 posts
  • Northeast
Posted 14 March 2004 - 10:11 AM
We had two 97 OBW.
One shudders at a light.
The other doesn't.
As the one that does always got 1-2 mpg better mileage than the other and now has 130K with no problems, I don't worry about it.
#14 duane b
duane b
    USMB Regular
  • PipPipPip
  • 71 posts
  • Northwest
Posted 14 March 2004 - 02:04 PM
Boy these are weird friggin cars. :madder: How would an axle shaft affect a vibration when the car is sitting still? The only thing in motion is the motor and the torque converter, right? Let's just say it's not a vacuum leak, wouldn't it still be from either the engine or the torque converter? Just trying to isolate the culprits. Does anybody have this problem with a 5mt?
#15 cookie
cookie
  • 3,058 posts
  • SFO
Posted 14 March 2004 - 05:46 PM
it would make you think it is brake related.
The only vac component in the brakes is the booster. If he uses the emergency brake instead and it does not do it the booster is fine.
No it cannot be the axles as they are not in motion at a stop. Needs more testing.
#16 myles
myles
    USMB is life!
  • 169 posts
  • New York
Posted 14 March 2004 - 06:39 PM
Strictly speaking, when the car is at a standstill with the brakes applied (with the slush box in gear), the axles are held fixed at the wheel end _only_. The trans. is still trying to turn the other end, right?
#17 cookie
cookie
  • 3,058 posts
  • SFO
Posted 14 March 2004 - 07:39 PM
the clutches taking up if the RPM was on the exact engagement point, but this should be the same weather you have emergency brake on or foot brake on.
This is another problem where you could make a heck of a lot more progress with the car right in front of you.
#18 WANTONSOUPGUY
WANTONSOUPGUY
    USMB Regular
  • PipPipPip
  • 31 posts
  • Southern New England
Posted 09 October 2005 - 02:37 PM
i am so glad to find this post. I replaced a half-axle on the front passenger side and immediately after it started vibrating at a stop with the brake on. Coincidence? I think not. Ran like a kitten before. Now it is driving me crazy messing with idle speed and sensors. BTW...no engine light and idle is at a strict 500 rpm with no problems at all starting. I think I have to go to the Suby dealer. Thanks for the post.
#19 cookie
cookie
  • 3,058 posts
  • SFO
Posted 10 October 2005 - 10:11 AM
do you suppose shudder could be caused by a misphased axle? I have never heard of anything like this and I still have not seen an answer to the question of waht happens if you use the emeergency brake instead. This would at least let out the booster.
#20 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 10 October 2005 - 10:28 AM
Nother possabilty is a leaky power break booster. If it doesnt do it with the handbrake on and the car in drive, i would bet its the booster.
nipper
#21 cookie
cookie
  • 3,058 posts
  • SFO
Posted 10 October 2005 - 10:31 AM
was my first thought, which is why I wanted somebody to try the e brake.
#22 Commuter
Commuter
    Subaru Master
  • 1,857 posts
Posted 10 October 2005 - 02:34 PM
Ditto with my 97 OB.
I replaced the front passenger side half axle in Aug. The work was done by the dealer and it was a Subaru remanufactured shaft. Now I get a bit of vibration when sitting still at a stop (auto tranny). Weird. It is more noticable when the car is cold. I haven't gone back to the dealer. It is not a "bad" vibration, but more than it use to be. Enough to annoy me though. Frustrating.
I too really have a problem understanding how it could be the half-shaft when the car is not in motion, but I have read of this issue several times over the years that I have been on Subaru message boards.
Commuter
#23 cookie
cookie
  • 3,058 posts
  • SFO
Posted 10 October 2005 - 04:59 PM
spirits around Halloween. I really can't see how an axle would affect this. Now the torque converter, or anything else that affected engine speed I can understand. I sure have heard of a lot of folks complaining about odd idle and roughness in Subaru automatics though. Anybody that gets to the bottom of this is going to make a lot of friends.
#24 nipper
nipper
  • 18,195 posts
  • Long Island NY
Posted 10 October 2005 - 05:04 PM
OK lets try this...
You need another person for this (someone who likes you) and water spray bottle. When you can reproduce this condition, spray all the hoses under the hood with wither one. i would start at the power brake booster and work backwards. SPray everything and see if the way the engine runs changes at all. Check arouns the air box, intake hoses etc...
nipper
#25 cookie
cookie
  • 3,058 posts
  • SFO
Posted 10 October 2005 - 05:07 PM
since I have a 5 speed, and all the Subies I have driven execept a brand new rental were five speeds I have never seen this.
