misfires
11 replies to this topic
#1 wesmay
wesmay
    New User
  • Pip
  • 3 posts
  • underhill
Posted 28 March 2011 - 07:05 PM
have a forester 02 with 120,000 started to mis at idle but ran better at 2500 rpm. error code showed 3 and 4 misfire, put on new plugs, Bosch, ran perfect for two weeks then started to run rough at idle again, replaced wires runs good at higher rpms but still idles rough and lacks power. today I checked ohms at coil and show 14 across 1,2 and 3,4. I see that this is not something new but looking for advice. thx.
#2 abdul_hameed
abdul_hameed
    Banned
  • Banned
  • Pip
  • 4 posts
  • Beverly Hills
Posted 29 March 2011 - 05:18 PM
That happened to me too and the dealer told me it was probably a timing problem. They had my car for 2 days and 700$ later it comes out with a new throttle positioning sensor. Might be worth a try.
#3 unibrook
unibrook
    Sube1
  • 508 posts
  • Boston
Posted 30 March 2011 - 09:37 AM
If it only misfires when warm, not cold, and if you have not replaced your front 02 sensor in the last 40k miles....then try replacing it.
#4 markjw
markjw
    Elite Master of the Search Function
  • 828 posts
  • Lacey,Wash.
Posted 30 March 2011 - 09:56 AM
You might try a new fuel filter. A plugged/dirty one will throw a injector mis-fire code.
#5 wtdash
wtdash
    Subaru Nut
  • 1,564 posts
  • N. ID
Posted 30 March 2011 - 11:36 AM
It's been stated on here many times to use OEM plugs/wires, so maybe worth a shot....esp. since it worked for 2 weeks...me thinks the Bosch just didn't like their new home. :)
Try some NGK plugs, and let us know.
GL,
Td
#6 Quidam
Quidam
    1000+ Super USER!
  • 1,622 posts
  • USA
Posted 30 March 2011 - 12:26 PM
GL,
Td
Yea, it worked for two weeks.
"Sometimes the Check Engine Light illuminates because the computer detects misfires. Subaru released an improved spark plug wire set to solve the problem. The ignition coil should also be inspected for carbon tracks or short circuits between the contacts."
#7 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 30 March 2011 - 02:55 PM
wait wait..
What bosh plugs are you using?? i hope its not the platinum plugs.
#8 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 30 March 2011 - 02:57 PM
GL,
Td
loong time ago when I had my forester before I knew better I installed bosh plat plugs in the car.. that car would misfire so much it was beyond stupid.. So I went ahead and swapped out for NGK I think coppers or whatever for the 98MY anyways car ran MUCH better.
#9 987687
987687
    Rally Suby!
  • 4,239 posts
  • Northern Maine
Posted 30 March 2011 - 06:43 PM
Either bosh plats are complete garbage, or they don't like subarus. I put a set in my car (before I knew better) and within two weeks it ran like crap. I was actually 500 miles from home at the time. What fun. Anyway when I got home I pulled the plugs out and they all looked like this.
Nuff said. Use OEM.
Posted Image
#10 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 30 March 2011 - 07:16 PM
Wow never seen that but maybe its the wasted spark setup that makes it run like poo?
#11 wesmay
wesmay
    New User
  • Pip
  • 3 posts
  • underhill
Posted 31 March 2011 - 07:27 PM
Thanks for all the input! Yes I swaped back to NGK a little better put still rough,
runnning Seafoam now fuel filter and o2 sensor are next and looking into OEM plug wires. keep you posted.
#12 987687
987687
    Rally Suby!
  • 4,239 posts
  • Northern Maine
Posted 31 March 2011 - 07:28 PM
A lot of cars use a wasted spark system. It's not unique to subaru.
