subiemech85 Posted April 30, 2004 Share Posted April 30, 2004 that goes between the asv pipe and the head, ea82 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 30, 2004 Share Posted April 30, 2004 Yeah - dealer only I think. Try www.thepartsbin.com GD Quote Link to comment Share on other sites More sharing options...
GLCraig Posted May 1, 2004 Share Posted May 1, 2004 since that's a pretty small gasket, you might try going to the parts store and getting some exhaust gasket material and make your own gasket. Quote Link to comment Share on other sites More sharing options...
ccrinc Posted May 1, 2004 Share Posted May 1, 2004 No, there is no gasket, of any kind including sealer, that goes between ASV plate and head. The exhaust manifold gasket goes between ASV plate and exhaust pipe however (duh). Emily http://www.ccrengines.com Quote Link to comment Share on other sites More sharing options...
GLCraig Posted May 1, 2004 Share Posted May 1, 2004 No, there is no gasket, of any kind including sealer, that goes between ASV plate and head. The exhaust manifold gasket goes between ASV plate and exhaust pipe however (duh). Emily http://www.ccrengines.com I think you're confusing the EA81 with the EA82. The ASV tubes bold to the side of the heads on EA82s Quote Link to comment Share on other sites More sharing options...
MilesFox Posted May 1, 2004 Share Posted May 1, 2004 it really dont matter. the whole exhaust manifold on my pinto(trashwagon 3) has no exhaust gasket Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted May 2, 2004 Author Share Posted May 2, 2004 it matters because I need to replace the asv with a block off plate, and want to stop the leaks would permatex gold work? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted May 2, 2004 Share Posted May 2, 2004 try hi-temp silicone. i made a block off by cutting the asv tube, and welding a spark plug to the hole Quote Link to comment Share on other sites More sharing options...
WJM Posted May 2, 2004 Share Posted May 2, 2004 you could use the ultra copper. Let it set up until it seems bry to the touch, then bolt it on. whats the asv on an eaxx?? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 2, 2004 Share Posted May 2, 2004 ASV = Air Suction Valve. GD Quote Link to comment Share on other sites More sharing options...
WJM Posted May 2, 2004 Share Posted May 2, 2004 what does it do? Quote Link to comment Share on other sites More sharing options...
