92loyale59 Posted May 29, 2014 Share Posted May 29, 2014 I have heard of people reinforcing the front control arems on ea82 cars befor so i picked up another set si i can beef them up . I was just tring to find some photos of some that have been but u havent had any luck . If someone could post a picture or two of them i would really appreciate it.. Thanks Quote Link to comment Share on other sites More sharing options...
monstaru Posted May 30, 2014 Share Posted May 30, 2014 (edited) If you have to ask, your probably not ready. lol You really need to be some hardcore spoob to add that to the mix. If you are not ready for another fuse. then i would suggest wheeling it until you need that. k Edited May 30, 2014 by monstaru Quote Link to comment Share on other sites More sharing options...
92loyale59 Posted May 30, 2014 Author Share Posted May 30, 2014 ........not the answer i was looking for. I am lifting my car more and am replacing the bushings in a extra set of controlarms i have i dont see why not to beef them up so i dont bend one off road . Does any one have some reak advice on what to do . I have a pretty good idea just eanted a image and maybe some first hand experience on how well they worked. Thanks Quote Link to comment Share on other sites More sharing options...
92loyale59 Posted May 30, 2014 Author Share Posted May 30, 2014 And explain your self more i dont really understand you Quote Link to comment Share on other sites More sharing options...
92loyale59 Posted May 30, 2014 Author Share Posted May 30, 2014 Another fuse? Quote Link to comment Share on other sites More sharing options...
Subruise Posted May 30, 2014 Share Posted May 30, 2014 (edited) I believe what is trying to be conveyed here is a general demonstration of murphys law. Right now the control arms bend as a "fuse". If you beef them up, and by all means look at the welds they come with, something else will bend/brake. Its a cyclical system, same reason you cant drop a 300 hp engine in a stock geo and expect it to live. enough babble, just weld the entire seam, its pretty self explanatory. I dont see much else you can do Edited May 30, 2014 by Subruise Quote Link to comment Share on other sites More sharing options...
92loyale59 Posted May 30, 2014 Author Share Posted May 30, 2014 (edited) Okay sweet thanks that as was my initial thought I just am more of a visual learner so I thought I'd see if anyone had a picture of one Bent so I could see were the week spot was so i can beefed up so I could see Okay sweet thanks that as was my initial thought I just am more of a visual learner so I thought I'd see if anyone had a picture of one Bent so I could see were the week spot was or a beefed up so I could see Edited May 30, 2014 by 92loyale59 Quote Link to comment Share on other sites More sharing options...
Subruise Posted May 30, 2014 Share Posted May 30, 2014 i was tryin to think of a better way but gussets will impede travel. thems the brakes i guess Quote Link to comment Share on other sites More sharing options...
Vegablade Posted May 30, 2014 Share Posted May 30, 2014 Jeff (one eye) tore one of his in half right at this joint. If you beef one up to much you will just end up ripping the mount off the cross member, beef up the mount, tear off the radius rod, beef up the radius rod and mount, then you will just tear off the knuckle. It never ends haha. 3 Quote Link to comment Share on other sites More sharing options...
Uberoo Posted May 30, 2014 Share Posted May 30, 2014 Jeff (one eye) tore one of his in half right at this joint. If you beef one up to much you will just end up ripping the mount off the cross member, beef up the mount, tear off the radius rod, beef up the radius rod and mount, then you will just tear off the knuckle. It never ends haha. BS.At each level you said it takes more and more force to mess up something higher up the fuse chain.With the wheeling a moderate subaru can do,assuming your not a total knob off road you wont break/bend things after you upgrade stuff. My hatch had beefed up radius rods and stock control arms and they held up fine.even after my hatch fell of my trailer at 55 MPH and centerpunched a tree the control arm mounts were not messed up.The entire crossmember was pushed back but the mounts were still more or less fine.The struts were bent to hell,so was the strut towers,and even the steering rack.If your paying attention to your driving offroad there is no way you can cause that much damage to go up several steps of the fuse ladder. If you beef up the control arms you will not bend the mounts unless you let it change your driving style.If you are slow and timid before adding beef,then go full throttle after beefing up parts then anything can happen,but if you still drive the way you did before, the "fuse" gets ironed out so you can go further between breakages. beefing up one part causes more stress to another part true,but the amount of force and effort it takes to bend a stock control arm, compared to bending a reinforced radius rod is significantly higher.Its like hitting a curb at 5 MPH vs 20 mph. If your bending control arms now beefing them up will help,but better driving will help even more. 1 Quote Link to comment Share on other sites More sharing options...
92loyale59 Posted May 30, 2014 Author Share Posted May 30, 2014 BS.At each level you said it takes more and more force to mess up something higher up the fuse chain.With the wheeling a moderate subaru can do,assuming your not a total knob off road you wont break/bend things after you upgrade stuff. My hatch had beefed up radius rods and stock control arms and they held up fine.even after my hatch fell of my trailer at 55 MPH and centerpunched a tree the control arm mounts were not messed up.The entire crossmember was pushed back but the mounts were still more or less fine.The struts were bent to hell,so was the strut towers,and even the steering rack.If your paying attention to your driving offroad there is no way you can cause that much damage to go up several steps of the fuse ladder. If you beef up the control arms you will not bend the mounts unless you let it change your driving style.If you are slow and timid before adding beef,then go full throttle after beefing up parts then anything can happen,but if you still drive the way you did before, the "fuse" gets ironed out so you can go further between breakages. beefing up one part causes more stress to another part true,but the amount of force and effort it takes to bend a stock control arm, compared to bending a reinforced radius rod is significantly higher.Its like hitting a curb at 5 MPH vs 20 mph. If your bending control arms now beefing them up will help,but better driving will help even more. Sweet just what i was looking along with the photo!thanks. I dont already bend control arms i just thought it would be a great modifacation since i am going way bigger tires. It wont affect the way i drive . I agree with ubaroo that it would take way more force to bend the other parts of the car after reinforcing the control arm . I will try to get a picture up as soon as im done with the control arms . Thanks everyone Quote Link to comment Share on other sites More sharing options...
monstaru Posted May 30, 2014 Share Posted May 30, 2014 The point is, you need more experience to tell you where your weak spots are. People break axles in different spots all the time. Not everyone is going to break/bend the control arm in the same spot. Beefing up to much moves your fuse from one spot to the next. Period. 1 Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted May 30, 2014 Share Posted May 30, 2014 Ive slipped tubing over the round rod (radius arm) and welded them up, another factor that helps is tires that are to large so they smash into the fender well, this helps prevent bent radius rods, a small tire with a large lift allows more room so the rod bends before the tire hits the wheel well Quote Link to comment Share on other sites More sharing options...
Vegablade Posted May 30, 2014 Share Posted May 30, 2014 If your paying attention to your driving offroad there is no way you can cause that much damage to go up several steps of the fuse ladder. If your bending control arms now beefing them up will help,but better driving will help even more. Dude calm down. I was just making a suggestion of what could happen as you upgrade each part. This is a pretty safe mod that will add a little strength but isn't going to mean you will never have any issues. I have been wheeling with the NW Washington Offroad group for a few years now and Jeff has been the only one to ruin one in that time. You are usually ok without, but it couldn't hurt. Quote Link to comment Share on other sites More sharing options...
Prwa101 Posted May 30, 2014 Share Posted May 30, 2014 ^ agree with you. Havent ever seen one break but there's no harm in beefing them up so it dosnt happen. Espeshily if you have an extra set like he does to mess around with. PRWA Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted June 24, 2014 Share Posted June 24, 2014 I never had an issue with control arms but I sure banana'd a few radius rods and I caved and tore the firewall/floorpan junction where the radius rod bracket mounts.My lift blocks weren't linked to each other so the additional leverage caused the body to fail. The radius rods and their mounts to the body are where upgrade efforts should be directed. I'd much rather the stock control arm twist when a radius rod bends rather than a rigid boxed arm shearing at the bushing end if a rod bends. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted June 24, 2014 Share Posted June 24, 2014 I never had an issue with control arms but I sure banana'd a few radius rods and I caved and tore the firewall/floorpan junction where the radius rod bracket mounts.My lift blocks weren't linked to each other so the additional leverage caused the body to fail. The radius rods and their mounts to the body are where upgrade efforts should be directed. I'd much rather the stock control arm twist when a radius rod bends rather than a rigid boxed arm shearing at the bushing end if a rod bends. +1 Quote Link to comment Share on other sites More sharing options...
el_freddo Posted July 5, 2014 Share Posted July 5, 2014 What tyre size are we talking here? 33's? I've seen a radius rod bent with a 3 inch lift and 27s - but that was due to "over enthusiastic" driving - and I mean REALLY over enthusiastic!I've been offroading my 3 inch lifted L with 27s for years now without issue, I've never considered the control arm to be an issue. Take things easy and you'll be fine. Drive like you're in the Dakar and you'll be in all sorts IMO CheersBennie Quote Link to comment Share on other sites More sharing options...
