Just bought a 2005 subaru outback wagon 2.5i automatic
Has 155k and is in decent shape.  Looks like it needs HG work and possible a leaky power steering pump and some rear tires or bearings.   Does anyone else know if there are any other good or bad issues with this series as this in new territory for me.
Thanks in advance
It isn't the rod bearings. It's the 7mm oil pumps. Change it out to a 10mm. The rod bearings and even the rods themselves can be found in Subaru's turbocharged model engines where they do not have failure problems because those engines had 10mm pumps from the factory.
Edited by GeneralDisorder
  • Like 1
I use the 11 mm pump . Here is the item # 142251153734 on ebay .   Brand new O.E.  $138 delivered.    Here's the # 131638875556 for the same thing with new bolts and both seals for $154      I buy from this company often, very reputable.
Edited by montana tom
Yup, one electric window not working.  One kinda sticky outside door handle and the interior finish doesn't hold up as well as my 00-04's.   Not bad though, got it for $750.  It will need two rear wheel bearings, head gaskets etc.   But really clean outside and pretty clean inside.
Hey for that price you bet it was worth it.   The 05's are the first year of " drive by wire"  no cable from the pedal to throttle body , (stupid, IMO).  There have been connection issues between the pedal assembly and computer. Unplug it at throttle pedal  , inspect it well then use dielectric grease when plugging it back in. May help.
We are still working on determining the viability of using the 11mm pumps on non dual-AVCS engines. It may be too much flow.
I'll have data soon to determine exactly which pump is best based on temp, viscosity, bearing clearances, pump size, and oil volume consuming devices (turbo chargers, intake/exhaust AVCS, AVLS, etc).
Too big of a pump and you cause the bypass in the pump to open more often and it may be unable to flow enough volume to drop the pressure to a desirable level.
We also want to know under what conditions the oil filter bypass valve will be bypassing. Science.
For now the 10mm pump us the safest bet. It is used all the way up to 14 WRX's.
  • Like 2
GD - which cars have the 7mm pump and what is the number for the 10mm pump?
it says; Subaru: 5 models, 178 variants between 2002 and 2006.
OIL PUMP ASSEMBLY-ENGINE
Part Number: 15010AA290 ; 15010AA260; 15010AA261; 15010AA262
so, I assume all non-turbo models in that range have those numbers stock and they are 7mm
very interesting
looks like the 10mm part number is;
used in 7 models, 275 variants between 1991 and 2009.
Part Number: 15010AA300 ; 15010AA103; 15010AA104; 15010AA105; 15010AA106; 15010AA107; 15010AA108; 15010AA109; 15010AA280
There are multiple part numbers for the 10. Some didn't have the provision for the timing belt guide plate. There are 9's out there too. And 11's, and 12's (Japan).
Some 10's are marked with a 10 like the 7 and 9 are marked. 11's are marked "78" and I believe the newer 10's are marked "76".
good info - kinda confusing for us that don't handle this stuff regularly.
found a coupla pics - here's the '78' (11 mm?)
are these the same size as marked?
This is what i found:
What it fits:
Subaru Baja 2.5L TURBO MT 4WD T 200420052006 Subaru Baja 2.5L TURBO MT B PICK UP 200420052006 Subaru Baja 2.5L TURBO MT PICK UP 200420052006 Subaru Baja 2.5L TURBO S/S 4WD T 200420052006 Subaru Baja 2.5L TURBO S/S B PICK UP 200420052006 Subaru Baja 2.5L TURBO S/S PICK UP 200420052006 Subaru Forester 2.5L AT L 1998 Subaru Forester 2.5L AT S 1998 Subaru Forester 2.5L AT X 200620072008 Subaru Forester 2.5L AT XT Sports 2008 Subaru Forester 2.5L MANUAL Base Premium 1998 Subaru Forester 2.5L MANUAL L 1998 Subaru Forester 2.5L MANUAL Premium 1998 Subaru Forester 2.5L MANUAL S 1998 Subaru Forester 2.5L MANUAL X 200620072008 Subaru Forester 2.5L MANUAL XT Sports 2008 Subaru Forester 2.5L TURBO AT XT Sports 20042005200620072008 Subaru Forester 2.5L TURBO MT XT Sports 20042005200620072008 Subaru Impreza (205) 5MT 4WD GT Sedan 2002200320042005 Subaru Impreza (205) 5MT 4WD WRX Premium Wagon 2002200320042005 Subaru Impreza (205) 5MT 4WD WRX Sedan 2002200320042005 Subaru Impreza (205) 5MT 4WD WRX Wagon 2002200320042005 Subaru Impreza (205) AT 4WD GT Sedan 2002200320042005 Subaru Impreza (205) AT 4WD WRX Premium Wagon 2002200320042005 Subaru Impreza (205) AT 4WD WRX Sedan 2002200320042005 Subaru Impreza (205) AT 4WD WRX Wagon 2002200320042005 Subaru Impreza (257) 6MT 4WD STI Limited Sedan 2006 Subaru Impreza (257) 6MT 4WD STI Sedan 200420052006 Subaru Impreza 2.5L 5MT 4WD Outback Sport Wagon 2006 Subaru Impreza 2.5L 5MT 4WD Outback Wagon 20062007 Subaru Impreza 2.5L 5MT 4WD Premium Sedan 2006 Subaru Impreza 2.5L 5MT 4WD Premium Wagon 2006 Subaru Impreza 2.5L 5MT 4WD Sedan 20062007 Subaru Impreza 2.5L 5MT 4WD Wagon 20062007 Subaru Impreza 2.5L AT 4WD Outback Sport Wagon 2006 Subaru Impreza 2.5L AT 4WD Outback Wagon 20062007 Subaru Impreza 2.5L AT 4WD Premium Sedan 2006 Subaru Impreza 2.5L AT 4WD Premium Wagon 2006 Subaru Impreza 2.5L AT 4WD RS Coupe 1998 Subaru Impreza 2.5L AT 4WD Sedan 20062007 Subaru Impreza 2.5L AT 4WD Wagon 20062007 Subaru Impreza 2.5L MT 4WD RS Coupe 1998 Subaru Impreza 2.5L TURBO 5MT 4WD GT Sedan 2006 Subaru Impreza 2.5L TURBO 5MT 4WD WRX Premium Wagon 2006 Subaru Impreza 2.5L TURBO 5MT 4WD WRX Sedan 2006 Subaru Impreza 2.5L TURBO 5MT 4WD WRX TR Sedan 2006 Subaru Impreza 2.5L TURBO 5MT 4WD WRX Wagon 2006 Subaru Impreza 2.5L TURBO 6MT 4WD STI Limited Sedan 2006 Subaru Impreza 2.5L TURBO 6MT 4WD STI Sedan 200420052006 Subaru Impreza 2.5L TURBO AT 4WD GT Sedan 2006 Subaru Impreza 2.5L TURBO AT 4WD WRX Premium Wagon 2006 Subaru Impreza 2.5L TURBO AT 4WD WRX Sedan 2006 Subaru Impreza 2.5L TURBO AT 4WD WRX Wagon 2006 Subaru Legacy 2. L GRADE : TURBO Sedan 19911992 Subaru Legacy 2.5L 4AT 4WD Limited 20062007 Subaru Legacy 2.5L 4AT 4WD Limited Wagon 20062007 Subaru Legacy 2.5L 4AT 4WD SE Wagon 2006 Subaru Legacy 2.5L 4AT 4WD Sedan 20062007 Subaru Legacy 2.5L 5MT 4WD Limited Wagon 20062007 Subaru Legacy 2.5L 5MT 4WD SE Wagon 2006 Subaru Legacy 2.5L 5MT 4WD Sedan 20062007 Subaru Legacy 2.5L AT 4WD GT Limited Sedan 1996199719981999 Subaru Legacy 2.5L AT 4WD GT Sedan 1996199719981999 Subaru Legacy 2.5L AT 4WD GT Wagon 1996199719981999 Subaru Legacy 2.5L AT 4WD Limited Touring Wagon 1996199719981999 Subaru Legacy 2.5L AT 4WD LSI Sedan 19961997 Subaru Legacy 2.5L AT 4WD LSI Wagon 19961997 Subaru Legacy 2.5L AT 4WD Outback Touring Wagon 1996199719981999 Subaru Legacy 2.5L AT 4WD SUS Sedan 199719981999 Subaru Legacy 2.5L MT 4WD GT Limited Sedan 1996199719981999 Subaru Legacy 2.5L MT 4WD GT Sedan 1996199719981999 Subaru Legacy 2.5L MT 4WD GT Wagon 1996199719981999 Subaru Legacy 2.5L MT 4WD Limited Touring Wagon 1996199719981999 Subaru Legacy 2.5L MT 4WD Outback Touring Wagon 1996199719981999 Subaru Legacy 2.5L TURBO 5AT 4WD GT Limited Sedan 20052006200720082009 Subaru Legacy 2.5L TURBO 5AT 4WD GT Limited Wagon 200520062007 Subaru Legacy 2.5L TURBO 5AT 4WD GT Wagon 20052006 Subaru Legacy 2.5L TURBO 5AT 4WD Limited Wagon 20052006 Subaru Legacy 2.5L TURBO 5MT 4WD GT Limited Sedan 20052006200720082009 Subaru Legacy 2.5L TURBO 5MT 4WD GT Limited Wagon 200520062007 Subaru Legacy 2.5L TURBO 5MT 4WD GT Wagon 20052006 Subaru Legacy 2.5L TURBO 5MT 4WD Limited Wagon 20052006 Subaru Legacy 2.5L TURBO 6MT 4WD GT Limited Sedan 2006200720082009 Subaru Legacy 2.5L TURBO MT 4WD BAJA-B PICK UP 200420052006 Subaru Legacy 2.5L TURBO S/S 4WD BAJA-B PICK UP 200420052006 Subaru Legacy 4. L GRADE : TURBO Sedan 1991199219931994 Subaru Legacy 4. L GRADE : TURBO WAGON 199219931994 Subaru Outback 2.5L 4AT Base 20062007 Subaru Outback 2.5L 4AT Limited 20062007 Subaru Outback 2.5L 5MT Base 20062007 Subaru Outback 2.5L 5MT Limited 2006 Subaru Outback 2.5L TURBO 5AT XT 200520062007 Subaru Outback 2.5L TURBO 5AT XT Limited 20052006200720082009 Subaru Outback 2.5L TURBO 5MT XT 200520062007 Subaru Outback 2.5L TURBO 5MT XT Limited 20052006200720082009 Subaru Outback 3.0L 5AT L.L.Bean 2006 Subaru Outback 3.0L 5AT Limited 2006 Subaru Outback 3.0L 5AT R 2006 Subaru STI (257) 6MT 4WD Limited Sedan 2006 Subaru STI (257) 6MT 4WD SEDAN 200420052006 Subaru STI 2.5L TURBO 6MT 4WD Limited Sedan 20062007 Subaru STI 2.5L TURBO 6MT 4WD SEDAN 2004200520062007 Subaru WRX (205) 5MT 4WD SEDAN 2002200320042005 Subaru WRX (205) 5MT 4WD WAGON 2002200320042005 Subaru WRX (205) AT 4WD SEDAN 2002200320042005 Subaru WRX (205) AT 4WD WAGON 2002200320042005 Subaru WRX 2.5L TURBO 5MT 4WD SEDAN 20062007 Subaru WRX 2.5L TURBO 5MT 4WD TR SEDAN 20062007 Subaru WRX 2.5L TURBO 5MT 4WD WAGON 20062007 Subaru WRX 2.5L TURBO AT 4WD SEDAN 20062007 Subaru WRX 2.5L TURBO AT 4WD WAGON 20062007
