CoreysLoyale Posted January 10, 2005 Share Posted January 10, 2005 So I was sliding around in the safety of a snowed-over, fairly slick parcking lot in my 91 auto tran-tran loyale, and as I am drifting around a planter, lush in greenery, the car just turns off as though it were frightened of the freshly dumped, white blanket of frozen precipitation. The electronics (stereo and lights) were still in perfect operation. Is this merely a feature of the luxurious loyale designed to keep me from sliding to my ultimate demise, or is it time for a friggin' tune up. :banana: :banana: Quote Link to comment Share on other sites More sharing options...
MSSLGECKO Posted January 10, 2005 Share Posted January 10, 2005 I'm fairly confident that that is not a dealer option you have there. Sounds like something is amis. I have been told that Subarus know no fear, so that is definately not a case of your car being intimidated by a planter. Quote Link to comment Share on other sites More sharing options...
sheppie62 Posted January 10, 2005 Share Posted January 10, 2005 check you engine ground wire, or other wires, low gas Quote Link to comment Share on other sites More sharing options...
kingbobdole Posted January 10, 2005 Share Posted January 10, 2005 Does it crank? Does it run but stall? Do the engine lights not come on? Quote Link to comment Share on other sites More sharing options...
canajun2eh Posted January 10, 2005 Share Posted January 10, 2005 I bet you were running near the red line. All of my Subarus have turned off when I hit the red line, turning on again as soon as the engine revs dropped to a more reasonable level. That's an ECU function as near as I can tell. Quote Link to comment Share on other sites More sharing options...
CoreysLoyale Posted January 11, 2005 Author Share Posted January 11, 2005 I bet you were running near the red line. All of my Subarus have turned off when I hit the red line, turning on again as soon as the engine revs dropped to a more reasonable level. That's an ECU function as near as I can tell. YES! I do believe it was reving quite a bit higher than I usually let it. Blasted automatic McTranny! THANKS CANAJUN2EH:banana: Quote Link to comment Share on other sites More sharing options...
americanyouth Posted January 11, 2005 Share Posted January 11, 2005 I bet you were running near the red line. All of my Subarus have turned off when I hit the red line, turning on again as soon as the engine revs dropped to a more reasonable level. That's an ECU function as near as I can tell. Wierd. I've had my EA82 well over red-line (as in, around 8000 revs) Quote Link to comment Share on other sites More sharing options...
