Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Engine shake after Engine Removal/Head Gasket replacement
#1
Posted 20 January 2005 - 10:31 PM
I am experiencing some engine shudder/shake - feel it when I am stopped. Car runs great otherwise. Idle rpm is fine too.
Any ideas where to start?
#2
Posted 20 January 2005 - 11:04 PM
99 leg l sedan 2.2l 5-sp
#3
Posted 20 January 2005 - 11:11 PM
#4
Posted 20 January 2005 - 11:28 PM
I removed the engine and replaced HG/Clutch/Timing belt on my 98 outback.
timing off?
#5
Posted 21 January 2005 - 04:55 AM
#6
Posted 21 January 2005 - 12:46 PM
Timing - I doubt it though it is not impossible.
Why I think timing is right - First, the car runs great. Second, I counted the teeth on timing belt(from crank sprocket mark to cam sprocket mark, and intake to exhaust cam sprocket marks) and they were exactly as per spec. As I understand it, only reliable way is counting teeth. The Right cam marks aligned perfectly with inside right timing cover....
The "not impossible part" - The marks on left intake cam sprocket did not align perfectly with left inner timing cover - seemed off by less than 1/2 tooth. If I had tried moving to next teeth, I would be off by more than 1/2 tooth and more importantly, the teeth count would have been off.
Mark on left exhuast cam sprocket was off by even less - perhaps 1/4 tooth. The left intake and exhaust alignment with respect to each other (the double etched marks on sprockets) seemed off by 1/2 tooth in relation to each other but the factory paint mark(not sprocket marks) going across left intake and exhaust were in perfect alignment.
I also suspect that a resurfaced head and an updated head gasket (Subaru redesigned them) with different thickness can make material difference to alignment with relation to inner mark, since they impact the distance between the crank and cam sprockets.
#7
Posted 21 January 2005 - 01:12 PM
Did you adjust the valves afterward?
#8
Posted 21 January 2005 - 01:15 PM
#9
Posted 21 January 2005 - 01:51 PM
Compression check? Bad plug wire?
#10
Posted 21 January 2005 - 02:36 PM
http://www.ultimates...ead.php?t=27635
I did measure compression on 1 and 2 and it seemed to around 200psi after 6-7 cranks. I didn't do 3 and 4 since they are harder to reach with engine in the car. Spark plug wire resistance measures up okay too. The plugs seem okay. I checked the injectors too and they were fine.
Somehow the CEL problem went away mysteriously.
Any other ideas? Could it be mechanical - I redid the pitching stopper but didn't make a difference. Engine mounts seem okay too...
#11
Posted 24 January 2005 - 09:55 PM
Spark plug wires - I did the experiment in dark garage - no arcs visible even when I spray with water/lysol!
#12
Posted 24 January 2005 - 10:20 PM
#13
Posted 25 January 2005 - 01:09 AM
I might try compression test on other cylinders as you suggested.
#14
Posted 26 January 2005 - 12:20 AM
#15
Posted 26 January 2005 - 02:46 PM
#16
Posted 26 January 2005 - 03:43 PM
Nor sure about other cars, but on DOHC EJ25, you cannot adjust valve clearance with heads off - one has to bolt heads onto short block, put in valve lifters and valve shims and then put the camshaft...
#17
Posted 26 January 2005 - 03:46 PM
On the EJ25 DOHC, the head bolts are under the cam shafts, so it makes no sense to do the adjustment with the head off the block. Unless you don't mind disassembling the thing again to bolt the head to the block...
#18
Posted 26 January 2005 - 06:42 PM
#19
Posted 26 January 2005 - 07:16 PM
#20
Posted 26 January 2005 - 08:52 PM
Engine shake is the only problem, feel it at idle. As I said Idle rpms are fine too...
Could the shake still be attributed to a problem in ignition or fuel system? Wouldn't a problem in those trigger CEL?
#21
Posted 26 January 2005 - 10:13 PM
The car is running great with no CEL. Plug wires are tight.
I think it would, OBDII systems are pretty good at detecting a misfire. Have you double checked the engine mounts?
#22
Posted 26 January 2005 - 10:25 PM
The engine mounts that fit on cross member are tight - I torqued them to spec. It is hard to see if anything is wrong with engine weight on them - visually they look fine.
Is there a way of identifying mount problems short of lifting the weight off the mounts - which would mean I would have to raise the engine.
#23
Posted 26 January 2005 - 10:39 PM
Have you tried pulling one spark plug wire at a time to see if the nature of the shake changes? If you find a cylinder where pulling the wire doesn't change anything, that's the one you want to examine more closely.
If you haven't I would do a compression test on all cylinders.
#24
Posted 26 January 2005 - 10:48 PM
Nope I haven't tried removing one plug at a time. You mean try to find a cylinder with no compression or very low compression? Won't very low compression also trigger a CEL? If a cylinder has reasonable compression (even 40 to 50 percent of other cylinders), I would assume that removing the plug wire will change the nature of shake.I would just examine the mount closely with the engine running. You should see movement but it should be very limited. The only engine mount failure I have ever diagnosed was very evident, with a couple of inches of movement when gears were changed, so my knowledge is limited to that experience.
I am thinking about doing it on cylinder 2 and 4...it's hard to get that tube into spark plug hole with engine in the car!
#25
Posted 27 January 2005 - 06:59 AM
i think you'll find something.
