Ratty2Austin Posted January 26, 2006 Share Posted January 26, 2006 got it swapped in less than 5 hours!!! ingredients= EJ22 longblock+EJ18 manifold, + EJ22 injector rails/injectors more power! pics and more info coming later! EJ18 for sale now! (longblock only, good cond~$120) Quote Link to comment Share on other sites More sharing options...
A DOG Posted January 26, 2006 Share Posted January 26, 2006 Does the EJ 1.8l have more power than the EA82 1.8l? Quote Link to comment Share on other sites More sharing options...
Snowman Posted January 26, 2006 Share Posted January 26, 2006 Yeah, the EJ18 makes at least 20 more horses than the EA82. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 26, 2006 Share Posted January 26, 2006 Congrats Austin, now come home. Quote Link to comment Share on other sites More sharing options...
tailgatewagon Posted January 26, 2006 Share Posted January 26, 2006 did you put the ej18 heads on the ej22, they are a roller rocker type and work up the compresion a bit look at nasioc there is a thread on the topic might want to check it out any way sweet. Quote Link to comment Share on other sites More sharing options...
Ratty2Austin Posted January 27, 2006 Author Share Posted January 27, 2006 here is the EJ18 as it sits right now.... still a good running engine, but only puts out about 100 or 110ish HP... good HGs! good bearings, good heads! Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 27, 2006 Share Posted January 27, 2006 If the spark plug threads are good, maybe i just want the heads, one of my heads has a helicoil on the spark plug, and i'm not so keen on that, and if i can put the EJ18 heads on her, and raise the compression to boot, it might not be a bad option. Anyone know the "new" compression ratio? or what the head volume is? Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 27, 2006 Share Posted January 27, 2006 Does the EJ 1.8l have more power than the EA82 1.8l? It is however not a direct swap, you'll need the adapter plate and the wiring harness and computer. Quote Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted January 27, 2006 Share Posted January 27, 2006 If the spark plug threads are good, maybe i just want the heads, one of my heads has a helicoil on the spark plug, and i'm not so keen on that, and if i can put the EJ18 heads on her, and raise the compression to boot, it might not be a bad option. Anyone know the "new" compression ratio? or what the head volume is? matty b with the ej22 Brumby has looked at swapping ej18 heads onto his motor but decided against it as the ej18 heads are too restrictive. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted January 27, 2006 Share Posted January 27, 2006 hehe, I love the color on that old motor!! did you ever get the tranny from my parents' place? I'm not sure when I'm going to be able to get down there again.....so if you want it, you're going to have to help yourself (and feel free to do so, my parents know you want, and I tore up the yard pulling the loyale out so you could get at it) Quote Link to comment Share on other sites More sharing options...
ballitch Posted January 27, 2006 Share Posted January 27, 2006 okay, just so people know, Matt Monson over on nasioc has been doing these "hybrid" EJ motors for quite some time, and his advise for cheap reliable power is: if you have a EJ22 alread, DO NOT get EJ18 heads put on it. for one the EJ18 heads are horribly restrictive for that CR (11.5:1) , the EJ18 cams do have better lobes for power, but its totally offset by the crappy flow of the heads. Two, you can grab a phase I or II EJ25 shortblock for less than $300, i know because i paid $200 for my shortblock that sitting in my dads shop, awaiting the phase II EJ22 heads from my 98 legacy. just by swapping in a EJ25 shortblock, you gain 20-25 HP with block and increased CR. if you DO swap in the EJ25 block, you MUST (strongly advised, not a must) send the cams to a place like delta cams in tacoma, WA. they will grind them to a more aggressive profile and net you another 10-12 HP, add some headers, a lightweight crank pulley, and a cat-back or header-back 2.25'' exhaust and now you have 195-200 HP at the crank. most of the power form this combo comes from 2k-4k rpm, but doesnt fall on its face after 5000 like the EJ22 does, it will keep pulling. do some research before you jump into this though. im sorry for hijacking, glad to hear you got more power, now you dont have to go WOT to keep up with traffic. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 27, 2006 Share Posted January 27, 2006 Dude, Austin won't care, hijack away. So can you run the EJ25 block with the EJ22 engine management? Or would you reccomend somthing like Perfect power for tuning? And whats the CR with the EJ22 heads? Quote Link to comment Share on other sites More sharing options...
soobmater Posted January 28, 2006 Share Posted January 28, 2006 Woohooo austin!!! might make the trip back home a bit easier Quote Link to comment Share on other sites More sharing options...
ballitch Posted January 28, 2006 Share Posted January 28, 2006 im using a phase I EJ25 block and phase II EJ22 heads. the phase II heads flow marginally better than the phase I's. but if you combine a phase II block and any kind of EJ22 head, you end up with 11.5:1 CR. but if you go the route im going, you use phase II heads on phase I block you get about 10.8:1-11.0:1 CR. with either one you NEED to run premium gas. yes you can use the EJ22 engine management, since they are both MAF systems, not MAP. remember to match the intake manifold to the heads you have, so keep your EJ22 intake, im just going to take it off and leave it in the engine bay(along w/ AC compressor). lots of info over on nabisco. ~Josh~ Quote Link to comment Share on other sites More sharing options...
Monte Posted February 1, 2006 Share Posted February 1, 2006 here is the EJ18 as it sits right now.... still a good running engine, but only puts out about 100 or 110ish HP... good HGs! good bearings, good heads! That looks like it's been underwater. Monte Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted February 1, 2006 Share Posted February 1, 2006 That looks like it's been underwater. Monte It has Quote Link to comment Share on other sites More sharing options...
dome24 Posted February 14, 2006 Share Posted February 14, 2006 got it swapped in less than 5 hours!!! ingredients= EJ22 longblock+EJ18 manifold, + EJ22 injector rails/injectors more power! pics and more info coming later! EJ18 for sale now! (longblock only, good cond~$120) I can't wait to get rid of my 1.8, is all you changed the longblock and injectors? what about the ECU? Quote Link to comment Share on other sites More sharing options...
Ratty2Austin Posted February 16, 2006 Author Share Posted February 16, 2006 I can't wait to get rid of my 1.8, is all you changed the longblock and injectors? what about the ECU? yeah, longblock, and injectors..keep the EJ18 manifold+electronics (thus keeping the EJ18 manifold) and the ECU stays the same- drawback- my CEL randomly comes on, because the EJ22 that I pulled was one without EGR, so I had to cap off the vac lines that control the valve (bypassing these with little screws in the hoses keeps the valve close, so it doesnt open the manifold up to open atmosphere) but it seems to run good- I just dont know whats going to happen when I go in for an emissions test! **** easy instructions on the swap- 1. remove Y pipe, Alt, A/C compressor, P/S pump, radiator and battery. 2. unbolt and move aside your EJ18 intake manifold, leaving all wires attached to the manifold (you will use the EJ18 harness) 3. unbolt+remove EJ18 longblock. 4.with engines removed, install new parts (like clutch?) or seals if needed. 5.install EJ22 longblock. 6.install EJ22 injectors into EJ18 manifold (easier to install the rail assemblys than to remove each injector) 7.re-install EJ18 intake manifold, onto the EJ22 longblock. 8.re-install Alt, P/S pump, A/C compressor, radiator and battery 9. dont forget to add oil and coolant! notes- EJ18 does not use a knock sensor, so if using the EJ18 ECU, it is still not needed. phase1 (w/dual port exhaust) EJ22 will interchange many of the parts used by the EJ18- including tbelt parts, water/oil pump, exhaust/intake Quote Link to comment Share on other sites More sharing options...
EDSIMPREZA22 Posted February 16, 2006 Share Posted February 16, 2006 HEy whats up guys ? Nice swap.. I have 2.2 in my 97 impreza can I upgrade into a 2.5 and if its doable what years fit..??? Quote Link to comment Share on other sites More sharing options...
Ratty2Austin Posted February 16, 2006 Author Share Posted February 16, 2006 HEy whats up guys ?Nice swap.. I have 2.2 in my 97 impreza can I upgrade into a 2.5 and if its doable what years fit..??? personally, I would reccomend to NOT switch to the 2.5...although they are more powerful than the 2.2, they are not anywhere near as reliable.. all the 2.5s that I have seen, either DOHC or SOHC, have had some strange issues, usually relating to HG, or piston slap.... although, it might just be all the ones I have seen... you can find info about the 2.5 swaps using the search function, and- http://www.nasioc.com deals with more of the 2.5 swaps.. try searching that as well but yeah.. just my opinion, stick with the 2.2- they are tough! Quote Link to comment Share on other sites More sharing options...
Qman Posted February 20, 2006 Share Posted February 20, 2006 We just completed the son's car. '93 Impreza "L" 1.8 5sp AWD Now we have a '93 Impreza "L" 2.2 5sp AWD. We had the motor from a '96 OB Legacy. Ended up installing headgaskets in it though. Resealed it with new belts and clutch. Runs much stronger than the 1.8. Next will be the sway bars, new suspension and air intake. I will be adding a 2.2 y-pipe when I part my Legacy out. Then have a catback built. Next in line for the garage is the '96 Brighton. It get's the 2.5 in place of it's 1.8. Quote Link to comment Share on other sites More sharing options...
