6" lift and t-case.....on a legacy???
14 replies to this topic
#1 offroadsubaruguy
offroadsubaruguy
    Subaru Nut
  • 729 posts
  • arvada, colorado
Posted 09 March 2006 - 09:28 AM
just wondering, has anyone yet considered this option????? i really would like to try it, but its going to take me a really, really, really long time to get everything together..... so, what would i need to do this???? other than the obvious........
#2 Numbchux
Numbchux
    EJ conversion addict
  • 6,827 posts
  • Saginaw, MN
Posted 09 March 2006 - 12:01 PM
same as doing it on any other subaru....do a search ;)
also, you're going to need to do at least an 8" lift, to fit the tcase and front diff. probably more like 10"
copied from the FAQ
Here is a rough list of steel you will need/use to do this project...
14pcs. of 1/4" x 2" x (8" or 10") x 2 inches long
aprox 20 feet of 1 1/2" x 1/8" wall square tube for tieing blocks together......
10 feet of 3 x 2 x 1/8 wall Rec. tube for tieing front blocks to rear blocks...This is also what the T-case will mount off of.....
Depending on how you are going to build front strut tops, you will need
10 feet of 1/4" x 3" flat bar
3 feet of 1/4" x 8" flat bar
2 pcs 1/4" x 8"x 6" flat bar
You will also need Tubing to sleave shift and 4WD linkage,
2 pcs of 1/4 x 3 x 3 angle iron for motor Mounts,
You will be building custom tranny mounts, so there is some steel in there
You will be stuffing a T-case Most likely, there will be steel involved there as well to mount it into the sub frame structure you build to connect front blocks with rear blocks.....
I did Jarods For $1500.00 Installed....this didn't include T-case , or 5 speed tranny......
All steel above is a Rough guess-timate but it will get you Started, let you see cost involved.....
Also you have to remember fuel lines and Brake lines have to be lengthened.....
you will also need front and rear diffs (maybe you'll reuse yours? but you might as well get 4.44s), front and rear driveshafts, tcase, and time.
you'll also need to modify your tranny so the center diff is locked. The DutyC is not strong enough to turn a tcase and big tires, do a search for andyjo's thread about it here in the offroad forum. Mudrat responded with some good information regarding this.
#3 LosDiosDeVerde86
LosDiosDeVerde86
    1000+ Super USER!
  • 1,358 posts
  • Columbus
Posted 09 March 2006 - 06:53 PM
i consider this every day on my life.
#4 burtonsnowman
burtonsnowman
    Banned
  • Banned
  • 448 posts
  • Elk (Spokane Area)
Posted 09 March 2006 - 10:12 PM
Yup...if not three or four times daily...
#5 offroadsubaruguy
offroadsubaruguy
    Subaru Nut
  • 729 posts
  • arvada, colorado
Posted 10 March 2006 - 09:09 AM
basically, i would either slightly frame it and then t case it, or i would roll cage it. either way i would make everything as high up as possible. meanin i would just cut a hole in the floor for the tcase, and just find some high angle shafts....i dont like the look of the tcase just hanging out in the middle of the car being a serious low point...
#6 Numbchux
Numbchux
  • 6,827 posts
  • Saginaw, MN
Posted 10 March 2006 - 09:52 AM
it has to be, as the input shaft on the tcase attaches directly to the rear output of the tranny. you could get a tcase that sits at an angle, but then you'd have some goofy stuff going on with the front driveshaft.
you have to build a frame under the car, the unibody is not strong enough to handle the torque of the tcase, there has to be something substantially more beefy there.....
also, remember you have to lift the car enough to mount a front diff under the tranny. And part of that means you have to find a way to attach a diff, one that's usually mounted in the rear, to the engine crossmember, and built a new engine crossmember above that (it's easier than building something new to hold the control arms, and steering rack).
This would be very cool, but it's VERY involved.
#7 seattlelegacy
seattlelegacy
    Eat, Live, Breath Subaru
  • 267 posts
  • seattle
Posted 10 March 2006 - 12:45 PM
So nice....
#8 RavenTBK
RavenTBK
    Professional Auto Thief
  • 661 posts
  • Apalachicola Natl Forest
Posted 10 March 2006 - 03:02 PM
So nice....
Oh.. wow.. someone toss me a towel! :eek: :lol:
#9 operose
operose
    1000+ Super USER!
  • 1,264 posts
  • Potsdam
Posted 10 March 2006 - 04:06 PM
Posted Image
old
#10 burtonsnowman
burtonsnowman
    Banned
  • Banned
  • 448 posts
Posted 11 March 2006 - 11:54 PM
I want those fender flares...
They're even the right color...
#11 oskar_subaru
oskar_subaru
    USMB is life!
  • 148 posts
  • Reykjavik, Iceland
Posted 12 March 2006 - 09:59 AM
So nice....
thad is not an lifted subaru... it´s a range rover chassy with the subaru body on topp
#12 LosDiosDeVerde86
LosDiosDeVerde86
    1000+ Super USER!
  • 1,358 posts
  • Columbus
Posted 12 March 2006 - 10:50 AM
i see you're from iceland, do you know that person?
#13 Numbchux
Numbchux
  • 6,827 posts
  • Saginaw, MN
Posted 12 March 2006 - 04:13 PM
we suspected (the first time this pic turned up) that it was a toyota landcruiser or something....
#14 erik litchy
erik litchy
    Leadfoot
  • 1,090 posts
  • Peoria IL
Posted 12 March 2006 - 06:46 PM
personally if you are going to that much work id be wroking on a buggy from scratch instead. no compromise design sounds better, no?
#15 oskar_subaru
oskar_subaru
    USMB is life!
  • 148 posts
Posted 16 March 2006 - 07:20 PM
yes i am from iceland ....... i don´t know the person who owns this car directly but as it is here in iceland : if you don´t know sumbody you are likely to know sumone thad does.
sorry about my english :rolleyes:
oskar
