Anything look out of place?
27 replies to this topic
#1 MachineAgeVictim
MachineAgeVictim
    Civilized 4 Wheel Drive.
  • 358 posts
  • West Palm Beach
Posted 07 April 2006 - 04:24 PM
Posted Image
Posted Image
Posted Image
#2 swiftt
swiftt
    USMB Regular
  • PipPipPip
  • 89 posts
  • Portland, OR
Posted 07 April 2006 - 04:45 PM
Uh, sure. I'll bite.
I'd say the aftermarket fuel pump is out of place.
What kind of car are we looking at? The radiator looks much smaller than the one in my EA71 Brat.
#3 swiftt
swiftt
    USMB Regular
  • PipPipPip
  • 89 posts
  • Portland, OR
Posted 07 April 2006 - 04:49 PM
It also looks like one of the PCV hoses from the bottom of the aircleaner assembly is in need of a home.
#4 subiemech85
subiemech85
    SIX STAR SERVICE
  • 2,710 posts
  • down by the river
Posted 07 April 2006 - 05:06 PM
spare and carb pre-heat air hose :D
#5 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,138 posts
  • Oregon City
Posted 07 April 2006 - 06:36 PM
most of the gen 1 cars I've seen usually have the AC compressor outside of the alternator instead of inboard like this one is. Seems to look ok to me.
#6 subeman90
subeman90
    Soobologist
  • Moderator
  • 2,801 posts
  • Akron PA
Posted 07 April 2006 - 06:37 PM
poorly painted aircleaner????? :D
#7 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,267 posts
  • Everett, WA, USA
Posted 07 April 2006 - 07:23 PM
The spare tire? Its certainly not there
#8 75subie
75subie
    I`m sold on Subaru
  • 3,910 posts
  • Walden
Posted 07 April 2006 - 07:34 PM
yea there shure is something out of place:lol: that beautiful wagon is not in my driveway:lol:
#9 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 07 April 2006 - 08:45 PM
1) Pre-heater hose
2) PCV intake hose caped off
3) Air valve hose not installed (on the intake)
4) Aftermarket fuel pump
5) Poorly painted intake
6) Missing jack
7) Missing spare
#10 MachineAgeVictim
MachineAgeVictim
  • 358 posts
  • West Palm Beach
Posted 07 April 2006 - 09:13 PM
anything that would hender the performance?
so that's not the original fuel pump huh?
#11 cricket
cricket
    Subaru Fanatic!
  • 372 posts
  • Houston, Texas
Posted 07 April 2006 - 09:40 PM
Would help if you removed the air cleaner. Is the anti-dieseling/cut-off thing disconnected (wire broken) at the carb?
#12 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 08 April 2006 - 12:42 AM
Well maybe the vacume lines, but its hard to tell what they did with the air filter covering most of the important area of the motor (the carb).
And its probably good that its not the original pump.
#13 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,138 posts
  • Oregon City
Posted 08 April 2006 - 10:46 PM
well even if it wsa the original pump, it wouldn't make a differemce really. I've always had the stock pumps in my gen 1's and they worked great.
Yes, please do remove the air cleaner so we can get a better look at that carb
#14 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 09 April 2006 - 07:20 AM
Whats that odd "ticking" upon start up and when idling?
It's the Facet fuel pump.
Isolate it from the mount with some form of
pliable matting.
#15 MachineAgeVictim
MachineAgeVictim
  • 358 posts
  • West Palm Beach
Posted 09 April 2006 - 09:05 AM
good tip!, would rubber between it and the mount work?
#16 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
Posted 09 April 2006 - 09:11 AM
Sure, but it depends on the shore durometer of the rubber.
http://stripe.colora...meterscale.html
#17 MachineAgeVictim
MachineAgeVictim
  • 358 posts
  • West Palm Beach
Posted 09 April 2006 - 11:41 AM
I actually checked it out and it's riding on rubber pillars
now to quiet the clicking of the valve lifters!
#18 MachineAgeVictim
MachineAgeVictim
  • 358 posts
  • West Palm Beach
Posted 09 April 2006 - 11:51 AM
I'm also going to try and retro fit one of these
Posted Image
#19 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
Posted 09 April 2006 - 12:22 PM
do go here though
Posted Image
#20 MachineAgeVictim
MachineAgeVictim
  • 358 posts
  • West Palm Beach
Posted 09 April 2006 - 03:23 PM
is the plastic covered valve in the airbox, inside the filter, needed for anything? is it just emmissions? and anyone know where the two hoses should connect to?
#21 MachineAgeVictim
MachineAgeVictim
  • 358 posts
  • West Palm Beach
Posted 09 April 2006 - 06:14 PM
well I fitted the filter/airbox to the carb, looks great, can't wait till fire it up, if only I knew what those two hoses were for
If anyone else wants to fit this filter I can do a write-up
#22 cricket
cricket
    Subaru Fanatic!
  • 372 posts
  • Houston, Texas
Posted 09 April 2006 - 11:13 PM
My repair manual has emissions diagrams for different generations of Subarus. Compare the oldest with yours and that will show you what needs to be "deleted" to de-emission your Subaru. It would seem to me that all you absolutely need is the vacuum advance line AND the crankase ventilation tube. You can turn the crankase ventilation tube DOWN and away, to create a negative pressure at its open tip. This is a simple way to run your crankase gases out of your engine and out the tube. The PCV valve is useless in my mind so you can probably do away with that too. Everything else can be removed and/or plugged up. They even have those nice vacuum cap kits at Rose Auto (or whatever is they call themselves now--Discount? Murray's?) .
#23 MachineAgeVictim
MachineAgeVictim
  • 358 posts
  • West Palm Beach
Posted 09 April 2006 - 11:21 PM
Posted Image
is that the hose with the screw in it?
#24 ecky
ecky
    USMB is life!
  • 132 posts
  • Roseburg, Oregon
Posted 12 April 2006 - 05:13 PM
I bought that same fuel pump for my '77 It is in the original pumps place, but it is a pusher not a puller. I think the instructions said it needs to be 6" below the tank and aimed up at a 45 degree angle. I put mine right were yours is and I get that same ticking. but I kinda like it.:)
#25 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
Posted 13 April 2006 - 03:00 AM
MAV, I believe the hose with the bolt in it
goes to the thermo valve for the the air cleaner snorkel
to exhaust furnace control valve diaphragm.
I now notice in picture three on the first page of this post,
the diaphragm control valve has no hose on it.
(it's on top of the aircleaner snorkel.)
This system brings warm air into the air cleaner in cold weather. (not needed where you are)
The thermo valve resides on the under side of the air cleaner.
The line with the bolt, went to it, it controls vacuum to the diaphragm when it's cold enough, via another rubber line.
The flex pipe from the opening in the underside of the snorkel to the furnace,
is probably not there either.
Hope this is what you are talking about
