You guys who redrill your rims, not your hubs.
12 replies to this topic
#1 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 09 July 2006 - 10:37 PM
What size bit did you use on the rims? And what did you use to bevel the holes?
-Brian
#2 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 09 July 2006 - 10:53 PM
I think I just grabbed one out of my bit box that matched the existing holes.
I'd get a angled stone bit to bevel it, though I just red-necked it on mine and tilted the drill, which I know does the backside as well, but my wheels were super thick. (and I only needed to do it on 2 per wheel...)
#3 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 09 July 2006 - 10:56 PM
I know the studs are like... 14mm or 9/16. So i was thinking maybe thats it... but dont i want the holes alittle bigger than the studs? Also was thinking of picking up a larger bit like 5/8 or 11/16 to use to bevel.
-Brian
#4 monstaru
monstaru
    wow, relevance....
  • 4,453 posts
  • OlyWa
Posted 09 July 2006 - 11:25 PM
i used a large 3/4 inch countersink.you should be able to find one at your local machine shop supply store.
Posted Image
#5 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 09 July 2006 - 11:52 PM
3/4 inch, thanks :) I can order pretty much anything through work... so i wanted to make sure i get the right stuff before i lay down the cash.
Did you use a 9/16" bit for the rims Monstaru?
-Brian
#6 El Toro
El Toro
    BIG DADDY ED
  • 297 posts
  • Kitsap co.
Posted 10 July 2006 - 10:46 AM
i did just about the same thing. 9/16 plus used a angeled stone bit. good thing they are cheap. was toast after the 4th rim.
#7 monstaru
monstaru
    wow, relevance....
  • 4,453 posts
  • OlyWa
Posted 10 July 2006 - 04:05 PM
it was like 35/64ths or something like that.i got it to match the splined part of the lugs for when i was going to do the hubs.then ended up drilling rims with it.it gave just enough room for the lug,match it with a countersink and voile'.cool thing about a countersink is it's ability to pretty much center itself.
#8 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 10 July 2006 - 04:46 PM
it was like 35/64ths...
My 35/64ths is nearly perfect match for holes in steel rim that I tried it on. BTW, one of the locals may have found an inexpensive source for high quality 35/64ths bits. I need to check it out.
#9 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 10 July 2006 - 04:48 PM
you gotta love standard sizes... wtf 35/64... why cant everything just be metric!! Oh well, 35/64 it is with a 3/4 countersink.
-Brian
#10 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 10 July 2006 - 04:56 PM
-Brian
Haven't seen too many metric bits around here. A 14mm is what you truly need. A 35/64th is just a few thousandths of an inch smaller than 14mm.
#11 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 10 July 2006 - 05:14 PM
Smaller? Then wouldnt I want to go with 9/16 which is near identical to 14mm?
-Brian
#12 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 10 July 2006 - 06:12 PM
the studs are 1/2". drill 9/16" then get a 3/4" 60* countersink.
#13 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 10 July 2006 - 07:14 PM
-Brian
35/64ths is more identical to 14mm than 9/16ths. :)
