Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Timing belt failure and head removal
#1
Posted 07 January 2007 - 12:45 PM
#2
Posted 08 January 2007 - 01:10 PM
#3
Posted 08 January 2007 - 01:19 PM
does it have the original headgaskets on it? if so then i'd probably plan on replacing both headgaskets if you're going that far anyway. make sure none of the tensioner pulleys are rough or noisy, they can cause the belts to fail.
#4
Posted 08 January 2007 - 01:32 PM
#5
Posted 08 January 2007 - 01:52 PM
Well since its been bought up, so am I
nipper
#6
Posted 08 January 2007 - 02:49 PM
valves in cyl 2 and 4 are closed and almost closed
thus the pressure diff.
the cam will tend to settle in this condition due to
the valve spring tension.
valves in 1 and 3 are bent or open
Just a WAG
#7
Posted 08 January 2007 - 04:28 PM
http://www.ultimates...85&postcount=31
#8
Posted 08 January 2007 - 06:59 PM
grossgary- I'm leaning toward pulling the engine and just doing the known problem areas for this engine.....both head gaskets, timing belt, water pump, oil pump o-ring, tesioner, any suspect pulleys, oil seals.....basically the works. It just seems like a lot of work for a couple of bent valves (probably).
I got the garage cleaned out yesterday so I can fit a car in there. Had my wife help me push the thing in backwards. I need to see if I can pick up an engine hoist tonight. One of the nice folding ones if the price is right. If not, I have a guy at work who will lend me his.
Should I just buy the whole engine overhaul gasket set? Will it have all the little o-rings for the oil pump and cam seals, etc? It's $183 and it sounds a little steep compared to the individual parts price. Head gaskets are only about $30 each...that leaves $123 left for o-rings and lip seals????? What about the oil separator plate? All I can find on GenuineSubaruParts.com is a "baffle plate". Is that the same thing? Are there other recommended places to get this stuff? Sorry about all the noob questions. I just don't want to get in the middle of the job and find out I'm missing a seal. Or worse, get finished and find out I should have changed "X" while I had the engine out. Thanks for your patience.
#9
Posted 08 January 2007 - 10:22 PM
Sorry about that guys.:-\ I should have explained the troubleshooting part a little more in this post to start with. The belt is not completely broken. I don't have it apart yet so I can't tell for sure, but I suspect I'm missing a few timing belt teeth. Why it didn't wreck both sides I don't know. I pulled one the passenger side timing belt cover back far enough to peek behind it and had my wife crank it over. The sprockets turn but I've got no compression on the passenger side cylinders.
I would get the whole set...I am currently assembling my 96 DOHC 2.5. Had head gasket problem.....My gasket set was 250.00....why is yours 183? (mine was mail order from genuine subaru parts.com)
I spent about 900 in parts...got all new pulleys which are not cheap (this drove up my costs) as well as tensioner, water pump, wires, you name it. Yes, for some reason they call it a baffle plate but the label on the bag calls it a separator plate. One weird thing about the new metal plate is that it is much thinner than the plastic one--but more importantly, the old one had chamfers at each bolt hole because the machine screws are flat heads (conical shape)....the new metal plate has NO chamfer. I did not realize this when I put anerobic sealant on it and slapped it on...i just used the chamfered flat head screws...seemed to tighten okay. But the anal person that I am went out this afternoon and bought plain hex head bolts with washers and replaced them. I did not see a gasket under the plastic plate and so I just used sealant under the new plate (anyone know if there is supposed to be one?)
#10
Posted 08 January 2007 - 10:31 PM
#11
Posted 09 January 2007 - 08:12 AM
I was thinking or replacing the crank sprocket as a minimum plus the tensioner and any other sprockets or pulleys that look or feel iffy. I picked up my folding 2T engine hoist from Pep Boys last night. $139 minus $20 rebate makes it $119 for the folding one (no sales tax). Made by Big Red. Probably a Big, Red piece of offshore crap but I only need to pull two engines with it at the present time. Hopefully, the count doesn't go up! Putting the Bronco and Saab 9KT back on the road today. Should be enough cars to get me past my repair job.
Thanks again guys. I'll be posting back on a regular basis asking stupid noob questions.
#12
Posted 10 January 2007 - 11:10 PM
Thanks for the replies. If you look up the gasket set today @ SubaruGenuineParts.com, the 96-98 2.5 DOHC Overhaul Gasket Set retails for $250 but their price is $183.
I was thinking or replacing the crank sprocket as a minimum plus the tensioner and any other sprockets or pulleys that look or feel iffy. I picked up my folding 2T engine hoist from Pep Boys last night. $139 minus $20 rebate makes it $119 for the folding one (no sales tax). Made by Big Red. Probably a Big, Red piece of offshore crap but I only need to pull two engines with it at the present time. Hopefully, the count doesn't go up! Putting the Bronco and Saab 9KT back on the road today. Should be enough cars to get me past my repair job.![]()
Thanks again guys. I'll be posting back on a regular basis asking stupid noob questions.The shoe is on the other foot for me as I'm usually answering Buick GN questions, not asking them.
Just looked it up and here is what is says:
OVERHAUL gasket set, All Models - 2.5L, 1996-98 - 2.5L, 1996-98 1996 $347.43$0.00$254.32Engine - Overhaul gasket set
#13
Posted 11 January 2007 - 08:18 AM
#14
Posted 12 January 2007 - 04:39 PM
#15
Posted 13 January 2007 - 01:05 AM
don't know how many miles are on your gt
just a thought
jake
#16
Posted 15 January 2007 - 10:35 AM
The bullet appeared to enter through the left shoulder and........OOPS! Wrong autopsy.......let's see ......it's here somewhere......Oh, here it is.....it looks like the lower left geared idler failed and the right (PS) cams jumped time. This allowed the piston too smack the exhaust valves on the right rear cylinder (I forget which number that is). Both valves are bent and won't close. It's like the story of the three bears:
Papa Bear said, "Someone's been changing my timing belt."
Mama Bear said, "Someone's been changing my timing belt."
Baby Bear said, "Someone's been changing my timing belt, and they used aftemarket parts, didn't change all the idlers, screwed up two of the cam sprockets and got debris in the engine and messed up one of the cam bearings and cam journals."
It appears this engine has been worked on before. Way too many of the bolts were WAAAAY too tight. The flange is damaged on the left side intake cam sprocket. Teeth are fine and it doesn't rub on that flange so I think this will be OK. Right side exhaust cam sprocket has damaged teeth from the previous "repair". Needs to be replaced. The geared idler on the lower left spit the bearing out and just about seized up. This is what caused the failure. The lower right idler appears to have been replaced during the last failure/repair. I suspect it caused the failure last time. The top right idler is very noisy. When removing the cams on the right head, we noticed bearing and cam journal damage on the center bearing of the intake cam. Looks like a piece of debris came up through the oil hole and got lodged between the bearing and the cam. The rest of the bearing and the journal looks OK. The engine must have pretty good oil pressure or this would be a lot worse. The two bent valves will need to be replaced. I will probably lap all of the valves while I've got the heads off. Since these are overhead cam engines, can the valve clearance be set on the bench? Is the "special tool" for pulling valve shims needed or is there another way to change them?
#17
Posted 15 January 2007 - 11:14 AM
#18
Posted 15 January 2007 - 11:30 AM
#19
Posted 09 March 2007 - 04:51 PM
The wheels of progress move slowly at my house. I got the engine all apart and took the heads in and had them do a valve job and replace the two bent valves. I bought two more exhaust valves because they looked like they hit the pistons also. It turns out they were not bent when they were checked by the machinist so they were reused. One head was OK but the other was not flat by 0.004 so it was shaved. All the valves were ground and the valve lash was set on the bench. After torqueing the heads in place I checked the valve lash again and found (3) out of spec. I was able to resolve one by swapping a shim from one of the other two that were also out of spec. This left me in need of two shims. My local feeble Subaru dealer said he doesn't have shims in the shop and that they have to order them when they do a valve adjustment. This sounds like total hooey to me but they have been so lame so far that it wouldn't surprise me. I went to work and got some brass shim stock and cut two pieces to fit between the factory shims and the bucket. Checked and double checked the valve lash and it was in spec. Replaced all suspect idlers (all except for one), new water pump, front and rear main oil seals, oil sep plate, tranny input seal, metal heater line, timing belt tensioner and pulley, cam sprocket, etc, etc, etc. Installed the engine and realized I had misplaced or thrown out the old fuel filter. Picked up a new one and cranked it over for a little while with the coil pack plug disconnected to get some oil in it. I tried to start it up. Car sputtered and then fired up. Then stalled. Repeat this a few times. The car throws a code. I remember that I didn't tighten the gas cap. I get the car started but it doesn't want to stay running. There is a clatter coming from the PS cam cover. When I assembled the heads I (and the machinist) used liberal amounts of assembly lube. About the consistency of frozen maple syrup. Is it possible that, due to the cold temps in my garage (around freezing), that the valve buckets could not follow the cam profile fast enough due to friction and allowed too much clearance between the valve shims and the cam lobe and now the shims fell out of the bucket? Also, is there an interlock for oil pressure in the fuel pump circuit that might be killing the engine?
#20
Posted 09 March 2007 - 04:59 PM
Update time:
No oilpressure switch interlock.
When it starts, how long does it run for, and is it a stumble run or a regular run.
That clatter .... which Timing belt idler did you not replace?
was the tensioner installed properly
Double check the timing, it can be off, as it happens to the best of us.
nipper
#21
check compression, spark and fuel and let us know.
#22
Posted 10 March 2007 - 08:42 AM
#23
Posted 16 March 2007 - 01:20 PM
I started over and measured all of the lashes again. Wierd. On one valve I measured the valve lash. Measured the shim, calculated the required thickness for the new shim, bought it, installed it........and got the same clearance as before. It doesn't make any sense. Now for the bombshell.......I took my digital caliper and measured my feeler gauges. Each feeler gauge was 1.5 to 2 thou thinner than what was labeled on the feeler gauge blade. All of them.... on both sets of feeler gauges I own. I checked a set of "three letters and starts with F" (it's brand name, not a slur) feeler gauges at work. They were also thinner than marked by 1 to 1.5 thou. I had our machinist double check my measurements. Same results. So, in short, I wouldn't get too anal about your valve clearance numbers. Check your feeler gauges before you use them. I expect a lot of people are using feeler gauges that aren't correct. Does anyone have an factual reason as to why the feelers were consistently thinner than marked? I put it back together using a feeler gauge 0.002 thicker than the required measurement. It sounds like I have one vlave that may be too big a clearance. It's a little noisy on cold start up. After it runs for 20-30 seconds it quiets down some and after the car is warm, it's quiet. Can't hear it at all. I'm going to run it for a month or two and then pull the cam covers again and re-check. Then I should be good to go until it get retired.
