'86 Brat EGR Light Reset Question
11 replies to this topic
#1 casm
casm
    The Timex of Lifters
  • 190 posts
  • Seattle, Washington
Posted 22 February 2009 - 11:41 AM
I just bought an '86 Brat in really nice shape to replace the '85 I had in CA before moving to VA. The EGR warning light on the '86 is on. According to p.249 of the up-to-1988 edition of HTKYSA, you can reset the light with the following procedure:
'85-'86 models: Remove the plastic panel on the lower left side of the dashboard. Remove the screws that attach the fuse box, then pull the fuse box away from the dash. Dig around amongst the wires behind and above the fuse box until you find a blue connector plugged into another connector. There should be a green connector nearby that's just like the blue one, except that it isn't connected to anything. Disconnect the blue connector and plug in the green one where you disconnected the blue one. Install the fuse box and plastic panel.
The procedure itself makes decent sense - but the part I'm not clear on is what happens after the blue connector is plugged into the green connector. Do I just leave them plugged together, or do I return the blue connector to the one it was originally plugged into?
Testing showed that the EGR valve is actually shot, and the new one should be here in the next day or two; it'd just be nice to know if after moving the connectors around the light is permanently disabled or not. If it's on a timer I don't really care if it's gone for good, but if it can actually detect an EGR fault I'd like to have it working at least while the new one is bedding in in case something goes haywire.
#2 Flowmastered87GL
Flowmastered87GL
    WCSS Drunk
  • 6,273 posts
  • Portland, Oregon
Posted 22 February 2009 - 01:31 PM
once you move them, just leave em that way til the light comes on again (if ever) then switch it back at that point.
I dont think that the light on these was ever actually tied to the valve... i have heard many times that it was just tied to the mileage.
#3 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,600 posts
  • Hillsdale, Mi. USA
Posted 22 February 2009 - 02:32 PM
Yeah, it's just a service reminder light. Once you switch the connectors, it'll be another 60K miles before it comes on again.
edit;
Oh, when you switch connectors, leave them that way until the next time the light comes on, then switch them again.
#4 casm
casm
  • 190 posts
Posted 22 February 2009 - 03:11 PM
Cool, thanks. Good to know. It didn't look like there was any way of monitoring whether the EGR valve was working or not, but I figured there might possibly be a vacuum check in there somewhere. Much appreciated!
#5 rsamsel
rsamsel
    New User
  • Pip
  • 6 posts
  • Renton
Posted 16 February 2012 - 04:24 PM
Fixed my '86 GL 4wd Hatch!
Thanks guys! Would have never found that myself!
#6 tackelbox
tackelbox
    New User
  • Pip
  • 3 posts
  • portland, OR
Posted 07 March 2012 - 12:49 PM
I had a question for you guys. I recently had a my EGR valve go out and i ordered a new one. I got the new one and it only has a spot for one vacuum line on the top of it but the one on the subaru has a 2 hoses, one on the top and a lager hose connected to the base of the EGR valve. Did I get the wrong one? I cant seem to find any valves online with 2 spots for hoses
#7 naru
naru
    1000+ Super USER!
  • 2,258 posts
  • under the bridge
Posted 07 March 2012 - 01:12 PM
http://www.ebay.com/...bb4415b&vxp=mtr
#8 tackelbox
tackelbox
    New User
  • Pip
  • 3 posts
  • portland, OR
Posted 07 March 2012 - 01:36 PM
damn thanks man! for some reason I couldnt find a part number. this is cheaper than the local auto store also
#9 naru
naru
    1000+ Super USER!
  • 2,258 posts
  • under the bridge
Posted 07 March 2012 - 01:47 PM
Try 14710AA590 at your local dealer.Go armed w/an online quote.Might be even cheaper.
Rockauto is $129.
#10 tackelbox
tackelbox
    New User
  • Pip
  • 3 posts
  • portland, OR
Posted 08 March 2012 - 12:17 PM
Awesome thanks. I'm new to subarus, my wife inherited this brat and it just needs a few things. Any one know where to get original interior parts? the dash is cut for a stereo and I want the original dash piece. They need like an LMC catalog for old subarus.
#11 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,690 posts
  • Portland
Posted 08 March 2012 - 12:42 PM
You can eliminate the valve that connects to that silly large pipe off the EGR - that's just an extreaneous bit that you don't need. It's the AAV (anti-afterburn valve) and it prevents fuel from being sucked into the engine through the idle circuit under closed throttle coasting.... it's probably shot by now anyway so you can just eliminate it. Use an EGR from a mid to late 90's EJ22 or EJ25. They have a smaller diaphram and fit easier.
#12 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 08 March 2012 - 01:40 PM
To bad the car still thinks theres a EGR in it.
My Brat's EGR light came on and all my stuff is removed.
Thought it was really weird until I saw the mileage......180K.
Thats when I knew I had to get under the dash and switch the plug.
