So, first order of business was to get an exhaust system installed, as the PO had cut the old system out, leaving only the open header pipes. Loud little sucker!
Supposedly the PO was planning to do some sort of dual exhaust and abandoned the project. Took it down and had a new system made up. Got a new Y pipe welded up to the stock header pipes and flanged right after the Y, so I would have a spot to break the system when I eventually will make new headers. Sorry the pic is kinda cr*ppy
Decided to run 2" pipe back to a Magnaflow SS muffler with dual outlets. From the muffler outlets, I ran dual 1 1/2" tailpipes. I am pretty pleased with the sound. It's a little on the loud side, but could easily tone it down if I wanted with some resonated tips or a resonator before the muffler. Definetely has a nice tone. Quite different than what I'm used to hearing WRX's sound like.
Now that I could run it without all the neighbors wanting to kill me, I could set off and see whats what. The PO told me it had an issue with hard starting and dying out so I figured I'd start there. Gave all the fluids a quick check and started her up. Basically figured out in short order the accelerator pump is not working at all. There is the hard starting problem and the dying issue also seems to be carb related. Basically it won't idle without the choke 2/3rd on. If you release the choke, it dies and is hard to restart due to no accelerator pump. So, I will start with a carb rebuild and see what happens. I just hope the PO did not try and do this and ended up botching it to the point I can't fix it. With a grasp on the dying issue, I figure it's time to take it for a spin. I found if I leave the choke on, it will stay running so away I go, or so I though. I slowly leave the driveway to head to the end of the street. When I get there and step on the brakes, I get a horrible pulsation/wobbling and noise from the brakes.
Ok, time to turn around and head back to the driveway and pull the wheels. I found out on the uturn that I will need to replace the outer CV's. Click city! Clutch is probably on it's last leg also. Anyhow, pull the front wheels first, as that is where I expect the problem to be. Get the wheels off and all looks OK. There is meat on the pads and the wheel bearings are tight. Since that looked OK, I started it up and slowly applied the brakes while running the car at 30mph (on the stands, with the opposite wheel blocked so only one side will rotate). Left side felt OK (rotor could stand replacing as it is scored a bit). Right side had a little vibration, but not so bad as to be the cause. I did check the runout and it seems that the hub has a bend in it. It has a replacement rotor on it so I wonder if it got bent during the install? Well, time to go to the rear. Pull the right rear and all's good there. Pull the left rear and look what I found,
When I pulled the drum, the lining came with it!
I am taking a shot in the dark that this may be an issue! Guess I'll be heading down to NAPA monday to order some new shoes. Once I get those on, (and the carb rebuilt)we'll try another road test and see what else will pop up. I also need to find some good temporary tires as the ones on there are checked pretty bad. I don't want to get new tires because the plan right now is to take the stock wheels to Stockton Wheel and have them widened to 6" so I can run 205/60-13 tires. I plan to powdercoat the wheels black and run the original hubcaps (rechromed, of course). Kinda an asian baby moon theme!
Probably will do a valve adjustment and compression check later this weekend just because. That's it for now.
Mark
