All Activity
- Past hour
Plain and simple, help me fix my ever lovable xt6
Coliseum replied to Coliseum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah I understand the back and forth version would be a project in of itself, i just like the idea of being able to enjoy my new Gen flat 6 without sacrificing my darling ER Anyways could you help me understand my powersteering situation a little better? Since its got the electric power steering, I dont see why i cant forgo the power steering pump on the EZ entirely, are the custom hoses for clearances purposes or? Also what's a pitch stop? Do EA transmissions fit up to the ER? I've seen conflicting things here Also you remind me, i don't know how or how to make my AC pump turn on, it hasn't bugged an inch nor have I been able to root around and find whether or not the thing is hooked up, -
This is my end goal, when I have more money then time and no limit to what im capable of - Today
On Gen II, inner and outer are the same seal.
Wheel seal driver
SuspiciousPizza replied to bushytails's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That inner seal is the one that gave me the most issues. Seemed like the smaller the diameter of the seal, the easier to install. Probably less resistance because of the smaller surface area contacting the bore. - Yesterday
el_freddo replied to Coliseum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I could be done if several components were adapted to work between the two engines. Wiring looms can be laid over each other and whichever one is needed is the one used. Realistically though, once you go for the larger power and more reliable engine you won’t look back. Tuck the original parts under the workbench all sealed up and labelled for a future resto - if it ever happens. That’s the plan for my brumby too - upgrade the drivetrain, everything factory that’s removed is kept for future resto options (that will no doubt never happen). -
Someone in another thread recently said they couldn't find the right driver for installing front wheel seals, so here's the random find I've been using for Gen II seals, a HyperTough 64P-14 oil filter socket, with the outside very slightly filed for a looser fit in the knuckle.
- Last week
There is no back-and-forth. The mods needed to fit a newer engine are extensive - you'd need to do a lot of work to make anything repeatedly swappable, and it'd still be a big project every time. For just a small part of the list, you can start with engine mounts, bellhousing adapter, modded flywheel, starter, fuel pump and plumbing, custom radiator hoses, custom power steering hoses, custom a/c hoses, engine computer and complete wiring harness, pitch stop, radiator fans, air intake, alternator wiring, vacuum hoses to body-mounted vacuum stuff, ignition coil stuff, etc etc etc... all of which you'd have to have two sets of and swap each time with the engine...
Ideally, id only be doing this for the ease of parts, if its possible I want to restore the engine and have the freedom to swap back and forth between my EZ and ER, thats a pet project for another post but for now, yes ill do all I can to keep the ER running. -
If it were me, I'd be collecting parts to keep the ER running before thinking about an engine swap. I know the oil pumps and water pumps are higher flow than the EA pumps. Parts is going to be the everlasting gobstopper, you've just got to be stubborn and eat the elephant one bite at a time. My EA82 is the exact same way, but mine is more of a loping "rap rap rap rap" that's a lower tone, not a "clack" nor a "tick". But my oil pump also leaks from the "freeze plugs". Once my engine is warm it's quiet as a field mouse. I run 5w30 in the winter and 10w30 in the summer. If you have the vision, keeping the ER27 would be the way to go. They're very uncommon and you'd be keeping a piece of Subaru history alive. I've never had the privilege of hearing, seeing, or putting a wrench to one but if they're anything like their 4-cylinder brother, then it'd be extremely adverse to dying so long as the fluids are maintained. Good luck the XT6 is up there as one of the weirdest Subarus. :]
Check your oil again after filling the fuel tank next time - unless you only do a partial fill, in which case I’d check after the second partial fill. My brumby likes a little oil top up after every second fill up. Leave it too long and it drops off the dip stick 😬 -
moosens replied to Coliseum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds like a fresh reseal of the oil pump will help the ticking. Get all settled for timing, front seals, and when you’ve got that pump resealed rev the piss out of it to get the oil to fill that last hydraulic lifter in the line. That’s the backyard method. It works. No need to be scared just watch the redline. Hold it pegged for a few seconds or more and it’ll quiet down. Use a nice light oil too like 5w30. I know some new lifters are still out there. I just sold some and have a few more I’m pretty sure, and I did see others selling them as well. But you’re not at that point. If you’re going to gather parts keep in mind you often get a factory Subaru part in an older Beck Arnley box for many bearings and such. Paraut and Atsugi are also helpful names you won’t go wrong with. They supplies Subaru with clutches and pumps. Enjoy it ! -
I have the original manuals 1-6 for the car, ill dig em out and get to book worming. Last time I read through them I wasnt granted much useful, hopefully I can make better use of em. And I checked my oil after the drive to school this morning, still good 👍🏽 Sparks are brand new, oil filter, and oil have less than a thouwow in miles, and the tick comes and goes as i drive, usually getting to be completely quiet once shes warm. -
I haven't worked on one of those engines (I'm more of a Gen II wagon fan), but those problems could just be it's time for routine maintenance... Change your spark plugs, wires, cap, and rotor, check for vacuum leaks (vacuum hoses, brake booster, stuck evap, intake gaskets, etc), clean throttle body, clean MAF sensor, check temperature sensor, clean idle air control valve, adjust idle throttle stop, change fuel filters, check fuel pressure under full load, etc. Some lifter tick is normal with that many miles - you can try various flushes and such, or just live with it. It sounds like this car is new to you, so keep a close eye on the oil level until you know just how fast it uses it - running it with no oil will make that engine swap suddenly a high priority. https://charm.li/ is good for quickly looking things up, https://project-car.net/technical-info/ has a pdf service manual, and you can google for other manuals... or ebay a full set. Will come in handy with the amount of work you plan on doing.
Good to know. I guess it goes to show that just reading through specs on the Internet isn't a substitute for checking things in person. Also turns out the Nissan Rogue struts are 49mm in diameter.
el_freddo started following Plain and simple, help me fix my ever lovable xt6
The tick isn’t anything detrimental - just lifter tick. Parts are basically unobtainiam for the XT6 other than those shared with the L series - and even these are starting to dry up. The H6 conversion would be sick. The wiring is the biggest part of the job. After that it’s driving it so you don’t kill the gearbox! That said, a mate of mine ran the 3L H6 in a gen2 Liberty with the same gearbox that’s in your XT6 - just a dual range version. The thing was mint offroad with the locking centre diff. Sadly he killed the diff one trip in the sand as it didn’t lock and he fried it. Enjoy the journey - collect parts when you can find them! The air bag setup you might need to go down the custom aftermarket route. I don’t have any leads on this sorry. -
Oh youre 100% correct, I intend to do all the side missions before I finish the game yeah? Perhaps I should've been more clear that thats a long term goal not intended to be done ASAP, but I still wanted yalls opinions on it. Regards to the engine, im not certain of the full extent of its issues but it has the tick, I need to locate and afford an oil pump seal so I can hopefully fix that issue, which hopefully you guys can educate me on as well. My main concern is that it will stall randomly upon pressing the clutch in, the engine power seems to wane randomly like the engine isn't firing properly or something, its not an issue per se but its coming up on 300,000 miles, I believe its burning a little oil? But its doing so at a snails pace and ive barely had to give it oil to keep it up after the first oil change. I want to change all my gaskets if I can but I cant seem to locate any gaskets for the engine, and I have trust issues with Ebay. -
I think you should start with simpler projects, like CVs, ball joints, and tie rod ends, before worrying about an engine swap. Until you're confident with routine maintenance like that, an engine swap isn't even something you can consider. Then worry about suspension mods and such until you're comfortable with fab work and re-engineering things. Then you can start researching engine swaps or other large projects. Is there even anything wrong with your current engine?
So, theres a lot of levels to this, being that i intend to make this car outlast me so ill try to keep this organized First and foremost, I both want and need to replace, revamp, or otherwise retrofit most of my undercarriage, while its served perfectly as my daily driver, I can feel and hear that my tie rods are bad, ball joints too I'm sure, my power steering works most of the time but id like to do whatever is best to get it at maximum capability again, idk what CV Axles or how to figure out certain part specifics like that so please explain it to me like I'm a child should you do so. I'd also like to swap it to coilovers for now, please drop me some specifics or what kinds of coilovers will fit exactly so i can start to search for them as ive been lost so far, eventually ill return it to functional air suspension and hopefully get it all working again so i can show off the height calibration stuff. Generally, I'd like to restore as much of this car to "original" as humanly possible. I, of course, want to customize it a small bit but I'd feel like im ruining the car if i start trying to turbo things and stance it so im hoping to keep it tame, focus on function as much as i can, but i cant rely on the ER27 for as long as Id like to keep the car, if yall think its possible for me to revive the ER27, id love that, the engine has a classic charm and rumble to it i wont get out of my next ask for advice Which brings me to my main point and the full extent of my intentions for the car I love the flat 6 engines, the EG33 isn't as easy to obtain, but the EZ30-36 are common enough and powerful enough that I can reasonably obtain one and a donor subie for 3-800 dollars(if yall are fckin with this idea, should I get the 03 or 05 3.0, is One better?) My hope and plan is to lift the ER27 out, replace it with an ez30 and hopefully keep the oem 5 speed, i understand the saying is easier than doing, im trying to establish a baseline and a timeline so I can put my dream car back together. Truly any advice, anything yall know, and any parts you could offer me would do me a world of good. Anything common with the car that could help me would a miracle as well because finding people nowadays who even know what the car is in my area leaves me finding a better time looking for actual unicorn cars on Facebook marketplace. Many thanks and have a good one. Edit: today I remembered to ask you all about my backfiring and further about my electrical issues, is this car common for bad grounds? Why might it be backfiring or making that loud pop and bang before idling well again, to be clear it usually does this while starting for the first time, often getting one bang or two off and then being okay.
They just don’t kit like they used to. I’m unaware of kits but maybe I haven’t looked hard enough. You could ask for the urethane in black. I did that for my 70s wagons. If it’s handy can you please post that list? Or send it to me, please. We have a small fleet of those third gen Legacys and one Outback wagon.
Those Hyundais have an upper control arm. The shock is not designed to support lateral loads.
I've never needed more than a good hammer on a Subaru. My 8lb mini-maul usually pops it off in one hit. loosen, but do not remove, the bolt. And smack the end of the knuckle where the tie rod goes through it (not the tie rod itself). I rented a tool similar to the one linked for my Suburban, but the hammer-smack still did the brunt of the work.
