All Activity
This stream auto-updates
  1. Today
  2. I own multiple classics and rarely install extra gauges in any of them. I'll confirm the OEM gauges are operating normally and leave it at that. The KISS principle makes life much easier for me. I don't need to know the exact numbers, only that I'm in a normal range. Engine temperature is all I really monitor closely since I drive my wagon through the Phoenix summers with A/C always cranked to the max. I know from using an infrared gun that 3/4 needle sweep is normal in the summer and about 206F measured at the thermostat housing. In winter, the needle reads about half way and equates to around 190F. For oil pressure, I installed a temporary T with a mechanical gauge at the filter and after a good hot freeway trip with the engine at idle, I still have good pressure. When you have good oil pressure at hot idle, you will always have good oil pressure at any other engine temperature or RPM. Since I have an idiot light for oil pressure, I make sure the bulb is working as I start it each day. If I let the clutch out a little fast and almost kill the engine, I'll see the oil light flicker when the RPM's drop below spec. That's another confirmation that the oil pressure switch is working fine. For fuel pressure, I only check that if I install a new pump. Again, I have installed a temporary port under the hood and confirmed pressure is in spec. After that, I remove the gauge and forget about it.
  3. Yesterday
  4. I wouldn't mind the stock gauges, but they are so vague. My GL has the fancy gauge cluster with voltage, oil pressure, and temp. But I'd like actual values rather than relying on a 35 y/o gauge without values. I actually don't know if my oil pressure gauge works. The P/O had a mechanical gauge installed where the dash clock was and this leaked oil all over the dash wiring harness and he cut into the defrost vent to get the gauge to fit. That really didn't help on a Wisconsin winter morning. I just like numbers for monitoring and diagnostic. :] If I had to choose one gauge to not get, it'd be the fuel pressure.
  5. I'll agree that extra data is fun to work with but constantly monitoring your fuel and coolant pressure in an EA82? I have the ultra basic (no tach) factory instrument package in my 87 DL 5-speed. The coolant temp gauge and the oil pressure idiot light are enough for me and got this wagon to 255K miles so far. Sometimes less is best for simplicity sake.
  6. ISSPRO has them. I'd go all ISSPRO since they're good quality and come with sensors and harnesses. But they cost a pretty penny, thus this discussion before I spend that chunk of change. Plus you can program in custom warning lights and change the backlight colors. :]
  7. I Tee’d my mechanical coolant temp gauge into the heater hose on the outlet from engine hose. Works a treat. Personally I wouldn’t like to Tee into the factory location, moving both sensors away from the direct flow of the coolant wouldn’t be an accurate reading. I’ve not seen a coolant pressure sensor as a standalone aftermarket gauge, but I’m not looking for one either. Many ppl feel comfortable with electric sensors and gauges over the older mechanical equivalents. I’d buy from a reputable brand that you can get some after sale service with if it’s ever needed. Cheers Bennie
  8. So if i disconnect my pc from the internet and change the date will it work?
  9. you need a computer that has never been on the internet since greenspeed
  10. Last week
  11. I'd like to install some electronic aftermarket gauges on my dash to display more data and keep tabs on the health on my EA82. Electric gauges since I wouldn't have to run fluid lines into the cabin. Though I prefer the simplicity and cost of mechanical gauges. The gauges I'd like to install are oil pressure, coolant temp, fuel pressure, and coolant pressure. The reason for the coolant pressure is that I'd, in theory, be able to see if my coolant pressure is spiking/ rising and thus detect head gasket leaks into the cooling system. Also monitor the water pump performance. For my coolant temp, I'd thought of installing a T-fitting to where the stock coolant temp sensor sits, allowing me to keep the stock one and add on the additional sensor. Will this affect my temp readings? Would this cause turbulence in the cooling system? Would air cooling the fitting throw off my readings? Would my readings be affected by the sensor being repositioned in relation to coolant flow? I've never messed with aftermarket electric gauges before and I'm open to thoughts and opinions before I go and spend the money on the gauges and sensors. Thanks :]
  12. Makes sense. Thanks for the explanation of cylinder washing. I wouldn’t think you’d lose that much compression though unless rings are super shot already. But I could be wrong on that too. I too said it was unlikely all four cylinders would have a stuck valve. This one seems almost the same as removing the spark plugs and cranking. Cheers Bennie
  13. since it pumps back up, I figured it isn't a cracked lever. The problem seems more hydraulic in nature?
  14. I'm the one who suggested that the cylinders were washed. lol. The piston rings seal with a very thin coat of oil on the cylinder wall. If you ever get fuel without starting, like trying to get a bunch of old gas and a dirty carb to run, the fuel washes this thin oil coat off the cylinder walls, and you lose compression. Fixing the problem that caused it not to start (i.e. flushing bad fuel, and dismantling and cleaning a gummed up carb), and starting it, will get oil slung back onto the cylinder walls, restoring the ring seal, and restoring compression. Sticky valves or such aren't going to happen simultaneously to all four cylinders from a running engine... Mechanical things that could affect all cylinders at once are a broken crank, broken cam (I saw this once! ... but there was a lot more broken too), broken timing gears, slipping ring gear (so you're not actually cranking the engine), etc... But if the accessories and dist are turning, those are all going to be fine. Broken cam or timing gears also cause a distinctly different sound, since some cylinders will be stuck with both valves closed, and compress each revolution - the sound of an EJ ready for a timing belt and half the valves replaced.... Am I positive I'm right? Of course not. They could have blown both headgaskets at once, or some other simultaneous multiple failure. Or the engine is total crap and never actually had any approximation of full compression but was limping along. But, based on my experience, I think it's the most likely diagnosis, which is why I said "probably".
  15. whats the chances that you might feel generous enough to send me a link to the 11-14 wrx version? and maybe im really lucky and timmy1236 feels like explaining his work around for the serial lock issue?? any help is greatly appreciated guys!!
  16. Other things to check in addition to whats mentioned above... Check the pedal assembly under the dash. Those years can get cracks in the pedal bracket. Remove and check the pivot pin itself for wear. I've long since replaced mine with a hardened bolt, washers and locknut. Is 2006 the a push clutch? The stamped fork tends to crack overtime. Hard to check though. Pull clutch uses forged fork and has no issues.
  17. Alternator changed Friday evening and had a muffler put on by a local mom-n-pop shop this morning. Next on the list is a water pump. I noticed my belt was fraying after that quick drive up the road last week. I am confident I've got the water pump for non-AC GLs and it's slightly out of alignment.
  18. Master cylinder is becoming gummy. It could be worth flushing the clutch hydraulic system. At worst you might need to replace the master cylinder. Or have the whole system overhauled. Also, the clutch pedal when it goes to the floor will not naturally return, at least in my Gen 1 RS Liberty it doesn’t.
  19. A complete loss of compression suggests it’s mechanical. It would be odd for all cylinders to lose compression, yes, but stranger things happen though. Someone even suggested that the cylinder walls were washed and will come good. I don’t know what that means exactly though - but it is something mechanical that’s the issue. I’d be flushing out the old fuel rather than having the engine eat it. I’d put the highest octane fuel you can get and run that for several tanks, then return to your regular fuel octane rating you use. Cheers
  20. The weather was finally somwhat bearable (if humid as hell for my tastes), my leg is 99% healed, and I had a day off to play with, so I started poking at the rear suspension again. Pulled the subframe apart and separated the sheet metal piece from the diff, and removed the knuckle assemblies including the CV's and lateral arms. Also I think i made my first obnoxious mistake. Nothing too unrecoverable but still... annoying. Made a couple of test fits and chalk marks with the whole assembly to get an idea of what I thought I'd be wanting to chop. Actually chopping was the mistake (sort of) - but I'll detail that shortly. The diagonal marks indicate roughly where the frame ends on the brat where I need the subframe to sit. Did another test fit with just the diff and subframe, determined it would be easier to fit where I needed it to if I just cut it straight where the stock bushings ended. The intent here was (and I guess still is) to re-fabricate mounting points to the frame with new bushing locations to fit in the smaller chassis. Got everything tucked up in and sort of leaned in place where I think It will go. The diff is bolted to the subframe, and then also mounted to the original Brat front diff crossmember. Fits pretty close to where it needs to be - only thing now is that it looks as if there's about 1.5 - 2 inches of height I'll need to make up to keep everything sitting level. It was at this point where looking back I think I maybe made a bit of a mistake cutting off the bushings. Funny thing is - mere minutes after completing all the test fitting and cutting today, a friend sent me a youtube video from a guy doing a similar subframe swap in on a later gen brat where he just...*widened the frame and used the stock bushings.* Shocker, this would have been a much simpler approach and I think there would still be enough clearance for me to narrow the links and CVs to tuck everything back in under the stock wheel wells. Granted, the gentleman in question had to refabricate his whole rear frame, and appeared to be planning on adding a widebody kit setup though so maybe he didn't need to be so concerned about the wheelbase width in the back. Lack of access to the "frame" from a different perspective was also a reason for me not thinking of this - I'm still using the bed as a demi-storage locker and haven't cut the bed floor or wheel wells out yet. Might change that and get the ol' death wheel out for the bed soon to, but that metal is in pretty good shape and I'd rather not cut into it if I don't have to. I'm deciding to look at the silver linings here - It's probably for the best I'm still going my own way of it - I'm definitely maximizing the room i have available to move the wheels inboard for a more stock look. I'm thinking I might be able to get clever and integrate the original moustache bar mounts or something... We'll see - I have to sleep on it. Absolute worst case I go to the junkyard and try to source another rear subframe and then widen the frame rails similarly to the other builder. A quick Google looks like one can be had for about $150 used. Maybe less if I find a pick and pull with one nearby or get lucky on marketplace. Mounting problems aside - having put everything roughly where I want it and looking at the bare underside of the subframe itself I think I'm going to have to take a slightly different track and shorten both the CV as well as the lateral links - chopping up the subframe more than I already have is going to prove much more complex than I initially assumed. I'd wanted to try to save on parts money and maintain stock impreza parts wherever possible, but in this case I think it will end up becoming much more expensive in terms of my time to relocate the pivot points instead of just changing to an adjustable link setup (It looks like I can get some of those for my GC model year for about $200.) Hopefully adjustable links will be adjustable enough to where I don't need to modify those to shorten them sufficiently. Anyways, looks a lot like it did when I started today but now I have more information to play with. Ever onward!
  21. Long time no write... After retirement, I rarely drive my wagon, after it sits for a while, I find the clutch pedal does not return after pressing. I CAN lift it and pump it enough to shift, then, after driving for a while, it starts behaving mostly normally. Anyone experience this? clutch master or slave cylinder????
  22. I doubt it's anything actually mechanical, just because it's all cylinders at once.
  23. Worst case scenario your valves are stuck open from some gummy crap. You should be able to pull them closed again with the rocker covers removed. If it happens again afterwards, I’d be looking at spraying some sort of solvent or fresh fuel down the intake while cranking to hopefully clean up the gum that’s holding them open. Cheers Bennie
  24. If you wanted to test the pump you could re-route the fuel lines so the pump is sucking from a Jerrycan and the return line is sent back to another container to push out any other crap that’s still in the fuel system. Just remember that the jerrycan will empty pretty quickly! Cheers Bennie
  25. Thanks for your help and wisdom! Yeah, from what I read online, my next step should be to drop the gas tank and clean out the 16-year-old gas and varnish, which I have been dreading doing, but it's gotta be done. Once I do that, I have an extra pump lying around that I was saving for my wagon, I'll swap it in and see if I can start it up! From what I can tell the two pumps seem to be the same.
  26. If everything is turning, you probably just washed the cylinder walls, and it'll sound normal again after you fix the fuel problems and get it running for a bit.
  1. Load more activity
