All Activity
- Today
I haven't posted here for years, partly due to login issues. @Turbone fixed those for me recently (thank you!). All the Subarus I had before have moved along, but I have more than ever before - 2006 Outback Wagon, 2004 Legacy Wagon, and the newest arrival is a 1994 Loyale AT my son just bought. The engine is suspect from a large oil leak that resulted in the engine's being run low on oil. We'll see about the leak and then if the noises clear up. His goal is to put a dual range MT in is but we'll see how easy that is to find...
GL/Loyale Broken Power Locks
SuspiciousPizza replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It was a terminal connection issue coming from the driver's door to the dash harness. The hatch still only works as manual. That's less annoying than manually locking and unlocking doors from the inside so I'll leave it for now. That breaking noise I heard I believe was a locking rod disconnecting from its socket. One on the driver side was only semi-connected. -
el_freddo started following Name That Noise - 1998 Subaru Forester 5-speed
That’s an interesting one! A chipped tooth will make a rotational clicking noise that’s speed related and only when in the chipped gear. That noise sounds like something is grinding - and interesting that it’s only in one gear. Other thought is that it’s multiple teeth that are damaged - unlikely though as the gear would most likely strip as a result, but anything is possible. Hopefully it’s something simple.
- 1 reply
- 1
- Yesterday
TMFS joined the community
Oddly I didn't get one tiny particle to come out by doing that. Interesting suggestion, doesn't seem like enough power but I'll be taking it apart again - ordered a $80 ebay exhaust manifold (if you've seen the 05+ manifold pretzels that's a crazy cheap price) to have some options. I'm wondering if the clog is in the header (i think it houses the catalysts), the mid pipe, or the mufflers or more than one. Hesitates around 5,000+ RPM's/flooring it (which is sometimes helpful on a steep mountain grade but others unecessary - but makes me thinking something is still clogged. Otherwise it drives totally normal. I wore ear protection but should call and apologize to the neighbor - her horses went tearing off towards her house.
Chrishgr6 joined the community
Justyntime joined the community
wrenchlife89 joined the community
Zezyzer joined the community
wtdash started following Name That Noise - 1998 Subaru Forester 5-speed
I had to unjam the cassette ejection mechanism last night. After I plugged the cassette player back in, the rear wiper switch illuminated for the first time in my ownership. There's some weird electrical gremlins going on here. So maybe the door lock issue is some sort of electrical issue. I'll break out the FSM and multimeter this weekend and check out what's going on. Oh I wish it's actually a mechanical issue, those make so much more sense than those invisible electrons. -
I want the wiper arms! Front struts any good?? Ed egowing@tds.net
I think you’d also need the sundials to run the correct oil seal on the shaft. Male CV shafts require a larger seal, the male stub axles need a smaller diametre seal. Bit of a stuff around but worth the effort to work with what you have. I’m unsure if the auto box’s sundials will fit the manual, I’ve not tried that. The early phase 2 gearbox with stub axles and all phase 1 gearboxes’ sundials will fit your later phase 2 gearbox that takes the male CV shaft setup.
A 2-headlight GL? That's a new one for me! It's a tilt wheel difference... The correct switch is on the left side of the column, and has a maybe 9" long wire pigtail with a pink 6-pin connector on the end. The one with no pigtail, from non-tilt columns, or with a black connector, from other vehicles, won't fit. Ask me how I know. lol Thanks again!
bushytails, mine is a GL as well, so I don't think compatibility should be an issue.
- Last week
Oh wow my good sir, wasn't considering the exhaust at all. That would be awesome. Aye aye captain - I rammed one out of an XT6 20+ years ago. It's not drivable enough to accrue miles and calculate gas mileage. Yeah this is a new sensor but it's the style that comes with bare leads you splice the old connector onto - and I do'nt trust that it's wired properly. I'll check those.
I once had the same symptoms from a bad airflow sensor, and another time it was the pedal position sensor. There are lots of possibilities for those symptoms. It will run without the O2 sensor, but it does so in limp home mode which would be as you describe - I would start with a new O2 sensor. Rock Auto sells Denso Front O2 Sensor which is GTG. How is fuel mileage? If the A/F ratio is off the mileage will suffer.
