All Activity
- Today
I am looking for a standard 5 speed transmission for a 2007 Outback basic. It has a sticker that says TY757VCDBA. Mine is showing metal, noisy and is hard to shift into gear. I changed the fluid. It has new throw out bearing, master and slave. When in gear you can still move the shifter back and forth like it’s in neutral. Can I rebuild this and if so any hints on where to find the parts? Any information is appreciated thanks!
Only cover half the grille. That’s what I do in winter - but I do it over half the radiator behind the grille on my EA81 brumby to help it get to operating temp quicker and hold it there during our winter weather. It’s only a piece of cardboard so it’s easy to remove when needed if there’s a warm day. Sometimes I run to work with the cardboard in place, then in the arvo I need to remove it otherwise the engine runs on the hot side enough to trigger the thermo fans.
I've been digging through shocks in hopes of finding something that could work to replace the obsolete shocks on the front of our EA82 cars. If turned up a few promising options and I'm hoping someone more knowledgeable than me can take a gander and either tell me I'm stupid or confirm that these shocks will work. First up, for stock or possibly lifted rigs, the front struts from a 2014 Nissan Rogue seem to be a good candidate. KYB part # 3340158. As best as I can tell, they've got a 46mm where they clamp to the knuckle which might be close enough to work. The extended length is 18.92in, compressed is 12.32, for a travel of 6.6in. Really hoping this one is a viable option. https://www.shockwarehouse.com/products/kyb-3340158-front-right-excel-g-gas-strut-nissan-rogue-awd-rogue-sport-all Next option that seems like it would work for a lowered car is a front strut for a 2000-2005 Hyundai Sonata. Monroe part # Monroe 71417. It's a 45mm strut body with an extended length of 16.75in, compressed length of 12in, and 4.75in of travel. https://www.shockwarehouse.com/products/monroe-71417-front-oespectrum-strut-hyundai-sonata-kia-magentis-optima
- Yesterday
No argument here, just asking the question. And important to note that this is the 3 litre H6, not just another 2.5 . If you haven't driven one, then you're going to have to trust me that regardless of whether it's interference or not, this motor kicks the 2.5's @$$ in a way I didn't expect (and we've owned more than half a dozen EJ25s (AT and MT, all NA of course, no turbos) in addition to a couple of EJ22s). When it's all loaded up, towing a boat, and climbing a hill, it has the juice where the 2.5 struggled.
Crank No Start
SuspiciousPizza replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I thought I'd update on the coolant pressure performance. It's on the brain now that my radiator started leaking. Turns out Subaru still sells radiators for my GL. How grateful I am for that. From a cold start by the time the RPM's have fully dropped it'll be steady around 10-12 PSI. When driving it'll fluctuate anywhere between 4-12 PSI. I think I should have tapped into the thermostat rather than the heater core inlet, that way I could see if the thermostat has opened or closed. There is a correlation between RPM and pressure, however the temperature of the engine does play a factor. I'm not informed enough to say how much is head pressure and how much is the pressure buildup from heat, but it's cool to see them all interact by watching the gauges. I live in an area with lots of rolling hills and vastly different temperatures between summer and winter. I actually have to keep the revs above 3k in order to keep the engine warm enough in winter. I don't cover my grille, I've found that prolonged highway driving with it covered can cause the engine to get a bit too toasty for my liking. About 1/2 way up on the temperature gauge. -
This is the one - worked a treat, fit perfectly, without having to unnecessarily dismantle stuff that's just fine where it is. I found it locally at Canadian Tire as OEM Tools 77515. It's also on amazon.com as 37308 and 26553, and god only knows where else by what other number(s). OEM Tools doesn't appear to be a "real company" - that is, they just link to their amazon store. So without an actual catalog or data sheets where I might confirm dimensions, I can only say that I think that these are all the same tool rather than, say, different versions (e.g. sizes) of the same style of tool. What-ever, it works and I like it. And I see that amazon.ca has a $45 five-piece kit in a case that includes this puller. I paid almost that at CT for this one, so it is left as an exercise to the reader what my plan is now.
They're a solid platform. Interference engine so I'd immediately be installing all new Subaru or Aisin timing belt, tensionser, pulleys, and water pump if it's in good enough condition to warrant that. You don't really want a 25 year old lower cogged idler - they are by far the most failure prone item on there. If minimalist is preferred: replace the timing belt and lower cogged idler - those are the two parts most likely to fail. The others don't fail often anyway and often times give you warnings the others don't. After market belts and pulleys aren't as good, I've seen the pulleys fail and the included tensioner bolts shear. While you're in there it's not a bad idea to reseal the oil pump (anaerobic sealant, one o-ring, and the crank seal) and tighten the backing plate screws - more than one are always loose.
- Last week
Forgive any errors here, because I'm working from memory. So I'm now unbolting the caliper in order to take the rotor off in order to get at those dust shield screws. And I think that there's an opening in the shield that will then allow me to slide it off (and not unstake the hub nut and pull the hub) - but that's the part I can't remember for sure. Regardless, that's a lot of stuff that's working just fine and doesn't need to be disturbed in the interest of simply getting a puller around that tie rod end. Not a lot of work by any means, but completely unnecessary. I just got the two pullers that Princess has, and neither fits.
I rented (for free) this tool from autozone last summer and it worked well. I replaced both the ball joints and tie rod ends, and I'm pretty sure it was the tie rod ends I was having trouble with (hammer not big enough?), so I went out and rented this as well as a pickle fork that I didn't end up using. https://www.autozone.com/p/oemtools-ball-joint-separator-57308/787834
