wrongturninwv
Everything posted by wrongturninwv
Went outside and it started right up again. All the might be this and could be that will make me replace all kinds of parts. We know now the battery is not the problem, its new its tight and the cables are clean. It is 3/4 full of gas and if it was not getting gas it would not start.So fuel pump must be good. We are getting spark now but not eariler this afternoon. Put brand new plugs in today as I said eariler. Coil pack must be good or it would not run. Ignitor module must be good too then right. No code or check engine light and never was. I'm lost here.The Subaru dealer will take my next 3 SS checks if I take this one in to the shop. What do I do besides push it over the hill.
First time for this. Ive had dozens of Subarus and when nothing else would start on the coldest days out here a Subaru always would. Its a 95 Subaru Impreza 1.8, 5 speed, fuel injected,4x4. Never had any problems,ran great. Left sit about 3 weeks and now will not start. Full tank of gas,new battery. Turns over like crazy but either no spark or fuel is my guess. This is the first fuel injected so I need a bit of help.So what should I check first and how do I go about it ??? What kind of testers do I need ???
95 Impreza 2dr coupe. Left brake light is dimmer than right. I changed all bulbs and replaced with new ones. Checked wires for bare spots and found none. Bulb sockets are clean inside. I do have a good ground. Right side brake and trunk lid break working fine. Also found when I push down on the brake that you cant see clock light on radio till you let off of it. I unpluged all 3 lights to left side and clock light stays on when brake is pushed down and works fine. What could the problem be. All other lights on car working fine.
I thought with the car being over 10 years old and with 15000 miles on it it would need new springs by now. When I had struts replaced on the wifes Outback I was told by the shop that did the work that you should replace springs when you have new struts put on. Is that just a sales pitch or do I just replace struts ? Car is bottoming out on bumps now with no load in back. How many years can you get out of the springs before replacing ??? thanks
Time to replace rear struts on my 95 Impreza 2 dr coupe. I have the new springs I ordered from Subaru so now I have to buy some struts. Need you guys to let me know which one gives the better ride, the KYB non ajustable or the Monroe Sensa-Track. Maby one of you even have a new pair for sale. Let me know what you think. Thanks wrongturninswv@wmconnect.com
Try your pets favorite toy and an open passengers side window at about 40 mph. Smell and pet will be gone forever. No really I love dogs.We have 6 Dobermans and run back and forth to the vet alot. Cant take em all at one time cause they would kill eachother over jealousy. Hard to keep the smell gone. I think its the hair left behind from the dog on your seats. I cover mine with a old blanket and pull it out after the ride. Havent found anything that keeps the smell gone forever.
Wife has 96 Outback with those plastic headlights. Every year they get worse in the winter from the salt. I tried rubbing coumpond and scratchout and good old soap and water and soon as it dries its back. They want way too much for bran new ones cause they are all one piece. Anybody know what might clean them up ??? wrongturninswv@wmconnect.com
Thanks guys, I will go with the Subaru parts. Belt,new seals and all. I only want to do the job 1 time. Too cold out to have to do it all over again. Then I should be good for another 155,000 miles. Also read post by rainbow123: Any timing belt difference between CA and non CA timing belt. My dealer could not tell me the difference in the two belts. You learn something new each day.
Need to replace belt soon and called a few places for price of belt. About $50.00 from Napa ,$27.99 from Autozone, and Advance has a whole range of prices on the same belt.What is the difference in who you buy the belt from ? Can you tell me what you think ? Is one brand better than the other ? Thanks
Need to drain and change mine on a 95 Impreza 1.8 but can not find drain plugs for block. Is it ok just to warm car up with heater on till temp goes up turn off and wait a few min then pull bottom hose and drain from there ??? And it gets pretty cold up here so how much Presstone would I use To be safe ??? Thanks
Had to change mine a week ago. Blower fan would only work on high and no air would blow through any vents. Took glove box apart to get to blower motor and found a mouse had made his home in there. He put all he could find in cage of blower motor and thats why no air came out. Any how thats where I found the relay mounted in a small metal box held by 2 phillps screws in the black cover for your heater core. One plug goes to it with I think 3 wires. Go to the junk yard and pull one.Subaru dealer wants an arm and both legs for one. Good luck
