9
apparently there are 2 holes for locking the "flywheel / torque converter. there is the access hole on top for removing and installing the bolts holding the TC to the flex plate and then there is a smaller "bolt" hole half way down on the engine bell housing which can only be used for locking the crank to keep it from turning during tightening. i have never used the smaller "bolt" hole. it sounds a little scary, what if a tooth broke off the TC? but others have used it with out issue and recommend it as a good method to keep the crank from turning. comments?
more specifically, any auto trans from a 2.5L car, (outback, GT LSi, whatever) 96 - 98 will bolt in and plug in and work just fine. the final drive will match and it will run great. the only issue will be the speedo, if the stock tires of the donor car are different form the stock tires of your car then the speedo will be a little off. but the trans will run great. you can also use any 95 - 98 auto trans from a 2.2L car as long as you get the matching rear diff. some, a very few, 99 outbacks will also work and match the final drive, but at some point in 99 the outback went to the phase 2 trans and the wiring harness changed as well as the trans code number. making it work is a challenge, if not impossible. when comparing trans code numbers, any trans that starts with TZ102Z2.... (the last 3 characters do not matter, they refer to the model the trans was in) will work, the second 2 after the second Z is the final drive identifier. 2.2L cars have a letter in that position.
the shaft on the torque converter, the large tube, is supposed to be longer. there is another piece to it that is supposed to be connected with a spring clip. ( the large shaft assembly actually turns the oil pump. the long thin shaft is the input for the trans. ) the only time i took one apart, the TC came out with both a longer oil pump shaft and the thinner input shaft still attached. so no, you did not break anything by wiggling the thinner shaft. but you may need to remove the second piece of the oil pump shaft and re-attach it to the TC with the spring clip. there was a recent thread about how to remove it by grossgary, i think.
there is a split ring seal , cleat or almost clear, i think, that rides on the large torque converter shaft. because it is not an actual ring, it has a split in it, it could have fallen off, or just be old. coolant yes, you have to drain that. you might consider catching it and then filtering it and re-using. hate to waste all of it. you probably will not catch all of it but some is better than none. i don't think you have to drain any engine oil or trans fluid.
i'm not sure 04 struts will fit. at some point they changed the top mount design, i'm not sure when. but outback struts 96 - 98 will bolt right on and then you can run outback wheels with 205/70/15 tires. EDIT: your speedo will be slightly off, less power and maybe better fuel economy, assuming you can accurately figure out how many miles you have driven.
i've never done it but from what i here, it is harder to swap the oil pump than the front diff. so in theory you could put your front diff on the 95 trans and use your original TC. but if you are buying, why not buy the right one, not one you have to re-work. did you look here: http://www.car-part.com ? sort your search by distance. you will have to do separate searches one for for each , 96, 97-98 and if you look at foresters that will be separate yet again. but you will lots to look for. you might be able to find a wreck near you on craigslist for a few hundred.
the torque converter matches rthe flex plate so if you swap one you have to swap the other. but more to the point, the 98 outback has a different final drive ratio, 4.44 than the 95 outback, 4.11. so if you use the 95 trans you will also need the rear diff. you can use the original torque converter and the 4.11 rear diff w/ the 95 trans and you will be good to go. you will have better fuel economy and a little less "power" due to the different final drive. all in all, it would easier to get the right trans, but compare the price. you want an auto trans from any 2.5L car 96 - 98, outback is your first choice but GT or LSi or even a forester will work.
generally speaking the subaru 4eat auto trans is pretty hardy. but any used part is a risk. what is wrong with your trans.?? search this site , http://www.car-part.com , sort by distance. i'm not very familiar with impreza 1.8L trans, but they are very much like the legacy trans. that means any auto trans from a 90 - 97? impreza as long asit has the same final drive ratio which you can find at http://opposedforces.com/parts . the soft wear at the parts site may say that there is a difference between some years, but as long as the final drives are the same it will work. for that matter, a legacy trans will work as long as the the final drive matches.
it would be way easier if you swapped in a 95 - 99 ej22. but you might make it work if you swap over the intake, assuming it fits. BUT the lack of an EGR will throw a code and that might keep you from passing a safety inspection. the 95 - 96 from an auto trans car will have the egr, 97-99 almost any ej22 will have the egr (a very, very few did not). i would get a stethoscope from the parts store to try and locate the noise. it might be the tensioner on the t-belt. they can make a racket under load, i hear. and a t-belt job would give you another 100k assuming the bearings and rods are ok. but even if the engine failed soon thereafter you could still use the parts on the next engine. ps : if the belt fails you will have bent valves.
i rdeplaced a speedo needle needle on a 97 outback. i set it to 0 mph with the car off. when i powered up the car, it jumped to 20 mph. so i pulled it off again and reset it while going 65 mph per my gps. it works pretty good , it reads 1.5 mph too slow, not bad fir a do it yourselfer. if i were you i would fill up the car to the max, pul the needle, and with the car turned on reset the needle to fulll. let me know what happens.
someone posted recently that alignment are not rocket science. with a measuring tape you can reposition the new tie rod end close enough to avoid an alignment. maybe put some tape on the tie rod about 12" fromr the knuckle, measure across and place a mark at 12, and another at 12.5 just in case you were not perfect with the first one. thread of the old thread on the new and get the measurement right. milimeters may be more acurate but regardless set it up the way it was before you removed it. my hammer method is different and probably more dangerous. i was told to whack the side of the knuckle where the tie rod mates and the end will pop right out. i'm sure there is a down side to this method, but so far it has worked for me without issue. what i do not like about whacking the bolt with the nut protecting the threads is that the castle nut does not have the same integrity as a solid nut. if the whacks are not square you can booger the castle nut and then the tire rod end. of course, like the pickle fork method, it does not matter if you are throwing the tie rods end away. but if you are going to re-install it you will want good threads.
if it hasn't overheated and the price quoted is good, i'd probably repair what you have. buying a used ej25 even if it is in the outback and you get the whole thing for 500$ is a crap shoot. regardless of what the seller says, you do not know what damage may have occurred because of the bad HGs and / or overheating. so if you replace go with a ej22, if you don't, put SUBARU head gaskets on what you have.
