9
the last time i looked, the front and rear o2 sensors were exactly the same, denso, (96 legacy) just the connectors were different. both are 3 wire units, one has a 3 wire connector and the other a 4..... shop at your own risk. it's hard to know how long some parts will last. but if the factory part lasted 120k miles, .......
how many miles? ej18 and ej22 are very very similar, i would not suspect the head gasket. yours is a right hand drive, so the oil fill spout is on the passenger side. or more correctly for us in the usa, the passenger side is on the left side of the car. i'd check the bolts and gasket for it. rocker covers look good. could also be cam seal. pull the timing cover on that side and look for oil at the cam shaft / sprocket. head gasket problems are rare.
i just did the timing belt, water pump, crank and cam seals, and cam cap o-rings. when i started it up it ran fine, when it warmed up it started leaking coolant off the bottom of the passenger side timing cover. once it got to to full operating temp, it was leaking on to the bottom side of the head at the exhaust and dripping on to the exhaust. 96 ej22, 125k miles, a/t. i'll pull the timing covers the next time i'm working on it, next week, but i don't remember any coolant lines in that area. any ideas?? one more thing, there is a 2 inch by 3 inch hole in the driver side timing cover on the bottom, and the belt appears to be dry. ( did you know it takes about a second for he timing belt to make a full revolution at idle?) thanks, john
2rsj means something like rubber seal 2 sides. i have a bunch of these from a subaru mechanics old/ new stock. he retired and sold everything off. there are some web sites where you can look them up. pm sent. http://www.skf.com/skf/productcatalo...did=1050010203 203-ff, unknown bearing also NTN-6203LU, $4.00 shipped outside diameter: 40 mm inside diameter: 17 mm thickness: 12 mm sealed both sides http://www.ntnamerica.com/datasheet.asp?CO_PARTNOSEARCHTYPE=BEGINS&CO_PARTNO =6203&MANUFACTURER=NTN&BEARINGCATEGORY=RBSRD&CSEAL SHLD=Double-lip+contact+rubber+seal+one+side+(LU)&CL_PARTNO=62 03LU&
if the part number you listed is correct, it has the 4.44 diff ratio, you will need the matching rear diff. the trans part number you listed is for a 96 outback, (2.5L or 2.2L, same trans, the only time a 2.2 had the 4.44 rear diff). you need a trans part number which starts with TZ102ZA ...... you cannot have a '2' right after the second z, it has to be an 'A' after the second z.
have you looked here? www.car-part.com you'll have to search for legacy, 95, 96, 97, 98 etc., as listed above, but you'll have lots to choose from. sort your search by 'distance'. a 450$ trans in town costs the same as a 300$ trans you have to ship for 150$. these guys list one for 175$, Alliance Auto Parts USA-NY(Woodside) Request_Quote 1-800-323-4500
95 legacy uses a TZ102ZAAAA. you can use any legacy 2.2L trans from 95 - 98 as long as it starts with TZ102ZA... impreza part numbers for the same time frame are similar but some check is in order. but you can probably use a 95 - 96 (maybe 97?) impreza 2.2L trans as long as the trans part number starts with TZ102ZA...., but this crossover is unusual and it's going to take some research to be sure it will work. there is a chance you can use an impreza as early a 93, but 95 is usually a break point so i would stick with 95 - 96/97 as long as the trans part number starts off with TZ102ZA.....
