9
i don't know a lot about auto trans, but even if the valve body is different as you say, the duty b may be the same. especialliy if you are just swapping that part, which is way more work than i'd attempt. the duty c i swapped was a fairly simple electric device, i can't imagine they redesigned it just because they upgraded the trans, but maybe they did. the trick would be getting part numbers to compare.
with torque binding, the front and rear wheels 'want' to turn the exact same number of times. when you drive anything except a straight line, there is a differentce between the front and rear wheel rotations, this difference builds up. on long runs it works itself out through the tires on the pavement. on short runs the difference is stored in the drive line, drive shaft, axles, tires. when you shift into neutral or park, it releases. in neutral it just bleeds off, in park it bleeds off and is caught by the park lock. i can't imagine how this could continue without the rear drive shaft in place. does the car lurch in park if you are on perfectly flat ground?
did the car have the 'special coolant additive" put in the radiator prior to the head gasket work. IIRC, that was a pre-requisite of warranty HG work. your radiator may be blocked. i have heard of this happening after the HGs are done in cars with the 'stuff' added . if this is the case, a good rule of thumb would be to flush your cooling system when doing HGs if you have put in the "stuff". ihave read where stop leak only hardens when exposed to air, guess what happens when you drain the system to do the HGs. i course, i could be all wrong. please correct me if i am.
i've read here that the offset was a 5.5". and since i know nothing about wheels, i just ASSUMED it was 5.5 for all legacy / outback wheels. are steel wheels different than alloy? if you were making a farm "truck"out of an outback and wanted much larger tires, could you put spacers on the hubs, (cut out the fenders) so the wheel/tire would clear the struts?
how long since the timing belt was changed?? the blinking (16 times) AT Oil Temp light at start up means there was an electrical malfuntion / failure in the auto trans the last time you drove the car. most likely in the transfer clutch duty c solenoid for sending power to the rear wheels. but it could be several other things as well.
