Everything posted by Soobadooba
25 bucks doesn't seem so bad considering the possibilities of this stuff. I just wonder if it would void my warranty. Don't wanna give SOA any excuses for not repairing my engine if the need arises...even if I know it is better than what they put in it at the factory! -Louis- '04 ForesterXT 5spd '91 Loyale 4wd 5spd Wagon
88 gl dies, restarts, dies, etc.
Soobadooba replied to aa8jz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ahh, didn't register in my mind it was running ok between failures. I thought it was still just sputtering along. That would almost surely rule out timing belt issues. I think the 4ppr issue is definitely a clue IMHO. I wouldn't rule out a coil issue, also. Otherwise I would be willing to bet a wiring connection problem. Good Luck and keep us posted-you've got my curiosity up. -Louis- '91 Loyale 4wd 5spd Wagon -
I may be totally off base here, but I seem to recall something about having a timing belt slip causing position sensor codes to be thrown. Have you checked your valve timing? -Louis- '91 Loyale 4wd 5spd Wagon -
EA82T starts and then stops immediately
Soobadooba replied to greggbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't know if the turbos work the same way, but I can tell you on a non-turbo '91 Loyale, if the hose to the Idle Air Control isn't on (or not on right), it will do pretty much what you describe. Mine will start, run normally for a few seconds and then drop dead. Hope this helps. Good Luck! -Louis- '91 Loyale 4wd 5spd Wagon -
ding dong the wagons dead...
Soobadooba replied to Meeky Moose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just do it, man!!! Pull that Mutha!!! -Louis- '91 Loyale 4wd 5spd Wagon -
Check Engine Light is out! Woo Hoo
Soobadooba replied to Goatboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Cool! You got a solenoid from the junkyard? Did you use the same meter or a different one? -Louis- '91 Loyale 4wd 5spd Wagon -
Hmm... those numbers sound kinda screwy to me... calibration shouldn't be affected that much by changing the battery. Don't suppose you have access to another meter. Even the cheap radio shack ones will do for this application. -Louis- '91 Loyale 4wd 5spd Wagon -
I don't know what model fluke you have, but mine (Fluke87) reads "OL" when held up to air...basically open circuit. It should read at or near zero when the probes are touched together (yes, closed circuit.) Your reading of 4M means four megaohms (which is high resistance) is something I haven't seen before in a working meter but will probably do for this application. When you touch the probes to the terminals of the solenoid, you should see in the neighborhood of 35 ohms- no "M" or "K"should be seen next to the ohms symbol. Hope this helps. -Louis- '91 Loyale 4wd 5spd Wagon -
The only time this has ever happened to me (and it has happened a few times) is when I am working on a car and not bothered to tighten the bolts holding the cables to the battery posts. When you attempt to engage the starter, it draws so much current that one of the terminals often arcs out. Moving the cable will get a good enough connector to get dash lights, etc., but you will lose it again if you try to start the engine again. Make sure the battery terminals are clean and the connectors are on REALLY TIGHT. Good Luck! -Louis- '91 Loyale 4wd 5spd Wagon
Well shoot, I still haven't gotten ahold of the Bratkart lady. I'm going to try again in a few minutes. If I don't reach her tonight, I'll try one more time in the a.m.. If that fails, I guess I'll have to scrap Operation Bratkart for this weekend. I can still come down your way regardless. Let me know. -Louis- '91 Loyale 4wd 5spd Wagon
If you think you can break away, we would probably be back in the Bridgeport area by about 1:00 or so giving us most of the afternoon to take care of other projects. This is all tentative until I can verify the lady is available for us to come by and get the kart. I'm planning to give her a call tomorrow. Be advised, though, that my mode of transportation for this trip could best be described as "third world". Are your tetanus shots up to date? Cheers -Louis- '91 Loyale 4wd 5spd Wagon
Ah, yes, but in the blink of an eye it's gone:( I got your answering machine this a.m. but I might try to give it another shot this afternoon. I'm tied up until at least 2 today, but late afternoon and tomorrow is a possibility. During the week, I am USUALLY out of work by 3:30 if that helps any. This coming Saturday I have somthing going at 2pm. I would have to be home around noon so the morning might be good. Sundays are usually fairly open. Let me know what is good for you:drunk: Cheers -Louis- '91 Loyale 4wd 5spd Wagon
Found location EGR Solenoid!!
Soobadooba replied to SubeeTed's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You got it! That's the one! -Louis- '91 Loyale 4wd 5spd Wagon -
Nope...and yes. That is what makes them easy to tell if they are repairable. As Skip said, the wires tend to break off right at the entrance to the housing. If that is the case (which is most likely), they can usually be repaired. If the winding is burned open, forget it. The housing is molded to the guts and if you can get into it without destroying it, you are definitely my hero. Cheers, -Louis-
Yeah! A four-wheel-drive toaster! Cool! -Louis- '91 Loyale 4wd 5spd Wagon
Why do you love your Sube
Soobadooba replied to dave valiant's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Most bang for your buck, easy to work on and they still have personality. -Louis- '91 Loyale 4wd 5spd Wagon -
Cheap good Subie on e-bay, 45 min left!
Soobadooba replied to GoldDiggerRoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Running D/R? Heck, I would think the drivetrain alone would be worth that much. -Louis- '91 Loyale 4wd 5spd Wagon
