Everything posted by OB99W
99 Legacy Speedometer Problems
OB99W replied to mikeshoup's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSee if pressing on the trip odometer reset causes the speedo to temporarily begin working.
Rear window defogger condenser?
OB99W replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the condenser/capacitor became electrically leaky, it could draw additional current beyond what the grid draws and cause more of a voltage drop than normal (you can expect there to be some drop). If that were the case, the capacitor would become warm or hot (under normal conditions it should be at ambient temp). Given its circuit placement, if the capacitor failed ''open circuit'', all you'd probably notice is a ''pop'' in the audio when the defroster was switched. Checking voltage drop across the relay contacts is still a good idea.
OB99W replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan we assume that you meant to say ''engine on''? (Otherwise, a 13.7 volt reading at the battery doesn't make sense.) Typically, to suppress an arc the capacitor would be placed across the switch (relay) contacts, not across the load (defroster grid). Placing it across the grid would tend to minimize the switching arc being ''broadcasted'' (causing RF interference), since the grid can act as a transmitting antenna for the transient.
EGR Valve Location & Vacuum Hose Problem : Help! Already Tried Search
OB99W replied to RAMSEYLOVER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, it's possible for a disconnected FPR vacuum hose to trigger P0420. The lack of vacuum will cause excessive fuel pressure, which can lead to an overly rich mixture. That, in turn, can raise emissions beyond what the cat can handle, resulting in changes at the rear O2 sensor that the ECU interprets as a bad cat. As has already been suggested, reconnecting the hose, clearing the code, and then seeing if it returns is the easiest way to verify whether that was the problem.
98 Legacy wont start, Thinks its 400 degrees!
OB99W replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSometimes there's coolant seepage, leading to corrosion.
CEL p0026/p0028 codes
OB99W replied to cgflyer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne more thing -- thanks for getting back to us. Your problem and the outcome will likely help others with similar issues.
OB99W replied to cgflyer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhile it could be that the oil was underfilled at the last change, there are other possible explanations. You mentioned going over your usual oil change interval -- maybe you'd been ''using'' oil before, but the level didn't get low enough by change time to cause problems until you went further than you had previously. Oil consumption can be so gradual that it doesn't show up as obvious smoke at the tailpipe. The oil warning light is initiated by low pressure, not level. If there's enough oil for the pump to build pressure, even if the amount is quite low, the oil light will remain unlit. As long as you keep tabs on the oil level, you'll probably be okay. Obviously, I'd suggest checking more frequently, especially since the cause of the level drop hasn't been determined. You're welcome, I'm glad to help.
OB99W replied to Gene J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the ECU ''thinks'' the engine is hot, it won't set up the proper conditions (rich mixture, etc.) needed for a cold start. The engine coolant temp sensor is mounted to the coolant pipe -- follow the upper radiator hose to that metal casting, then look under the intake manifold in the vacinity of the cylinder #3 runner. Unfortunately, it's kind of buried. Be sure you replace the sensor that has two terminals (the one with a single terminal is for the temp gauge).
OB99W replied to cgflyer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're welcome. May I make a suggestion? Don't put off checking the oil level -- given the things you've mentioned so far, the level might be very low. If not, then it would appear that there's an oil pressure problem (but that's less likely).
OB99W replied to cgflyer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the engine oil level. OSV operation is very dependent on getting good oil delivery (as is the rest of the engine ). It's possible if the oil level is low enough, during hard right turns you might have been running the pickup out of oil.
Help! Pulley Issues?
OB99W replied to Kerplunk105's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you referring to the timing chain?
Dead 4EAT Transmission ?
OB99W replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs Gary suggested, it's worthwhile looking for obvious problems. However, if you're able to ''talk'' to the TCU, but it reports no codes, then (as you suspect) the trans likely has mechanical problems. Given the ''crispy'' smell of the ATF, a good used 4EAT should probably be considered.
Rear defroster sucks
OB99W replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey're more of a ''defogger'' than a ''defroster'', although eventually they'll melt ice. You should be able to just measure the voltage on the conducting traces on the window. Put one meter probe on a conductor as close as possible to the trim on one side, and the other probe similarly placed on the opposite side. (It might require two people.) Obviously, try to not damage the conductors. If the wiring, etc., is okay, the voltage should measure only slightly less than the approximately 14 volts measured at the battery.
1996 Subaru Legacy Wagon Issue
OB99W replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf, as Fairtax4me suggested, the plug wires are properly seated at both ends, then do see if reinstalling the originals makes a difference. The two cylinders that are misfiring (#1 & #2) are ''wasted spark'' paired -- they share the same coil in the pack. A problem with that coil or either plug wire could cause misfire on both of those cylinders. Once you get back to us after checking the ignition wires, we can offer other ideas if needed.
OB99W replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith just misfiring codes, what Gary said is a definite possibility. Reread the first two paragraphs of his post #11. What brands of plugs/wires did you use?
Dead cruise, horn, and hazards on 93 Impreza Wagon
OB99W replied to Dodge Aries K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor some possible insight, see http://www.ultimatesubaru.org/forum/showthread.php?t=103838 .
Advice on purchasing code reader
OB99W replied to dcbpe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCAN = Controller Area Network. See http://en.wikipedia.org/wiki/Controller_area_network .
OB99W replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAn ECU tends to be one of the most reliable parts, and would rarely be the cause of multiple codes. I'd suggest reinstalling the original one and see if the engine will start. With so many seemingly unrelated circuit problems, the common factor tends to be power or ground issues. A failing main relay, for example, could cause what you're experiencing.
who's good with electrical?I don't want to go to a stealership!!!
OB99W replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's because, in simple terms, the voltage at the primary of the coil has to be ''pulsed'', not constant. Naturally, for the spark to occur at the correct part of the engine cycle for each cylinder, those pulses have to be correctly timed. The used distributor isn't necessarily good. EDIT: I suggest that you go to the AutoZone website, and register. Enter the data for your car (year, make, etc.), and then go to the repair guides. Under ''Engine Electrical'', select ''Electronic Distributor Ignition System''. Go through that ''tree'' -- there's diagnostic info.
Two mechanics stumped, anyone here have an answer?
OB99W replied to twojtyniak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had mentioned the neutral switch earlier. A new post (#56) in http://www.ultimatesubaru.org/forum/showthread.php?t=85794&page=6 might be worth reading. EDIT: Just to verify my suspicions, I did a bit of searching and came across http://bbs.scoobynet.com/general-technical-10/491306-misfire.html . The OP's problem might not be the switch, but investigating it is probably justified.
OB99W replied to twojtyniak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBesides MAF/MAP, check connections at the intake air temp sensor and especially those at the engine coolant temp sensor (they sometimes seep coolant and corrode the contacts).
OB99W replied to twojtyniak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the forum. I agree that the problem could be caused by something not being sensed correctly, and that the ECU then defaults to some fail-safe (''limping'') mode. Unfortunately, there are several possible causes. Having the code(s) in the form Pxxxx (where the x's are numbers) would be helpful. Having said that, one thing that can be intermittent and cause erratic fuel delivery is if the ECU doesn't know whether the car is in gear or not. The neutral switch could be intermittent. If one of the codes is P1507, see http://endwrench.com/images/pdfs/DiagTroubSum04.pdf . Otherwise, let us know what turns up.
Help my subaru is acting strange!
OB99W replied to titoav15@oneont's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the forum. Flashing of that light indicates the cruise control has been disabled. That's done whenever a problem significant enough develops that the computer determines it can't adequately control things. Misfiring and/or unstable idle speed would certainly qualify. As already mentioned, getting the trouble code(s) read (for free at most larger automotive stores ) would be helpful -- please let us know what you determine in the form Pxxxx (where the x's are numbers), not the code definition(s).
Freshly rebuilt EJ22 seems anemic
OB99W replied to pvenuti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith proper timing and no carbon buildup on the piston crown or the head, 180-185 psi is typical (especially with the non-interference engines). I assume that both banks are now correctly timed, so perhaps one head got shaved a bit. I wouldn't suggest intentionally mistiming in an attempt to equalize the readings -- the 10% difference isn't particularly significant, and it's likely that the engine will perform better with proper timing than with it changed just to equalize compression at cranking speed.
2001 Legacy reads Po420 code and front O2 sensor reads 3-4 volts
OB99W replied to quinnrj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI suggested that thread because it showed that the voltage reading didn't indicate a fault. Some generic OBD-II scanners don't read certain A/F sensors correctly, or the data is misinterpreted. (By the way, that's true in particular for wideband type.) Pep Boys might have suggested the dealer because they would use the Subaru Select Monitor instead of a generic scan tool. P0420 can have several causes (besides the cat itself being bad) -- do a search here for that code, and it should turn up threads with more info. Here's a link to some: http://www.catalyticconverter.org/news/news_page.cfm?Key=catalytic_converter-&News=120 .
