Everything posted by djbroadus
oil pump madness!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Help
im here now till about 3 im suppose to work but have no car, i'm probably gonna use my roomates
I'm not seeing those 10mm's
Which way should I turn it, counter, there are no grooves that its in right?
maybe tommorow I can have my friend come down hes got a camera.
so we got the pulley off but the housing on the pump is broken so the piece with the o ring that enters the block is stuck, what the hell am i suppose to do? i cant pull out i dont have anything to hold on to. this is not good, trying to improve the car and this what happens
Help Soon!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
EA81 engine I'm trying to get my oil pump off to replace it and the alternator pulley is in the way and turning the nut results in the flywheel turning. Any tricks to get this off ???????
Subaru Chopper!!!
last night dug around a little on the car and I think the gaskets on the head are leaking, making things a little louder.
Subaru Chopper!!!
Mine is 2 inch to dual inlet magnaflow exhaust and single 2 1/4 out
Subaru Chopper!!!
What size is the stock y pipe?
Subaru Chopper!!!
Just the valves
Subaru Chopper!!!
Power seems a bit better up hills and stuff, gas mileage is way better. I am going back down tommorow and we are gonna try to quiet it down a bit. What is the stock y pipe diameter like 1.5"? i think i will just make smaller headers because the ticking is just out rageous. I guess I am not subu guru enough bigger is usually better but in this case no.
Subaru Chopper!!!
Scavenging?
Subaru Chopper!!!
Ok so today went my budddies shop an got my exhaust put on- 2" Y headers to magnaflow muffler 2 1/4 out to tail pipe. Sounds sweet when at high Rpms or down shifting but idling and lower rpms it sounds like a frickin jesse james chopper I dunno its a little scary
Lewy's Progress
Well Lewy is sort of coming along, I sold my truck so lewy is my daily driver. Found out i need a new right axle and oil pump. I have installed new stereo and headlights (IPF with yellow ion bulbs) trying to hook up the third eye. Tommorow going to see what kind of custom exhaust my buddy can do for me, thats about everything as of now.
what headlight bulbs to buy?
djbroadus replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPIAA nothing better
Front end noise???
ok there is no vibration on the freeway or any other driving time, just letting off the gas and shifting.
Front end noise???
Whole axle or just CV's???
Front end noise???
Having some funny noises going on, when letting off the gas or shifting theres a knocking sound then when accelerating it goes away. Also when turning left sounds like when you close a zip tie but constant while turning. Help please
Gas Tank???
Cool thanks Q man
Rieter Pit Run, WA, January 3rd 2004 **Updated**
I might be able to make it out there, I dont think Lewy is up for it yet but he might just make an appearance to say whats up. i was hinkin bout takin the yota though.
Gas Tank???
I was wondering If someone could tell me the gas tank capacity on a 1980 1600 DL Hatch? Thanks
Best Oil opinions
Like some opinions on best oil for EA81 1800's?
oil pump seals
What about EA81 I need to get it for my hatch? Serial number, name?
Fox Shocks?
Anybody using these, there a little spendy but seem pretty sweet. i was wondering If they would fit soobs? Description * Special "Smooth Bore" seamless alloy steel body * Features a high-flow, large bore, damping piston, and utilizes the highest quality valve shims available * Nitrogen gas pressurized (200 psi) * Teflon lined steel spherical bearings * Hard Chrome 5/8, 7/8, 1 1/4 steel shaft (1 1/4 is considered an air shock) * Billet aluminum end-caps and eyelets * Customer rebuildable and revalvable
I need some shocks
How much is the kit Qman
