Everything posted by J A Blazer
Need help - side mirror controls bad
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks guys. I suspected the mirror controls was separable from the rest, and actually found one on eBay.
2000 OBW, 155K. Suddenly the 4-way rocker control for the side mirrors has failed in one of the directions, for both mirrors. Anybody been there with this problem? Simple fix? Is that control separately replaceable, or must the entire assembly (including door window controls, etc.) be replaced? TIA.
2003 Forester 2.5XS - Sell it or replace the engine?
J A Blazer replied to ajmaudio's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXQuestion: Is leaking oil really evidence of a bad head gasket? I thought the leak would be coolant, not oil. Maybe what your mechanic is seeing is oil from the valve cover gaskets, not the head gasket. I'd get a second opinion.
J A Blazer replied to ajmaudio's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAmen to what everyone else has said. I would add that, regarding # 3, it is not the valve cover gaskets per se that are bad; its the seal between the spark plug tubes and the underside of the valve cover that will leak over time, causing oil to coat the spark plug and the plug wire. But in order to replace them you have to replace the valve cover gaskets, the bolt hole grommets, and the tube seals. But that is an item of repair that can be deferred a long time, and as others have said, would be included in a head gasket job.
How do I test my rebuilt starter?
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI may have looked, but I have a local source - Arlington Armature - in Springfield, VA. Cost about $15.00.
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks everyone. Removal, rebuild, and reinstallation all successful.
I finally was able to remove the starter from my 2000 OBW. Replaced the contacts, and am now ready to reinstall it, but thought it might be a good idea to test it first. Jumper cables to the battery, I assume, but what about that small wire contact next to the positive terminal on the solenoid? What do I do to/with it? TIA.
Rear Differential Bushings Write-Up w/Part Number :) Subaru Legacy 90-94
J A Blazer replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes my 2000 Outback Wagon have a similar setup?
2000 4 cyl OBW - need new starter
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was able to remove the top bolt with no trouble. From above although I could position the socket on the lower bolt I could not get enough 'swing' to get it loose. From below, on jackstands, I simply could not get my socket on the bolt. No doubt I could have gotten it done were it on a lift, but the DIY facility that I have used in the past unfortunately just went out of business.
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRooster: Trust me, I tried, from above and below (jackstands but no lift), but simply couldn't do it. And I don't easily give up.
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually, I got the contacts intending to rebuild the one that is in the car, but I'm not able to remove the starter myself (I tried) and therefore I will probably have to take it to my independent mechanic, where I simply won't be able to be around to 'rebuild' the starter.
2000 4 cyl OBW, automatic transmission, 155K. I need to replace the starter. RockAuto lists several from various (re)manufacturers, at various prices. Any reason to pay more than the minimum? Any to particularly avoid? TIA.
Subaru Engines 2.5
J A Blazer replied to ktdenali's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIsn't there a place in Denver? http://www.CCREngines.com?
Knock Sensor Problem
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, it is not immediate. What plugs on the bellhousing are you describing? Thanks.
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes I reset it, several times now.
2000 OBW, 153K. Replaced the knock sensor (with a new OE one) but still get the CEL 325 code. I installed it according to specs as best as I can tell. Is there some other condition that will throw this code?
Knock sensor 101 and replacement
J A Blazer replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhile installing a new knock sensor I encountered slight resistance with the bolt, and rather than risk cross-threading it, I installed the knock sensor in a different location that took the same thread. It is slightly towards the rear and towards the drivers side, higher up on the block. Will this work?
What will $20,000 get me?
J A Blazer replied to AlanS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I were you, I would get a 2008 6-cylinder LLBean Outback wagon. It has the facelift that was new that year, the 6-cylinder does not require premium fuel, and the automatic transmission has 5 speeds. If you look hard enough you will find one; they are routinely listing in the low $20s.
AC not working, anyone know of a....
J A Blazer replied to Rpm90001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLet me echo what GrossGary says. In my 2000 4-cyl OBW, all it took was the two o-rings.
Non OEM knock sensor, anyone install one?
J A Blazer replied to Rpm90001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKeys to a successful knock sensor installation are cleaning the surface, aligning at the proper angle, and the right torque.
Coolant conditioner with new head gaskets?
J A Blazer replied to Rpm90001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen my HGs were done at about 115K I was told (by the dealer mechanic) to continue to use it.
Working on a 3.0 2000-04
J A Blazer replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAdmittedly a minor point, but there was no H6 Outback (or VDC) in 2000; didn't start till 2001.
Legacy Outback VDC Rear Subframe rusted through?
Could you please post pix of exactly what you are talking about?
Getting a '95 Legacy and taking it across the US. What's it going to need?
J A Blazer replied to v8volvo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy recommendation would be to closely monitor and inspect the car at regular and frequent intervals during the trip so that problems can be spotted and corrected before they disable you.
J A Blazer replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYear? Miles? Is this the original knock sensor? In any event, sounds like too much torque was applied last time it was installed.
