Everything posted by J A Blazer
Car trembles
My 2000 4-cyl A/T OBW has 120K; all original suspension components; never wrecked; new tires. If I'm going about 50 mph and back off the throttle, the car 'trembles' briefly as it decelerates. Also trembles/shakes at low speeds with uneven curb cuts, speed bumps, etc. What is the likely explanation? What bushings/mounts/etc. typically wear out by this mileage and might explain this problem? TIA.
A/C question
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAbog: Actually, I'm fairly certain that he did put in dye and I brought the car back to him several weeks later, but the black-light did not reveal any leak.
A/C question
2000 4 cyl OBW, 120K. About 18 months ago my A/C stopped working. My independent mechanic topped up the refrigerant and it worked fine until just recently. Took it back to him, and he says now there is a leak in the discharge line (part # 11 in the schematic, the one that runs between the condensor and the compressor) where it connects to the compressor. Is this likely just a bad o-ring, or does the line itself need replaced? Either way, does this repair require a new receiver/dryer at the same time? TIA.
Replacement axles
J A Blazer replied to Steves72's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI bought two axles from Marshall and was pleased with the transaction, but I did perceive that he is a one-man operation and sometimes slow to respond to phone/fax/email. But worth the wait.
EZ30 H6 Spark Plug R&R
J A Blazer replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy mechanic told me that in order to change the plugs on an H6 it is usually necessary to remove the engine mount bolts and lift the engine slightly in order to permit the spark plug socket wrench to get past the frame rails.
burnt oil smell?
J A Blazer replied to crockettbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPerhaps what you are smelling is grease from the CV joints, spinning out through torn CV boots onto the exhaust system. Thats what happened to me.
Lookie!!!!!!!!!!!!
J A Blazer replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFantastic! Who is/are 'OpposedForces'?
HELP: CEL CODE P0420 {2000 Forester}
J A Blazer replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt about 113K my '04 OBW threw the same code. Dealer reset it, said to watch it, and it went several thousand miles until it briefly came on again and spontaneously went out. Until it comes on, and stays on, I'm forgetting about it.
Oil in spark plug hole
J A Blazer replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTAmore accurate description of what is leaking is the gasket at the top of the spark plug tube. The valve cover gaskets are something else.
Glad USMB is fully back!
J A Blazer replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs there an archive of old posts? If so, how do we get to it?
03-04 Outback Light Bar Group Buy Info
J A Blazer replied to yukondoit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWill this fit my 2000 OBW?
Replaced Contacts, Now it just Clicks
J A Blazer replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI replaced the contacts in a Denso starter (for my Lexus) and had no problems at all. Yes, one of the contacts is asymetrical, so grinding yours may have inadvertently caused a problem. I had no problem keeping the contacts 'flat' while I torqued the nuts, and didn't use a press.
What extra parts do I need to replace struts and springs on my Outback??
J A Blazer replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI recently had to disassemble a front strut/spring assembly because a previous mechanic forgot to install a washer between the strut and the tophat. Although I have a high-quality spring compressor I was unable to get the job done, and took the assembly to a local Goodyear store; they did it for me, for $20. Money well spent, in my opinion.
What should be done for 90K servicing for 2003 Subaru Outback H6 VDC?
I'm curious; how much did you pay for your 2003 VDC?
Please , advice on front axles
J A Blazer replied to Hendrik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMWE for me too. But do the math before you go to the trouble of sending your old axles back to him simply to recover your core charge. Cost of shipping will probably exceed the credit you will get.
*..Baja hitch question..*
J A Blazer replied to bakerman1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI bought something from etrailers and was very happy.
2009 models - no Outback 3.0?
Any idea why the official 2009 Subaru website still fails to acknowledge the ability to get an Outback wagon with the H-6 3.0? The brochure lists it.
rear right door damage
J A Blazer replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe that piece fits into a corresponding slotted piece on the door, that prevents the door from popping open during a side impact.
2008 models
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis thread should have been labeled '2009' models; my mistake. But I went to the dealer today and picked up a 2009 Outback brochure; it clearly shows the H6 3.0 being available for the 2009 Outback wagon. I showed the dealer, on his computer, the official Subaru website which is silent as to that option; he was surprised, and had no explanation.
2008 models
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBut apparently you can no longer get the H-6 in the Outback, if the Subaru website is to be believed, although the unofficial Subaru site "cars101" claims that it is available.
2008 models
I must have missed this memo, but when did Subaru stop putting the H6 in the Outback, and when did Subaru stop building L L Bean editions?
Trailer Hitch Install and Frame Weld Nuts
Maybe your car had been rear-ended?
Lower Control Arm Bushings
J A Blazer replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure if they are bad, but I'm trying to figure out why there is more play in my front suspension than I like. I don't think the problem is tie rod ends or strut mounts, so other than control arm bushings or ball joints what could it be? 112K.
What is involved in replacing the lower control arm bushings on a 2000 OBW? Is this a DIY? If not, what is the dealer likely to charge?
05 Outback Sedan H6 Question...
J A Blazer replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought the H6, unlike the turbo H4, did not require premium gas?
